General Supercharger Thread
  1. Aug 1, 2023 at 5:41 PM
    #9781
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    What size pulley on the Whipple? Smaller pulley doesn’t really tell the whole story, as technically my 80mm is also a smaller pulley lol.
  2. Aug 1, 2023 at 5:50 PM
    #9782
    AZTundra
    Paul
    Phoenix, AZ
    Winks4x4Toy, e30cabrio and reywcms like this.
  3. Aug 1, 2023 at 5:59 PM
    #9783
    Silver17
    Eastern PA
    V10Ace likes this.
  4. Aug 1, 2023 at 6:05 PM
    #9784
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I'm just hoping that's the problem.. going to install the relay on Sunday. Wideband still acts delayed in its new location.. I'll fight that battle after the fuel pressure gets sorted out and may just need a "reset" procedure as noted previously
    Silver17[QUOTED] likes this.
  5. Aug 1, 2023 at 6:26 PM
    #9785
    Silver17
    Eastern PA
    So the problems started when you did headers and the 75mm at the same time? If so I’d be curious if it still has problems after swapping the 80 back on with the headers. May indicate if there’s more going on there, I forget your exact symptoms with your issues though. Don’t mind me, just pondering things lol.
    V10Ace[QUOTED] likes this.
  6. Aug 1, 2023 at 6:30 PM
    #9786
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Correct. Base pressure is good currently at idle but when I drive around and get into boost, fuel pressure drops rather than increases. I didnt have this problem prior to pulley/headers.
    Chris told me to either put the 80mm back on or install the relay. I dont daily my truck anymore and im too busy until the weekend to mess with it unfortunately.
  7. Aug 1, 2023 at 7:07 PM
    #9787
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The question is what boost pressure? Our pullies aren’t the same size as the others. We’re one step down from what comes stock. I saw a spike of 9.5 then settled to 8.3 the other morning. Pops sees 7.5-7.8 I think at his altitude and heat.
    Silver17[QUOTED] and HulkSmurf14 like this.
  8. Aug 1, 2023 at 7:10 PM
    #9788
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Could it be a collapsing fuel line?
    reywcms likes this.
  9. Aug 1, 2023 at 7:15 PM
    #9789
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Possibly.. I ran into that issue on the second tank drop. Hoping it's just a damn relay this time :rofl:
    HulkSmurf14[QUOTED] likes this.
  10. Aug 1, 2023 at 7:18 PM
    #9790
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I saw 10.8 psi on the way home after headers/pulley. I had to hear the headers despite leaning out :D
  11. Aug 2, 2023 at 3:20 AM
    #9791
    Silver17
    Eastern PA
    I think boost pressure is actually not a great way to differentiate airflow with pulleys. There is too many variables between intake and exhaust setups, elevation and temperature. It’s easiest to just figure it out mathematically. An 80mm pulley on a 2650 is 5,133cc/1 engine revolution. A 3.5” pulley on a 2900 is 5,054cc/1 engine revolution. A 75mm pulley on a 2650 is 5,479cc/1 engine rev. That’s a crapload more intake air.
  12. Aug 2, 2023 at 5:54 AM
    #9792
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’m curious to know the difference in form’s from the years. If he goes back one pulley size they’re saying it’ll fix the situation. To me that’s a band aid fix avoiding the real problem?
    Mdl and V10Ace like this.
  13. Aug 2, 2023 at 6:25 AM
    #9793
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Chris mentioned in his email that anything beyond the base pulley (85mm), they recommend relaying the pump. I went straight to the 80mm from the beginning and was never told about the pump module issue. Id say ive been on a band aid.
    Mdl, reywcms[QUOTED] and HulkSmurf14 like this.
  14. Aug 2, 2023 at 6:41 AM
    #9794
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Dang, yall are scaring me. Part of the appeal of this truck is the rock solid reliability.
    If I were to:
    • Harrop Engineering TVS2650 supercharger system
    • OEM Lexus RC F 84mm throttle body
    • Prospeed Autosports 4.50" air-intake system
    • ZPE GripTec 80mm supercharger pulley
    • DeatschWerks 650cc/min fuel injectors
    • Harrop Engineering high-flow fuel pump
    • NGK LFR6AIX-11 spark plugs
    • Genuine OEM Toyota coolant
    • Custom Calibration via HP Tuners or VF Tuner
    • Long tube headers
    How much of a reliability hit would I take? I'm not talking about longevity. Just talking about tweaking/fixing/constantly monitoring and watching for issues?
    So far the ones I know of from reading in here are:
    Catalytic converters blown
    Fuel pump not providing enough fuel
    Winks4x4Toy and V10Ace like this.
  15. Aug 2, 2023 at 6:43 AM
    #9795
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Edit: I was wrong and you should be good to go. Catalytic converters are something to watch out for!
    Mdl, HulkSmurf14 and 1UP[QUOTED] like this.
  16. Aug 2, 2023 at 6:51 AM
    #9796
    snivilous
    SW UT
    300k+ Supercharged 2008
    Depends who you ask and if your truck wants to play ball. My truck has been extremely reliable :D
    Mdl, e30cabrio, reywcms and 1 other person like this.
  17. Aug 2, 2023 at 6:53 AM
    #9797
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my 80mm on stock intake did not lean out on dyno
    I have the harrop supplied fuel
    Pump
    Mdl likes this.
  18. Aug 2, 2023 at 6:54 AM
    #9798
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    For whatever its worth, mine's always been drivable without any hiccups.. I just dont have all the sauce
  19. Aug 2, 2023 at 6:55 AM
    #9799
    nobodyintexas
    nobodyintexas What?
    South of Houston
    we are simpatico
  20. Aug 2, 2023 at 6:55 AM
    #9800
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Whats your afr's at WOT? I believe it was @snivilous that showed tables
  21. Aug 2, 2023 at 6:58 AM
    #9801
    HulkSmurf14
    2014 Tundra Limited
    Maggy FTW!!
    snivilous[OP] likes this.
  22. Aug 2, 2023 at 7:18 AM
    #9802
    snivilous
    SW UT
    @ZPhilip was the datalog where it was running out of injector, and I believe he has the 85mm pulley? I can't find where he says what size pulley he had, but on stock injectors he was maxing out duty cycle by 4800rpm.
    e30cabrio likes this.
  23. Aug 2, 2023 at 7:23 AM
    #9803
    nobodyintexas
    nobodyintexas What?
    South of Houston
    hi 10’s. On my recent dyno tuning
    I don’t do WOT in real life
    maf was maxed. 650 Injectors at 90%
  24. Aug 2, 2023 at 7:24 AM
    #9804
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’d avoid the prospeed intake and do the maggy box.
  25. Aug 2, 2023 at 7:25 AM
    #9805
    snivilous
    SW UT
    Maybe controversial opinion but I'd avoid anything prospeed :rofl:
  26. Aug 2, 2023 at 7:31 AM
    #9806
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    At this point my opinion would be to buy a 10 spd F150 and put a Whipple on it and call it a day
  27. Aug 2, 2023 at 7:35 AM
    #9807
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL agreed. Even though their billet motor mounts looks sick. Unless you wanna make one that I’ll buy lol
    ViktorG likes this.
  28. Aug 2, 2023 at 7:41 AM
    #9808
    snivilous
    SW UT
    Just tell me when, but considering there's lots of motor mount options out there that seems like a waste of time :D I prefer to make parts other people won't make :p
    reywcms[QUOTED] likes this.
  29. Aug 2, 2023 at 8:17 AM
    #9809
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ditto.
    if I had to buy another truck soon.....
  30. Aug 2, 2023 at 8:19 AM
    #9810
    Silver17
    Eastern PA
    This is incorrect, you must be thinking of the stock injectors (the Harrop kit doesn’t include injectors). The included pump is plenty up to the task even with the 80mm. Prospeed will tell you otherwise though and sell you a lot of BS you don’t need.
