4Runner TRD Pro rims on a 2006 Tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, May 23, 2020.
  1. May 23, 2020 at 5:21 PM
    fighthedude
    fighthedude [OP] New Member
    Would there be an issue if I bought these rims for a 2006 double cab 4wd... I know they are 4 runner but not sure about fitment issues....I was thinking of getting 265 70r17 or 285 70r17. I am slowly piecing my items for truck together and found a few memorial day sales... For those that have these rims what did you pay?92378EC4-84D6-4471-9BBB-34A711B1AD4A.jpg
  2. May 23, 2020 at 5:34 PM
    toyoboyo
    toyoboyo New Member
    I am running these on my 2005 Sequoia with spidertrax spacers. They look great. 285-80-17.
    Some shops won't mount 285's on these wheels.
  3. May 23, 2020 at 5:52 PM
    fighthedude
    Copy. So I need a spacer? Does that make tire stickout farther or just so it will fit?
  4. May 23, 2020 at 5:56 PM
    toyoboyo
    toyoboyo New Member
    Yup! You need the spacers to stick the wheel/tire out further to prevent the tires from rubbing on the fenders. If you go 275 you will have a smaller chance of rubbing.
    I rubbed a lot on 285's. I finally got my suspension/alignment in check and the passenger tire slightly rubs.. I'm about to have it re-aligned by a reputable 4x4 shop to have zero rubbing issues. I got slightly better MPG on 275. 285's just look so good!
  5. May 23, 2020 at 6:51 PM
    fighthedude
    thanks primo
  6. May 23, 2020 at 8:30 PM
    speedtre
    speedtre New Member
    Inland Northwest
    They work great....on 255/80r17s in this pic....$147 on BF sale....since they only have +4 offset they actually push the tires out about 1/2 an inch on each side as well compared to stock.
    st1V9pUSUhAqZqCpk_GQaDVgvcUuWmfx07P9YQ3h_9868d30d772687332b05748c0802b237ab94f2a7.jpg
    dinosaur, abcinv, HBTundra and 7 others like this.
  7. May 24, 2020 at 7:26 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    I have these on my '06 AC, with 265/70r17 tires. Stock suspension. No spacers needed, zero rub. They have a little better offset than stock Tundra rims, so as @speedtre said they do stick out a little farther than stock.
  8. May 24, 2020 at 7:35 AM
    fighthedude
    Thanks fellas. Both trucks look good. Speedtre truck is the panty wetter... What is your suspension set up?
  9. May 24, 2020 at 9:27 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Indeed it is. Nice tire size. I've had 255/70 and 255/75-17 on my Tundra and I believe the 75 was as tall as I could go on stock suspension.
    OP: nice wheel choice, especially in gunmetal.
  10. Dec 21, 2021 at 6:50 AM
    Corner Tundra
    Corner Tundra New Member
    Where did you get your wheels? I want to buy wheels exactly like those for my 2006 Tundra. Thanks.
    [​IMG][/QUOTE]
  11. Dec 21, 2021 at 9:51 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  12. Dec 21, 2021 at 12:45 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    What a trip ! I was wondering what those would look like on my truck, which almost a clone of yours. If/ when my stock spoke'r wheels get too far gone, I'd def. consider those . . . Looks great.
    Here's my imposter of yours.
    dinosaur and abcinv like this.
  13. Dec 21, 2021 at 2:36 PM
    Corner Tundra
    I have those same wheels on mine. I wonder what they would look like black.
  14. Aug 7, 2023 at 2:46 PM
    Tundra1986
    Tundra1986 New Member
    2003 Tundra SR5 4x4
    Purchasing wheels off of a 2023 TRD Pro 4Runner. What lug nuts should I order for 2003 AC Cab
  15. Aug 7, 2023 at 2:48 PM
    Won't work. Hub bore is different. Please read this thread. https://www.tundras.com/threads/3rd-gen-wheels-on-1st-gen.108450/
    Sorry, but unless you're coining out $$$ for some kind of hubcentric adapter, you're basically SOL. Did you research this before purchase?
  16. Aug 7, 2023 at 2:50 PM
    Tundra1986
    2003 Tundra SR5 4x4
    These won’t work on my 2003?
  17. Aug 7, 2023 at 2:57 PM
    My bad - possibly. Get a caliper and measure the center hub bore.
  18. Aug 7, 2023 at 3:00 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
  19. Aug 7, 2023 at 3:01 PM
    Tundra1986
    2003 Tundra SR5 4x4
    Now I’m worried, kind of already promised I’d buy them lol
  20. Aug 7, 2023 at 3:04 PM
    I don't know that it has, for some reason I was distracted and glossed right over the T4R in that sentence, hence my sorry ("my bad").
    As long as the hub bore is ~106 (IIRC), it should be fine. And just needs OEM lugnuts for alloy wheels to bolt on.
  21. Aug 7, 2023 at 3:07 PM
    Yup, I just confirmed, 2023-2024 4Runner Center Bore / Hub Bore: 106.1 mm
    I blame my old eyes, I read 2023 TRD PRO Turd and not 2023 TRD PRO T4R.
    Elevatorguy and FrenchToasty like this.
  22. Aug 7, 2023 at 3:48 PM
    Tundra1986
    2003 Tundra SR5 4x4
    no big deal, gonna pick them up tomorrow. Still curious what lug nuts to buy ?
  23. Aug 7, 2023 at 4:28 PM
    If you already have alloy wheels on your truck, you should have OEM 'mag seat' lug nuts already, I'd be shocked if they won't work. 2nd one in the pics, the shank centers the wheels, the flat grabs the wheel without damaging the alloy.
    3rd one in this lineup is typically for steel wheels. If you currently have OEM steelies, you'll likely have these, and they're not compatible.
    What have you currently got?
  24. Aug 7, 2023 at 4:31 PM
    PS - if you want black, which would probably look best with those wheels, should be Toyota P/N: PT076-60200-02. Scroll up to reply # 10 to see what silver/chrome nut look like.
    Be careful buying on fleaBay or scAmazon, you'll probably get knockoffs at near-OEM pricing, which is twice what you should pay.
  25. Aug 7, 2023 at 4:46 PM
    Tundra1986
    2003 Tundra SR5 4x4
    You’re a wealth of information shifty , thank you for taking the time out to help. Really looking forward to my new wheels. I’ll post pics after I get them mounted.
    shifty`[QUOTED] likes this.
