Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Jul 26, 2023 at 5:38 AM
    #481
    EmergencyMaximum
    EmergencyMaximum New Member
    Literally I'm sure. Dystopian cyberpunk future is here.
    Oil viscosity matters more or less for fuel economy; although probably not much. I've read somewhere 0w-20 was causing premature(relatively speaking?) timing chain/sprocket wear due to how wet and runny it is?
  2. Jul 26, 2023 at 10:28 AM
    #482
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Because it's not actually one of the approved oils by Toyota. I'm sure it will work just fine though. Personally i run 5w30 in the winter and 15w40 in the summer.
    CaptRussia253 likes this.
  3. Jul 26, 2023 at 11:45 AM
    #483
    AZBoatHauler
    So.Arizona
    I believe, generally speaking, 5w will have better film strength / retention properties that 0w. The startup noise people have running 0w tells me there is less lubrication in the top end during startup with 0w.
    Terndrerrr and reywcms like this.
  4. Jul 26, 2023 at 12:12 PM
    #484
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    The first number indicates how it flows at cold startup. 0w flows better at colder temps than a higher number (5w, 10w). This number is basically irrelevant in summer/warm weather. It matters when it's cold. I don't want my oil flowing like molasses at startup. I have long, cold winters, so I use 0w.
    The second number is the oil weight/viscosity at operating temps/hot.
    I'm not sure how much of a difference there is in viscosity and ability to lubricate at operating temps between 20 weight and 30 weight.
    People say 30 weight quiets the engine. That tells me the oil is a little thicker at operating temps and sticking to everything a little better. But in my mind, having the oil stick to the outside of the components and mufflling noise doesn't necessarily make me feel better or translate to better lubrication where it's needed most. I want to know that the oil is flowing at the right rate and making in-between the moving parts. I'm not really concerned with engine noise.
    That said, it's really splitting hairs. 30 weight would probably be better in really hot climates with long summers. If it gets and stays hot enough, I imagine it flows like a 20 weight.
    It's been a hot summer here and if my truck wasn't in the shop, I was going to switch to a 30 weight for the summer and then back to 0w20 for winter.
    But, by the time I get it back, the worst of summer will likely be over. So I'll stick with 0w20. Maybe next summer I'll try the 30.
    Js18tundra likes this.
  5. Jul 26, 2023 at 12:55 PM
    #485
    EmergencyMaximum
    What's the obsession with 'quiet' engine, gang?:boink:
    RichterScale likes this.
  6. Jul 26, 2023 at 1:10 PM
    #486
    AZBoatHauler
    So.Arizona
    Some people like their $50k truck with a $10k engine to run smooth and not sound like it has marbles under the valve covers. The clattering valve noise is metal smacking metal. A heavier oil fills those gaps acting as a cushion making it quieter. People that have taken apart and understand motors are usually the ones that hate the noise.
    Some people don’t care.
    coTony, Mike59, 2mchfun and 2 others like this.
  7. Jul 26, 2023 at 1:51 PM
    #487
    EmergencyMaximum
    Well, if it reaches metal to metal, then I doubt a film of oil is going to do a lot to stop it. If clearance is 0.00000, then oil or no oil, you'll have contact.
    My truck doesn't make any of those noises. Perhaps a borken 50k truck needs service tune up instead of heavier oil?
  8. Jul 26, 2023 at 1:59 PM
    #488
    AZBoatHauler
    So.Arizona
    I’d love to hear how the cam is supposed to open the valve without metal touching metal.
    Mike59, 2mchfun, 17inferno and 2 others like this.
  9. Jul 26, 2023 at 2:04 PM
    #489
    EmergencyMaximum
    Ok, perhaps I was thinking of something else. I thought some parts were bottoming out, hence the clunking noise. Thank you for clarification.
  10. Jul 26, 2023 at 2:07 PM
    #490
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was thinking about a 0W-30 after my powertrain warranty expires if I can find it in full synthetic.
    Leo's first likes this.
  11. Jul 26, 2023 at 2:34 PM
    #491
    Quattroa4m
    Quattroa4m New Member
    This engine was approved to run several different viscosities of oil. When Toyota narrowed down the approved range of oils (in the USA) to just 0W20, the engine didn't change.
    Some manufacturers have only ever approved one viscosity of oil and that's were the difference lies.
  12. Jul 26, 2023 at 3:05 PM
    #492
    ShawnTRD
    ShawnTRD New Member
    Shawn
  13. Jul 26, 2023 at 3:12 PM
    #493
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Are we talking about a Ford Model T? Any reasonable viscosity of oil will be pumped through by the crankshaft-driven mechanical oil pump.
    2mchfun and AZBoatHauler like this.
  14. Jul 26, 2023 at 3:31 PM
    #494
    AZBoatHauler
    So.Arizona
    The clarity of the empty jar is my argument against 0w. Pouring water.
  15. Jul 26, 2023 at 3:34 PM
    #495
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    to test ive run 5w-20 the last 2 oil changes.
    i dont need the 0w for any season, and the 5w-20 is as quiet as I’ve experienced with the 5w-30 in the past. For climates like mine where the coldest start i will ever see is maybe 45 in the winter, but averaging 60-80 for the year, there is zero value in 0w oil, only downside in clackity clack
  16. Jul 26, 2023 at 3:49 PM
    #496
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    They are both 20 weight at operating temp. There is absolutely no difference. The only difference is that 0w will flow a little easier in really cold temps than 5w. Since the 0w flows easier at lower temps, it would be lubricating faster after startup and quieting the engine faster.
    But since you don't experience any temps lower than 40-45, there is absolutely no difference between 0/20 and 5/20 at that temp at startup or operating temps.
  17. Jul 26, 2023 at 4:12 PM
    #497
    AZBoatHauler
    So.Arizona
    I’d bet his engine is 80* or colder on morning start so how is it 0w vs 5w makes no difference? You act like 95* is operating temp. The second number is the viscosity at 212*F - that’s a lot hotter than startup temp. The first number applies to viscosity at start up - even in Southern California.
  18. Jul 26, 2023 at 4:13 PM
    #498
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Either this doesn't make any sense, or I'm misunderstanding what you're saying.
    It's talking about how the oil flows in cold temps, when you start your vehicle.
    Have you ever started a vehicle that's been sitting in sub zero temps all night? You want the oil to move like sludge and not lubricate anything for the first 10 min until it warms up?
    You keep referencing "water". Well, yeah, that's the point. You want it to flow like water at start up, not like molasses. Btw, all oil flows like water at operating temp, when it's hot. If you're in AZ then you don't have to worry about start up at freezing temps.
    20 weight oil leaves a film like all the others. It doesn't run completely off like water and leave the parts dry.
    There's nothing wrong with running 30 weight. That's not my argument. But the comments about 0w20 being like "water", implying that it doesn't lubricate as well etc, tells me that folks aren't understanding the designations and how this multigrade lubrication thing works. The reasons I'm hearing for why people won't use 20 weight just don't make any sense. Conversely, the reasons I'm hearing for why anyone would run 40 weight in the north east don't make any sense either. Unless you're being funny. I can't tell.
    Cpl_Punishment and Js18tundra like this.
  19. Jul 26, 2023 at 4:15 PM
    #499
    AZBoatHauler
    So.Arizona
    I like oil to stick around where it’s supposed to be doing its job - see the nice dark colored coating on the 5w-30 jar? It is thin enough to move but not completely runoff a surface.
    2mchfun likes this.
  20. Jul 26, 2023 at 5:45 PM
    #500
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    get the GF6 5w-30, GF6 flow better in startup
    Hbjeff likes this.
  21. Jul 26, 2023 at 6:52 PM
    #501
    Joe333x
    Joe333x Member
    Boston
    I know the oils in which it is approved to run, thats why included the screen shot with all the oils Toyota has approved for use in my post.
    Im not concerned that 0w20 doesn't lubricate well, its that it so thin that its much more likely to cause blow by and end up being burned by the engine which once your engine starts buring oil it wont stop. My previous vehicle, a 2014 Subaru called for 0w20 and by 60,000 miles it was burning a quart of oil every 3-5k miles. 0w20 only exists to improve CAFE standards by marginally increasing MPGs. Find me a snowblower that calls for 0w20 and those things literally only start in the cold and almost all take 5w30. Now maybe if you live in Alaska with constant below 0 temps then I would use 0w20 but in normal continental US winters 5w30 is fine.
    2mchfun and nobodyintexas like this.
  22. Jul 26, 2023 at 8:33 PM
    #502
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    the valvetrain sounds completely different, i have no data to back it up, but its not the same
  23. Jul 26, 2023 at 9:16 PM
    #503
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    A 5w-20 will still drain into the oil pan over night… having a 0w-20 will allow the engine to suck the oil out of the sump faster to lubricate parts faster…but as previously stated, unless you are seeing cold temps the difference is negligible.
  24. Jul 27, 2023 at 6:13 AM
    #504
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I run Mobil1 15w-50 synthetic in everything I own... 5.7 Tundra, 4.0 4Runner and 496 big block powered boat.
    It never gets very cold here in GA but it gets plenty hot for much of the year.
    nobodyintexas likes this.
  25. Jul 27, 2023 at 6:25 AM
    #505
    Quattroa4m
  26. Jul 27, 2023 at 6:26 AM
    #506
    Chip_Tundra
    Chip_Tundra New Member
    I made the mistake of pouring 5 qt of 0w20 and 3.5 qt of 5w30 on my last oil change. Lol
    Did a round trip from Vegas to Phoenix. 600ish miles worry free.
  27. Jul 27, 2023 at 6:57 AM
    #507
    Retroboy1989
    Northern Utah
    If 0w30 was more mainstream and available, I'd run that. Best of both worlds.
    I run 5w30 primarily for towing in the summer. Hours on the highway at 3,000rpm.
  28. Jul 27, 2023 at 7:26 AM
    #508
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
    I had two quarts of 0W-20 leftover from the previous oil change so I mixed it with 5W-20. I went on an 800 mile round trip good to go.
  29. Jul 27, 2023 at 7:45 AM
    #509
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    We're supposed to put oil in these?
  30. Jul 27, 2023 at 7:57 AM
    #510
    sd172
    sd172 New Member
    South Dakota
    This is a relatively easy operating mode for the engine - high rpm, correspondingly excellent cooling and oil pressure, significantly lower tendency for knock. Much better than lugging the engine at 1200ish that transmission seems to like in town.
