  1. Aug 7, 2023 at 8:02 AM
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    I didn't check that, will have to. Thanks. Gonna get on a first name basis with the dealership parts girl pretty soon here.
  2. Aug 7, 2023 at 8:22 AM
    Duh bro, what did you think this song was about? Totally the background music playing during that scene.
    FrenchToasty and JasonC.[QUOTED] like this.
  3. Aug 7, 2023 at 10:15 AM
    Azblue
    The Dirty T ( ^_^)_且
    Is she hot?
    bmf4069 and oscardog86 like this.
  4. Aug 7, 2023 at 10:30 AM
    danb
    danb New Member
    Minnesota
    Beautys a light switch away, amigo
    Galladanb, NUDRAT, KNABORES and 8 others like this.
  5. Aug 7, 2023 at 4:12 PM
    danb
    danb New Member
    Minnesota
    Installing the Bilstein 5100s with OME springs that were preindtalled and cant figure out what these 4 big washers are for. Instructions say they're for jounce bumpers?
    metalpete and oscardog86 like this.
  6. Aug 7, 2023 at 4:54 PM
    "jounce bumper" is another word for "bump stop".
    Some vehicles will have bump stops integrated into the strut, I've only seen it once or twice in my lifetime. Our trucks have two bump stops on each side of the frame, facing downward, up front. Hold up and I'll get a pic from my recent suspension activities. I dunno where you'd be using those? (left stop is hidden, but it's there - basically these are what the LCA come in contact with when the suspension is in full travel upward, i.e. hitting a big ass bump - I assume this is the 'jounce bumpers' they're talking about?)
  7. Aug 7, 2023 at 4:57 PM
    Those big washers are for your front bumpstops. They spin on and off with a larger crescent. Use two washers as spacers to make the bump stops stick down a little further, then reinstall. Keeps you from bottoming out the shocks. I didn’t use them with my first set. Blew the passenger side shock at 60k miles, may not have been related.
  8. Aug 7, 2023 at 5:01 PM
    Makes sense, then.
    I mean, if I were really worried about it, I'd probably replace the factory bump stops with Duros. I need to see what my travel is like once I get my suspension in.
  9. Aug 7, 2023 at 6:26 PM
    danb
    danb New Member
    Minnesota
    Ahhh thank you, makes sense. Will throw them on tomorrow. Got one side in no problem, but the driver side is a pain. The bolt at the bottom was bent and a normal ass nut was securing it. Went to fit the shock and the bottom wouldnt line up parallel with the bracket, offset a bit. The blue lines would be the bracket, green is the shock. I dont know enough about suspension besides messing with the spring can kill you, so I'm not sure if its possible to twist it to fit. I would think I'd have to mess with the nut keeping the spring in tension right?
  10. Aug 7, 2023 at 6:42 PM
    I'm not following the problem. You mean the shock mount won't line up so the bolt goes straight through? If so, just take a BFS (big f'n screwdriver), insert into the shock mount, spin the shock shaft until aligned, then insert into LCA provision and work the bolt thru.
    With my truck, I found it's easier to remove the top bolt of the swaybar link while the truck is still on the ground to gain some added LCA downward travel making the job easier, but there's no reason you can't do it now. EDIT: Although it'll be easier if you grab the OEM bottle jack and toss it under the tapered end of the LCA, and jack it up to relieve tension on the swaybar link. Reattach when the truck is back on the ground, or use the jack to jack it back up into place, maybe easier.
    I'm pretty sure the lower strut mount nut on mine was a normal nut also, is the other side different? It's unusual the bolt is bent though. I'd probably want a new one, personally. But that's just me. I'm anal-retentive.
    Make sure you install the bolt the same direction it came out. Nut should be on the front bumper side, bolt head facing the rear. Careful not to damage your CV boot in the process.
    As long as the spring is mounted properly inside the strut, there's not really any risk of losing teeth or skull fractures.
  11. Aug 7, 2023 at 6:49 PM
    danb
    danb New Member
    Minnesota
    Yup, exactly. I wasn't sure if I could mount and twist to fit without damaging the assembly. A lot of this is new to me so I appreciate the help.
    Yeah the bent bolt is concerning, and the regular nut as well. The passenger side nut for the mount bolt had a flange on it, much more substantial as well. Back to the parts department tomorrow I guess
  12. Aug 7, 2023 at 7:01 PM
    Mine is a regular nut and washer. That's it. Pic below. For our 2006, per parts system, here's your part numbers.
  13. Aug 7, 2023 at 7:02 PM
    It skipped the other pic of my bolt etc. Here.
    oscardog86 likes this.
  14. Aug 7, 2023 at 7:04 PM
    Last but not least, can confirm it's just a regular old nut, not flared at the base. So mine must be stock.
  15. Aug 7, 2023 at 7:14 PM
    danb
    danb New Member
    Minnesota
    what a dawg, absolute G. been struggling to find those numbers!
  16. Aug 7, 2023 at 7:18 PM
    I needed to run them down myself, I dicked up the threads a little bit on my bolt pulling out the OEM strut, LCA dropped and jammed the bolt, then the bolt head was on a crash course to tear my CV boot, it was a debacle. First time getting into the meat of 1GT suspension over here, some mishaps occurred :D
    txagg and danb[QUOTED] like this.
  17. Aug 7, 2023 at 7:29 PM
    danb
    danb New Member
    Minnesota
    blazing a trail for the rest of us
  18. Aug 7, 2023 at 7:36 PM
    Pffffft, I'm standing on the shoulders of giants brother. Consider me a parrot with fair-to-mid info retention and access to a few resources.
  19. Aug 8, 2023 at 4:10 AM
    Radiator and radiator accessories are here. Radiator juice looks fine, so I don't need a flush or full drain. How much coolant do I need? And how long will this take on a sequoia? It's got a bunch of weird shit on the front. I also need to get a radiator funnel. Do parts stores carry those? I'm looking to do this Sunday when we get back from the lake.
    DJenerated likes this.
  20. Aug 8, 2023 at 4:27 AM
    danb
    danb New Member
    Minnesota
    https://youtu.be/wpNqsXDL8Lw
    this vid might help
    Mr.bee likes this.
  21. Aug 8, 2023 at 5:11 AM
    I have no idea how much you'll get out of just the radiator. I had to add over 3 gallons when I drained the block last month.
    You might have to buy 2 gallons and end up only using half.
  22. Aug 8, 2023 at 5:15 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I just ordered a Lisle 2468 kit that should work. Ships today and should be here Friday. I can bring it by on Sunday.
    bmf4069[QUOTED] likes this.
  23. Aug 8, 2023 at 5:50 AM
    Man, I love the cap on that thing. I wonder what brand it is. SnugTop? Looks like the same long-oval logo I saw on a truck in NorCal that fit so nicely. Awesome OEM+ look to it. Fits perfect.
  24. Aug 8, 2023 at 8:36 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Hey, that set up looks familiar!
  25. Aug 8, 2023 at 9:40 AM
    bfunke
    bfunke Tundra Curmudgeon
    Coolants are diols which oxidize into diacids over time. If your coolant is more than a year or two old, drain and refill with new. I opened the drain clock on the radiator and then removed the lower hose at the radiator. There are two 10mm block drains below the exhaust manifold. Easy to reach with socket wrench and 6 in extension. If you have a lot of corrosion be careful or they may snap. Turn heater on max to open valve that controls coolant flow to heater core. No need for Lisle kit. I used a household bucket to catch old coolant and put it into the empty jugs to take to our local recycle center.
    Mr.bee and metalpete like this.
  26. Aug 8, 2023 at 9:58 AM
    JakeJake
    2000 Tundra AC 4X4
    @bfunke
    A spill proof funnel makes the refill/air-bleeding a hands free one step process. Eliminates all the checking and filling and checking and filling after having the cooling system open. Definitely in the nice to have, but not necessary category.
    Also, I like to drain mine right right back into the ground where it came from ;)
    txagg and bmf4069 like this.
  27. Aug 8, 2023 at 10:25 AM
    That would be awesome. I was gonna order one but it said Thursday delivery, which is when we leave, and I don't want it sitting out that long.
  28. Aug 8, 2023 at 10:27 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @bmf4069 might not be a bad idea to change ironmans coolant, too; if this winter is supposed to be as harsh as they're predicting.
    bmf4069 likes this.
  29. Aug 8, 2023 at 10:38 AM
    Pretty sure my coolant is green too.
  30. Aug 8, 2023 at 10:41 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Did you say you were going to wait and do the timing belt in a year from now? I'd just knock it out with the radiator now if you can.
    bmf4069 and DJenerated like this.
