  1. Jul 28, 2023 at 7:20 AM
    Did you pay someone to do it? Dropping the tank sounds like a pain.
    One time mine acted up was after a trip to the mountains where I was on a really rough road. I thumped it with a mallet and it didn't do it again for about a year. My truck hates it if I short stroke the starter. I have to let the truck sit for a minute before trying again. It will roll over but seems really angry with me. I apologize to her and move on.
    bmf4069 and oscardog86 like this.
  2. Jul 28, 2023 at 7:22 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Mod Meet?
    bmf4069 and txagg[QUOTED] like this.
  3. Jul 28, 2023 at 7:22 AM
    It looks better than my truck when I didn’t have holes that rusted through. That bed liner wore down the paint on the raised section much worse than yours.
    txagg[QUOTED] likes this.
  4. Jul 28, 2023 at 7:25 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i thought the 1gt has to drop the tank, as the pump is under the cab?
  5. Jul 28, 2023 at 7:26 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    If that's the case, screw it. I'll pull the cab as well.
  6. Jul 28, 2023 at 7:27 AM
    Maybe we can get @Tundra2 to post a pic of when he had his bed off but I'm pretty sure the fuel pump is accessible with the bed removed. People have posted pictures in the past.
    PHM dropped his tank but said it required hand yoga.
    w666 and TX-TRD1stGEN like this.
  7. Jul 28, 2023 at 7:33 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Ok, i was wrong. Seems to be accessible, but looks tight.
    & my post about the ranger showed up on the google.
    metalpete, txagg and Jack McCarthy like this.
  8. Jul 28, 2023 at 7:36 AM
    Gotta love the design where water between the bed and cab is meant to puddle around the opening of the gas tank cover that hides the fuel pump.
  9. Jul 28, 2023 at 7:56 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Yep. Gasoline is one thing I hate dealing with. Dropping the tank is a pain, always thought it would be easier to take the bed off.
    I think it was $250 to get it done? Not including parts, but all I bought was the motor, pump filter, and tank gasket; which wasn't too much $$ either.
  10. Jul 28, 2023 at 8:04 AM
    Pro tip: After you hit those seams with a deck brush to get the crap out the corners, hit it with some spray-on, qipe off hybrid wax. Assuming you weren't gonna already. I love this stuff:
  11. Jul 28, 2023 at 8:11 AM
    Location of pump-to-cab varies based on year and cab type IIRC.
    And I dunno, someone on here got onto me when I said "pull the bed", he dropped the tank, said it was only two straps and took 15 minutes. Easier to do when the tank is <1/4 full, though that's not always an option. Have a short span of 2x (2x12 ideal) that's a foot long or so with a jack helps a lot.
    txagg and metalpete like this.
  12. Jul 28, 2023 at 8:25 AM
    metalpete
    ID
    It's probably easier than it looks. I always thought the real PITA was disconnecting everything before dropping the tank. Not a lot of room in there.
  13. Jul 28, 2023 at 8:27 AM
    The filler hose is supposedly the real bitch on the 1GT. And unfortunately, if it doesn't remain sealed ... EVAP CODES! Yay!
    And there was that TSB for leaky/cracked/defective filler necks for some years too, I think '03-'04?
    metalpete[QUOTED] likes this.
  14. Jul 28, 2023 at 8:55 AM
    I remember someone saying there is an electrical connector you can't see but have to unclip blind. Hence the hand yoga.
    oscardog86 and shifty`[QUOTED] like this.
  15. Jul 28, 2023 at 8:57 AM
    You and I are probably the only ones anal enough to wax our beds. :anonymous:
    I'll admit I've done it and it only took 20 minutes once I had the bed clean.
  16. Jul 28, 2023 at 9:45 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    RCLB can be accessed by removing the bed, AC not so much. The access panel to the pump is indeed under the cab.
  17. Jul 28, 2023 at 9:54 AM
    w666
    Maryland
    I dropped the tank on my AC. Well, not intentionally...one of the tank straps rusted and the tank almost left the chat on its own. When I got new straps I discovered that the tank had numerous rust holes leaking small amounts of fuel. Ever since I got my truck I had been smelling fumes, and throwing the occasional evap code. Once I had a new non-leaking tank (Dorman), no more fumes, and no more codes! I replaced the fuel pump while the tank was out because it would have been irresponsible not to. The filler pipe, and vent pipe are easily disconnected at the tank rather that the filler neck. The fuel lines require a special too to disconnect. Hand yoga is definitely required, but if you're lucky enough to have your tank drop out there's a lot more room to see.
    This was the moment that inspired me to carry a fire extinguisher in my truck...
    shifty` and oscardog86 like this.
  18. Jul 28, 2023 at 9:55 AM
    @Aerindel
  19. Jul 28, 2023 at 10:00 AM
    No doubt, and as long as you're not waxing your anal, I think we can hang out and have beers any time. :rimshot:
  20. Jul 28, 2023 at 10:04 AM
    w666
    Maryland
    Anal beds?
  21. Jul 28, 2023 at 10:06 AM
    You can't remove the pump with the bed off or it's just really tight?
  22. Jul 28, 2023 at 10:09 AM
    w666
    Maryland
    Cannot.
    Although, here a video that claims you can!
    Your mileage may vary...
    FirstGenVol[QUOTED] and Aerindel like this.
  23. Jul 28, 2023 at 12:07 PM
    Aerindel
    Aerindel New Member
    Montana
    I dropped the tank on mine. It was pretty easy. There is a lot of slack in the electrical connector, enough that you can lower it almost to the ground without tugging on it, so don't bother with unclipping it blind, just bring it down on a jack, with that a-for mentioned 2x12 under it.
    Where I got in trouble, was putting it back.
    To take it off, you can just tap out some pins and it's no problem. But to but it back, you have to loosen two bolts. Put the tank back, re-pin the straps, and then tighten the bolts to tension those straps. If you can't loosen them, you can never get the pins back in.
    Problem was, one of my bolts was seized and broke off. That was a pain.
  24. Jul 28, 2023 at 12:10 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    FYI: loosen the two bolts first, its easier to pull the pins.
    Bonus: you'll know if one is fubar before you get too far.
    Aerindel and txagg like this.
  25. Jul 28, 2023 at 4:18 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Of course the rust comes up from the underneath, so...
    both pic, the top is tailgate end of the bed. Way more rust under than shows from the bed.
    I now 'clean' under the new bed by keeping it coated in Fluid Film &/or Woolwax.
    bmf4069, bob1008, txagg and 1 other person like this.
  26. Jul 28, 2023 at 5:24 PM
    Galladanb
    Galladanb New Member
    Southeastern Tennessee
    2002 AC Sr5
    So, this will prolly get lost in the vastness of you all, but…
    Weighed ours today, empty weight (with me, wifey and the pup) under 5100 lbs…
    Is that normal or unusual?
    Also topped off the gas bucket today, had way under the last mark on the gauge, but it still took over 19 gallons to fill it…
    Does it have a 21 gallon tank? Hollie Mollie…!!!
    bmf4069, JasonC., FirstGenVol and 2 others like this.
  27. Jul 28, 2023 at 5:50 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I was at a fund raiser for less fortunate kids and snapped a pic of this Tundra
    The bed light is kinda cool....
  28. Jul 28, 2023 at 5:52 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    My 2wd was 4700lbs with a full tank iirc.
    Tank is actually 26 gallons iirc. Light comes on around 20 for me.
    KNABORES and metalpete like this.
  29. Jul 28, 2023 at 6:08 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Why? Just why? That poor truck. :(
    oscardog86, bmf4069, Mr.bee and 5 others like this.
  30. Jul 28, 2023 at 6:17 PM
    abcinv
    Tommy
    NW Georgia
    I asked the same question...
    Is this not how it should look (maybe without the nerfs)NFab 3 11-6-22.jpg ?
    ktundra, bmf4069, Galladanb and 5 others like this.
