General Supercharger Thread
  1. Aug 17, 2023 at 5:55 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Lowest I've seen is $500 but god know if it was a genuine. They usually sit around ~$660ish
    Mdl and Silver17[QUOTED] like this.
  2. Aug 17, 2023 at 5:56 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    :rofl:Having trouble determining what retail is, damn prices are all over the map. And then there’s the used market to consider!
    Wynnded[QUOTED] likes this.
  3. Aug 17, 2023 at 5:58 PM
    Saltyhero13
    MSRP is ~900 so Tree Fiddy.
    Wynnded likes this.
  4. Aug 17, 2023 at 6:05 PM
    Silver17
    Eastern PA
    Hmm, that plus the adapter…might be looking at 800 bucks for 15 horsepower. That would be a tough sell for someone more financially responsible than me…
  5. Aug 17, 2023 at 6:05 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    TB going on, It is on the SC but it's 116 & 60% humidity, I was sweating so much I could not see from the sweat in my eyes, had to come inside.
    The original had the rubber ring & no gasket so I did not use anything.
    Mdl, reywcms, Silver17 and 1 other person like this.
  6. Aug 17, 2023 at 6:07 PM
    e30cabrio
    I got the TB for under 360, the adapter was 115 I think delivered.
  7. Aug 17, 2023 at 6:12 PM
    Silver17
    Eastern PA
    I’d be pretty interested for that price all in. No retune needed to take advantage of the extra air?
  8. Aug 17, 2023 at 6:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I think I got mine for $630 from a Lexus dealer online shipped super quick
    Mdl and Silver17 like this.
  9. Aug 17, 2023 at 6:15 PM
    e30cabrio
    I'll find out once it's in.
  10. Aug 17, 2023 at 6:26 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    So this happened today. Never seen double digit boost numbers. 90 degrees here.
    Harrop with 80mm pulley, SABM intake, stock exhaust.
  11. Aug 17, 2023 at 6:28 PM
    ZPhilip
    Philip
    West Chester, PA
    The internal coolers are different in location and size, if I remember correctly. Viktor had a video on it a while back.
    Winks4x4Toy likes this.
  12. Aug 17, 2023 at 6:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Makes me want to pulley down one more lol
  13. Aug 17, 2023 at 6:38 PM
    ZPhilip
    Philip
    West Chester, PA
    Why not?
  14. Aug 17, 2023 at 6:39 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    already has enough power in the dirt but may consider it lol
  15. Aug 17, 2023 at 6:42 PM
    e30cabrio
    It is done, started right up, revs normally. Hope to get a read tonight.
    Before it got over 90 at all times I was seeing 10+, since it's over 110, 7 has been normal.
    Mdl and reywcms like this.
  16. Aug 17, 2023 at 7:08 PM
    e30cabrio
    Did it look like mine? I don't understand how LKQ gets a new unused part but I really don't think it was ever used.
    Also, glad I took & looked at my pics, forgot to connect the maf.
    :p
    Mdl and reywcms[QUOTED] like this.
  17. Aug 17, 2023 at 7:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks like a throttle body you should’ve measured the diameter lol. Should run fine mines untuned and drivability as far at the throttle body is the same as before with the stock unit
  18. Aug 17, 2023 at 7:12 PM
    e30cabrio
    I meant how it is clean, it is definitely bigger, was a massive PITA getting the intake tube on.
    lol
    reywcms likes this.
  19. Aug 18, 2023 at 1:13 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    yes. I was referring to the new mag 2650.
    it apparently has "twin" intercoolers, albeit in the same location as the 1900.
    is it as large as the harrop?
  20. Aug 18, 2023 at 3:20 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not that I/C would matter...
    from what we see on these pages, the 1.9L mag performs quite well...as it builds boost VERY quickly.
    The dragys prove the performance - the initial G's on the 1.9L maggies is demonstrably better than kinda-similarly equipped Harrops/2650's.
    The bell curve for S/C performance with non-built engines is very tight. dragy's prove that point.
    said another way...our ~600hp trucks perform like ~600hp trucks regardless of S/C size.
    the Raptor R & TRX perform like 700hp trucks.
  21. Aug 18, 2023 at 3:24 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    With that said...
    If our "~standard" builds produce 4.4-5.2 0-60 numbers.....
    what are the dragy numbers for fully/kinda built Tundra engines? Let's call these 1 std dev.
    @ViktorG would be somewhere to the right of 2 std dev's.
  22. Aug 18, 2023 at 4:59 AM
    e30cabrio
    reywcms[QUOTED] likes this.
  23. Aug 18, 2023 at 6:11 AM
    e30cabrio
    How about 12k+ for 50 hp 70lb?
    This was my 2006 350Z
    https://my350z.com/forum/na-builds/516492-96-5-11-0-1-88mm-bc-crank-na-build.html
    My 22k engine replaced by Nissan is using 3 quarts per 1k miles.
    I am doing an NA stroker and can't wait to get it back!
    Specs are BC 88mm crank, BC rods 96.5 JE 11.0.1 pistons +1mm Manley valves and Jim Wolf S7 cams.
    I bought a sub 10k oil consumer block & heads so the build could be done and I could keep my car.
    Oh, also, it took over a year shuttling it from bad shop to worse shop to finally someone that completed it (poorly) it failed after a few k miles & I sold it for 3k & dumped an eBay motor in & dumped the car.
    Jbehredt and Silver17[QUOTED] like this.
  24. Aug 18, 2023 at 7:45 AM
    Silver17
    Eastern PA
    Hey you speak for your own G’s! :D
    Chirping all 4 tires on takeoff mind you.
    Fastlane47, e30cabrio and reywcms like this.
  25. Aug 18, 2023 at 8:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    How much boost are you seeing?
    nobodyintexas likes this.
  26. Aug 18, 2023 at 8:07 AM
    Silver17
    Eastern PA
    Highest spike I’ve ever seen was 10 for a split second. Usually the peak is 8 or 9psi.
    Mdl, Fastlane47 and reywcms[QUOTED] like this.
  27. Aug 18, 2023 at 8:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    then holds at?
    HulkSmurf14 likes this.
  28. Aug 18, 2023 at 8:38 AM
    e30cabrio
    Here is a comparison of the original TB & the RS-F
    Mdl, reywcms and M3Tundra-JK like this.
  29. Aug 18, 2023 at 8:41 AM
    Silver17
    Eastern PA
    It hits 7psi by 2700rpm, and then is 8psi by 4000rpm, and 9-10psi between 4 and 6k rpm.
  30. Aug 18, 2023 at 9:48 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
