Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Jul 27, 2023 at 8:38 AM
    #511
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
    Gear oil I believe?
    reywcms[QUOTED] likes this.
  2. Jul 27, 2023 at 8:39 AM
    #512
    EmergencyMaximum
    EmergencyMaximum New Member
    Gang, it's not like transmission with lifetime fluid. Manual says 5k for regular engine oil or 10k for synthetic. This sounds like a joke more so than a serious reply.
    I've heard of people never changing engine oil, but that can't be very good for everything inside the engine.
    Mixing oil should be totally fine, even different brands, given they're all API certified.
  3. Jul 27, 2023 at 9:54 AM
    #513
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Mine came with oil already in it.
    Good enough for me.
  4. Jul 27, 2023 at 9:55 AM
    #514
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    LOL
    hagrid[QUOTED] likes this.
  5. Jul 27, 2023 at 10:19 AM
    #515
    PasqueFlower
    PasqueFlower New Member
    2022 Tundra SR5 double cab 6.5ft bed, tow package, rear air suspension
    Walmart July, 2023 5 qts of Mobile 1 "Extended Performance" $29.
  6. Jul 27, 2023 at 10:49 AM
    #516
    EmergencyMaximum
  7. Jul 27, 2023 at 11:46 AM
    #517
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    That's about what it cost me!
    Sierradevil and Leo's first like this.
  8. Jul 27, 2023 at 12:19 PM
    #518
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    So you all change oil, but you leave the same engine in there? Every time? I have better piece of mind with a fresh engine every 5k. Some go 10k between engines. But The Car Care Nut said that’s not a good idea, so new engine every 5k for me.
    Hbjeff, St2946, hagrid and 5 others like this.
  9. Jul 27, 2023 at 12:29 PM
    #519
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    no that crap is for domestics, you bought a refined vehicle
    Cpl_Punishment and Leo's first like this.
  10. Jul 27, 2023 at 12:40 PM
    #520
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    God I love oil threads.
  11. Jul 27, 2023 at 12:49 PM
    #521
    EmergencyMaximum
    These and transmission cooler threads?:101010:
  12. Jul 27, 2023 at 12:54 PM
    #522
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Oh man I haven't seen a good confused male cooler thread in a minute
  13. Jul 27, 2023 at 12:57 PM
    #523
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    For me, it's oil threads and then "premium" fuel threads/conversations are a close second.
    The trans cooler topic is relatively new and I don't follow it. Maybe I'll start watching at some point. I hear it's pretty good.
    But oil? Oil is timeless.
  14. Jul 27, 2023 at 1:27 PM
    #524
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Engine oil engine oil, which one should it be?
    Engine oil engine oil, it must be 5w3.
    It slips and it slides when it’s hot outside a thicker vis-cos-ity.
    0w-20, so good when it’s freezing.
    0w-20, to keep that *%*% from seizing.
    What you choose likely doesn’t matter one iota.
    When SHTF, just remember, it’s a Toyota….
    Mike59, hagrid, AZBoatHauler and 5 others like this.
  15. Jul 27, 2023 at 1:31 PM
    #525
    Terndrerrr
    Music City
    6UR-FE
    Yeah but which oil is best for payload?
  16. Jul 27, 2023 at 1:38 PM
    #526
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    50w100
    Cpl_Punishment likes this.
  17. Jul 27, 2023 at 1:42 PM
    #527
    Terndrerrr
    Music City
    6UR-FE
    I was thinking more like 0w0.5. Gotta save it for my 5th wheel hitch weight :cool:
  18. Jul 27, 2023 at 3:17 PM
    #528
    Retroboy1989
    Northern Utah
    What's the biggest oil I can run on stock suspension without rubbing?
  19. Jul 27, 2023 at 3:22 PM
    #529
    Retroboy1989
    Northern Utah
    I've noticed the transmission loves to keep the revs down in this truck. Tow haul and S4 for me.
    This line in the owners manual was the reason for my 5w30 switch:
    The 20 in 0W-20 indicates the viscosity characteristic of the oil when the oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
  20. Jul 27, 2023 at 4:12 PM
    #530
    CTundraForMe
    CTundraForMe New Member
    I use 5W-30 here in southern AZ where it's regularly over 100 ambient, regularly well over 100, during the summer.
    TundraTed likes this.
  21. Jul 27, 2023 at 4:18 PM
    #531
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Interesting, my 2021 manual states the same thing. “Extreme load conditions” is fairly ambiguous, I wonder if Toyota has anything written down elaborating on what the manufacturer would consider “extreme”.
  22. Jul 27, 2023 at 4:25 PM
    #532
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll betcha a supercharger qualifies as extreme load. Hence 5w-30
  23. Jul 27, 2023 at 4:27 PM
    #533
    EmergencyMaximum
    Yours is 2020 model. Do you have transmission cooler added? I'm sure it has to work a lot harder vs NA engine, hence higher temps of the fluid.
  24. Jul 27, 2023 at 4:28 PM
    #534
    Tbrandt
    Tristan
    Kansas City
    I wouldn’t hesitate to agree with you there.
  25. Jul 27, 2023 at 4:31 PM
    #535
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I added the trans cooler
    Leo's first likes this.
  26. Jul 27, 2023 at 7:09 PM
    #536
    PKFan
    2018 Inferno! DC SR5 4x4
    I'd rather not.:puke:
    Cpl_Punishment and hagrid like this.
  27. Jul 28, 2023 at 12:15 PM
    #537
    Bammer
    Monroe, CT
  28. Jul 28, 2023 at 12:24 PM
    #538
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It’s complicated. It thinks it has a thermostat, however, it’s bypassed.
    sooooo….. I don’t want to come across as intolerant.
    Retroboy1989, Hbjeff and Leo's first like this.
  29. Jul 29, 2023 at 6:45 AM
    #539
    Retroboy1989
    Northern Utah
    I'm considering pulling a 7000# trailer over mountain passes with a truck rated for 9800# extreme.
  30. Jul 29, 2023 at 2:32 PM
    #540
    ShawnTRD
    ShawnTRD New Member
    Shawn
    I'll just use 0W-50. That should cover everything.
    hagrid and AZBoatHauler like this.
