18" rims/ Tires on 1st Gen
Discussion in '1st Gen Tundras (2000-2006)' started by johneg2u, Aug 13, 2023.
  1. Aug 13, 2023 at 1:22 PM
    johneg2u
    johneg2u [OP] New Member
    2002 Tundra Ext cab 4 x 4 Limited
    Will 265/70/18 fit on my 2002 Tundra Ext cab 4 x 4 limited?
  2. Aug 13, 2023 at 1:37 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
  3. Aug 13, 2023 at 2:22 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Your wheel width and offset will help answer.
    I've got 18x9 with offset 10 wheels on a 2006 DC 2WD. Running 265/60-R18 with no issues. Running stock height rear with 2" front level. Front tires have about 3/8-1/2" clearance between the tire and upper control arm. No rubbing anywhere on chassis or suspension.
    Depending on your wheel offset or suspension setup you may be colliding with 70 series tires.
