Tacoma wheels and rubbing
Discussion in '1st Gen Tundras (2000-2006)' started by Spread5150, Aug 10, 2023.
  1. Aug 10, 2023 at 7:55 AM
    Spread5150
    Spread5150 [OP] New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
    I found a deal on these Tacoma wheels. They look great and came with 265/70/16 on them.
    I would like to take it 275/70/16 and the only place it looks close is upper control arm.
    I have a 2.5 rough country lift up front w JBA upper control arms.
    I don’t see anyplace where I think they will rub as far as frame goes and I have an aftermarket front bumper so anywhere up front shouldn’t be an issue.
    I don’t want to get into a wheel spacer and I’m looking at the BF Goodrich tire
    Ko2
  2. Aug 10, 2023 at 8:16 AM
    Jeebus that spring looks cranked the F up. Is it actually providing any function?
    Do you rub anything when the truck is jacked up and wheel is hanging fully?
  3. Aug 10, 2023 at 8:37 AM
    Spread5150
    Dave
    I don’t believe so. Rough country assembled them. They were direct bolt in.
    actually I am corrected size I’m looking to fit is 265/75/16
  4. Aug 10, 2023 at 8:55 AM
    Just looks so radically different from what I've seen on any vehicle, not just these trucks. Coil looks really wide, and almost no spacing.
    Yours first here, 5100 from DrLeonard after that (1st pic I could find). Roughly same lift in inches it looks like, but your coils look super compressed, with half the space between each rotation.
  5. Aug 10, 2023 at 9:43 AM
    Spread5150
    Dave
    Hmmm is there something you recommend I check to be sure it’s right ?
  6. Aug 10, 2023 at 9:56 AM
    Spread5150
    Dave
    Not sure if it matters but I do have a heavy duty bumper up front.
  7. Aug 10, 2023 at 10:23 AM
    Spread5150
    Dave
    Here it is a tire off and lifted
  8. Aug 10, 2023 at 10:49 AM
    Spread5150
    Dave
  9. Aug 10, 2023 at 11:19 AM
    Awesome, that's always a win. They didn't give you any crap for going in and buying while unsure about fitment?
    And yeah, that looks like you're closer to 4" lift up front, going by the last pic in your 1st reply. What measurement do you get measuring from center of the wheel hub to the top of the fender? IIRC, stock is usually around 21 ¼" - 21 ¾".
  10. Aug 10, 2023 at 11:41 AM
    Spread5150
    Dave
    Here’s the new tires. They ride great. I think they are set to 35. Might bump them to 40.
    e1 rated tires.
  11. Aug 10, 2023 at 3:56 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I’m not a fan of spacers but those wheels need them. Doesn’t look like you need them clearance wise but those wheels tuck in too far imo.
    The Black Mamba likes this.
  12. Aug 10, 2023 at 4:52 PM
    Spread5150
    Dave
    I really did my best to stay away from wheel spacers. I know the strain on the ball joints on these trucks is already bad. If they didn’t rub I was happy. It’s mostly pavement pounder. Just a couple of deer feeder corn runs now and then and the occasional mud hole in and out of the ranch.
    BF goodrich has always been good to me. East Texas mud and west Texas rock along with years of hwy use. Not many complaints in all the years.
    Elevatorguy likes this.
  13. Aug 11, 2023 at 4:54 AM
    Elevatorguy
    James
    I’ve had a few sets of ko2s. They suck in the rain, otherwise I like them. Hopefully the ko3 takes care of that issue.
  14. Aug 13, 2023 at 8:52 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I used to feel this way. Did a lot of reading here and there. Figured if you put them on right with loctite and torque properly and never use an impact on them afterwords you're probably good. I run a spacer with this exact same wheel and tire size but I also have fender flares so the tucked in effect was more dramatic. Mine rubbed on the frame at full lock with no spacer so that pushed me to just go ahead and do it.
  15. Aug 14, 2023 at 6:37 AM
    That's the biggie, especially with alloy spacers. I'd recommend steel if you're concerned. I've seen my fair share of cracked alloy spacers either because someone was at a shop where the tech impacted the lugnuts on without concern vs. torqueing, or because the owner over-torqued using a 4-way like I do. With a standard OEM setup, no spacer, I rarely bother with using a torque wrench on lugnuts. I have a memory of how much physical output is required and go to that level. :laughing:
  16. Aug 18, 2023 at 11:23 AM
    Richid
    Richid New Member
    Should've passed on the taco rims - there's plenty of 4runner rims out there that have the correct offset.
  17. Aug 18, 2023 at 11:39 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    A miss is as good as mile.
  18. Aug 29, 2023 at 3:58 PM
    Spread5150
    Dave
    So they have been great.
    What does everyone think of these alignment numbers
  19. Aug 29, 2023 at 5:27 PM
    I feel like they went the right way dialing in the camber, but way wrong with the caster. Did you tell them what you were looking for?
    Rodtheviking likes this.
  20. Aug 30, 2023 at 8:03 AM
    Spread5150
    Dave
    Here is the current numbers on bottom. Where do I go from here.
  21. Aug 30, 2023 at 8:19 AM
    Well, if we go by @assassin10000's suggested baseline numbers, taken from the sticky info-dump thread...
    • Alignment numbers after lifting: This is important, if you want a roadworthy driving experience without eating tires after your lift, there's a sweet spot for the 1GT that's been road-tested and proven by an array of members time and time again. Specifically ask the shop to aim for the following: -0.1 to -0.3 camber, 2.6 to 2.8 caster, 0.1 to 0.2 total toe in. For camber, aim closer to -0.1 if you're mostly driving freeway, and if you like corners/onramps at speed, aiming closer to -0.3 will offset outside-edge tire wear somewhat.
    I'd say it looks like the shop is more concerned about keeping the numbers in the green, and you'd be in a better place if you dialed back the toe a smidge, with the caster was back closer to the original values in red, trying to get nearer to the 2.6-2.8 range.
    I'm not the alignment expert though. There are other guys on here who do it for a living, day-in/day-out. They'd be better to speak to this.
    Honestly though, I dunno what that Rough Country setup is doing/has done, and what it's capable of. Based on what I'm seeing, I'd be concerned about it, personally, but I also wouldn't have installed their stuff on my truck when Bilstein is about the same $$ ballpark. There's a few things that concern me about what I'm seeing in your pics, but I won't beat that horse again. Trying to focus on topic at hand.
  22. Aug 30, 2023 at 9:13 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the steering feels too light, go to 2.5-2.8 caster if possible.
    Currently (after a year and some miles) I'd recommend this for those that corner a bit faster:
    -.5 camber
    2.6-2.8 caster
    .1-.2 total toe (.05-.10 per side)
    For normal or mostly freeway
    -.3 camber
    2.6-2.8 caster
    Depending on your suspension setup (lift, upper arms and even lower arms) the camber or caster could change significantly. If lifted without uppers you may be stuck with less than 2 degrees caster (.5-1.5). If you have solo lowers you may get 4+ degrees. It all varies.
    shifty`[QUOTED] and Rodtheviking like this.
  23. Aug 30, 2023 at 9:35 AM
    OP is running JBA uppers, IIRC. OEM lowers.
  24. Aug 30, 2023 at 9:42 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Jba's have extra caster for lifts.
    Definitely get caster to 2.5+
    The wheels are pulled too far back and probably rubbing the footwell.
    Rodtheviking and shifty` like this.
  25. Aug 30, 2023 at 9:49 AM
    I updated language in the sticky, I think this probably encapsulates what you've shared across a number of posts RE: alignment --- I mis-cropped the damn pic, I'm not lopping off those other two which have nothing to do with you
