  1. Jul 25, 2023 at 9:15 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Should I just bite the bullet and get the 5160s now, then?
    BlueRibbon4x4 and SAGE63 like this.
  2. Jul 25, 2023 at 9:17 AM
    I would if it's in your budget. November is the expected date but you know how that goes....it can always change.
  3. Jul 25, 2023 at 9:53 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Definitely
    RobertD likes this.
  4. Jul 25, 2023 at 11:08 AM
    KILLINTIME
    KILLINTIME Like a Villain
    Pauline which is in Spartanburg county.
  5. Jul 25, 2023 at 11:16 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Just for reference I am exceeding payload with my 4700lb dry, 6k loaded, Jayco 264BH by 6-700lbs. I would guess a 9000lb trailer and all the passengers is exceeding the trucks payload capacity by 1200+ lbs. and exceeding the rating of the rear axle. The frame may even be sitting on the bump stops with that much weight.
    Tundra's have some of the lowest payload capacities and is the limiting factor when towing.
    Tony_h and 1UP[QUOTED] like this.
  6. Jul 25, 2023 at 11:42 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yeah, I am not a fan of their top plate... it's just a row of circles and adds no real aesthetics to the design. Although I understand the function of the design, I really dislike the look
    BreyTundy[QUOTED] likes this.
  7. Jul 25, 2023 at 12:36 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
    If my reminders is off would the maintenance thing still show when it's due or almost due. 2018 tundra I turned the button to on even tho I have not set reminders. Does that matter ?
  8. Jul 25, 2023 at 2:56 PM
    SAGE63
    San Diego County
    Go with the 5160's
    ATV25 and CaptRussia253 like this.
  9. Jul 25, 2023 at 3:43 PM
    drpheta
    drpheta New Member
    I went with the 5160s.
    Thanks for the push, guys!
  10. Jul 25, 2023 at 3:58 PM
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    These caliper bracket bolts appear to be unobtanium. Dealer can have some in a day or two but SOL otherwise. Also they're apparently 14mm-1.5p if you're curious. I did manage to find a correctly sized tap at a local NAPA so I can clean up the threads in the caliper.
    reywcms likes this.
  11. Jul 25, 2023 at 5:23 PM
    TundraAF
    TundraAF New Member
    Cnote
    21 tundra crewmax TRD off-road
    I absolutely boned my rear quarter panel. Truck vs birch tree…
  12. Jul 25, 2023 at 5:34 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Can you crawl up under and pop that out?
  13. Jul 25, 2023 at 5:53 PM
    TundraAF
    TundraAF New Member
    Cnote
    My neighbour pulls dents for a living and is going to take a look. Best place to pop it out is from behind the tail light and remove the plastic trim from the bed rail. He thinks it’ll come out.
    got to replace the tail light assembly, anything better than stock out there? I’m not a fan of the Morimoto LED but wouldn’t mind looking at something interesting
  14. Jul 25, 2023 at 6:01 PM
    1UP
    1UP Truck Gang
    https://www.alpharexusa.com/product/14-21-toyota-tundra-luxx-series-led-tail-lights-alpha-black/
    I run an earlier version of these. Love em.
  15. Jul 25, 2023 at 6:06 PM
    RobertD
    Robert
    DFW, Texas
    Alpha Rex or the HiRev would be good options since you need a new assembly. I'm running HotTails and love them but that is just a bulb and wiring change.
    https://www.tundras.com/threads/hirev-sports-hrs-led-taillights-review-with-pictures.82698/
  16. Jul 25, 2023 at 6:42 PM
    Wahayes
    Will
    2017 tundra limited
    Definitely wasn't on the bumpstops once. I have a dobinsons suspension with upgraded springs. I only had my wife and 2 corgis soft kennels and a bag because I knew I couldn't load the truck much due to payload. That trailer weight was 100lbs less than my towing capacity and my payload on my truck is 1500 or so with my configuration (limited dc 4x4 6.5) after tounge weight is considered and my cap I may have been close but shouldn't have been over. Most all our gear I made my daughter put in her car along with her and the other 3 people that went. Sure was a heavy bitch though
  17. Jul 25, 2023 at 9:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  18. Jul 25, 2023 at 9:20 PM
    RobertD
    Robert
    DFW, Texas
    Throttle controller?
  19. Jul 25, 2023 at 9:42 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah and I got a splitter too
  20. Jul 26, 2023 at 12:07 AM
    DacianDesignLLC
    DacianDesignLLC New Member
    2021 Tundra
  21. Jul 26, 2023 at 1:52 AM
    That splitter works very well with my SG3. Just don't forget to set the app to No OBD mode.
    bulldog93 and texasrho83[QUOTED] like this.
  22. Jul 26, 2023 at 4:26 AM
    TundraAF
    TundraAF New Member
    Cnote
    fixed… not even a scratch after I hit it for about 10 seconds with a buffer. On the body line that comes up at the rear of the fender flare there are two little imperfections. Neighbour worked that area for a long time but at the end of the day couldn’t get it perfect. Pretty damn close though. I’m pretty particular but even I was impressed with the before and after.
  23. Jul 26, 2023 at 5:07 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Can you see inside the square tube to see if they powder coated in there too? The open holes look like a future water intrusion and rot point.
  24. Jul 26, 2023 at 5:07 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Wow! That's impressive. Nicely done.
    rockR67 likes this.
  25. Jul 26, 2023 at 5:11 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I plan to hook my radio up to it.
  26. Jul 26, 2023 at 5:22 AM
    I keep forgetting that yours is a 2016. Mine doesn't use the OBD adapter since it gets the info through the Maestro data cable.
  27. Jul 26, 2023 at 5:49 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Check out McMaster-Carr, they carry lots of sizes and you can usually have them next day with standard shipping depending on your location.
    https://www.mcmaster.com/products/screws/thread-size~m14/thread-pitch~1-5-mm/
  28. Jul 26, 2023 at 5:51 AM
    drpheta
    drpheta New Member
    These PDR guys are artists. Sometimes there's nothing you can do when a crease is involved, but your neighbor did a fantastic job here.
    Tundra234 likes this.
  29. Jul 26, 2023 at 5:54 AM
    bfunke
    bfunke Tundra Curmudgeon
    @MattAK - use a thread chaser rather than a tap to clean up existing threads. M14-1.5 is a common size readily available.
  30. Jul 26, 2023 at 6:31 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wanna say I have a data cable hooked up to my Maestro as well.... shouldn't need to use OBD. I'll check that theory when the Banks comes in
    bulldog93 likes this.
