2023 SR5 TRD OR tire recommendations
Discussion in '3rd Gen Tundras (2022+)' started by Black widow TRD, Apr 18, 2023.
  1. Apr 18, 2023 at 8:46 AM
    Black widow TRD
    Black widow TRD [OP] New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Evening gents, want to get some larger tires on my rig hoping y’all can steer me in the right directing.
    I’ll be keeping my stock 18 TRD OR wheels just like to go bigger. Want to keep the stock OR suspension, really like how it rides. Would like a small poke but not looks for that cuhhh look. Was thinking Mickey Thompsons or some Nitto grapplers or some Toyos.
    I appreciate your suggestions gents.
    22whatwedo likes this.
  2. Apr 18, 2023 at 9:49 AM
    VolksDragon
    VolksDragon New Member
    Here you go sir, hours of reading and excellent photos on all kinds of different options. LINK
    Most 33" and 34" tires will fit with zero mods, you just get to decide what kind of driving you'll be doing and how durable / heavy / aggressive you want to go. Virtually ALL the aggressive A/T tires will come with an MPG and performance hit depending on size and weight.
    Black widow TRD[OP] likes this.
  3. Apr 18, 2023 at 10:20 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I have the same wheels and also would like slightly bigger tires. 265/70-18 has an overall diameter of 32.6" so I would like to get 285/65-18 which is also 32.6" diameter. But, unfortunately, almost all of these are more aggressive AT type tread instead of the road oriented tread I prefer. Tire Rack has a Michelin LTX M&S with road oriented tread in this size, which would be exactly what I would want, except it only comes only in Load range E version. Their standard LTX M&S doesn't seem to come in this size. If it did, I'd have got them already. :-(
  4. Apr 19, 2023 at 1:02 PM
    Black widow TRD
    Manuel
    Thank you for that Volks. I have scoured that thread quite a few times.
    I’m still a bit confused, which is why I indicated what I was looking for and what recommendations the fine folks here on the forum would recommend….
    I wanted to go 35 without modifying the stock suspension. Or how big can I go without modifying my suspension.
    I’ll keep looking on the thread you provided.
    And continue arguing about engine rod bearings…
    Leo's first likes this.
  5. Apr 19, 2023 at 2:22 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    And I would add to that: the more aggressive and OR treads also have poorer rain / wet pavement performance. Just be aware that tire choice involves a compromise in just about every category.
  6. Apr 19, 2023 at 2:28 PM
    Outbound
    Aaron
    Northern Alberta
    Super happy with my Falken Wildpeaks. OEM wheels and suspension.
  7. Apr 19, 2023 at 2:34 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
  8. Apr 19, 2023 at 7:11 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I am super happy with the BFG KO’s. Excellent snow tire. They are a little rougher than stock but not much. Have 1.25” Bora spacers on too. 51344DB7-84DF-45D4-8B8D-8EC926E136EF.jpg
    Dfrink and Black widow TRD[OP] like this.
  9. Apr 19, 2023 at 7:17 PM
    TundraMoe
    BTW, tire size is 275 70 18 and they were on for a while before the small lift was put in. Fit just great.
  10. Apr 19, 2023 at 7:20 PM
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    295/70/18 is the largest tire size you can go on stock suspension.
    Nitto makes the Recon Grappler in a “P” rating in that size, which is nice because it’s much lighter. As long as you don’t require an E-rated tire for some reason.
  11. Apr 19, 2023 at 8:13 PM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    I’ve had a lot of trucks and different tire setups. Here’s my takes but YMMV:
    Toyo: Wear rate was horrible on Toyo’s for me I tried both MT and AT both were terrible for me.
    BF Goodrich KO2 - really like the KO2’s great on almost everything, they are just average on wet pavement though.
    Nitto Grapplers - look cool and were good but I really didn’t like the amount of road noise.
    Mickey Thomason’s - Never ran these
    **Falken WildPeak A/T3W** - These are my new favorite tire. I haven’t had them long enough to tell on wear, but I’ve had them in all conditions from mud, to wet, to white out ice and snow and they performed great. They’re pretty quiet for daily driving as well. As a bonus they are usually a little cheaper than most of the field.
    I’m running 295/70/18
  12. Apr 20, 2023 at 10:58 AM
    Black widow TRD
    Manuel
    Thank you to all that provided insight on this, I greatly appreciate your knowledge !
    I may go with the Westscott lift and 35’s. It seems the Westscott lift retains the weight em quality suspension as mentioned on another thread.
  13. Jul 21, 2023 at 2:34 PM
    jonnychewtoy
    jonnychewtoy New Member
    I'm in the same boat, what did you end up going with? I feel like i've read 295/75/r18 wouldn't fit on stock OR suspension.
  14. Jul 21, 2023 at 8:52 PM
    Black widow TRD
    Manuel
    I ended up going with Falken Wildpeaks 295/70 R18, at first I went with oem wheels and a 1” spacer.
    Then I switched out the oem wheels and went with some 18” Fuel Blitz with a 20+ offset.
  15. Jul 23, 2023 at 9:57 PM
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    I just put on 275 70 r18 and love it. Not too big, but look great. All stock everything.
    dogsleds_t100_tundra likes this.
  16. Jul 24, 2023 at 9:47 AM
    jonnychewtoy
    Did you need the 1" spacer for the 295/70/r18s?
  17. Jul 24, 2023 at 9:02 PM
    Black widow TRD
    Manuel
    No you don’t.
  18. Jul 25, 2023 at 9:18 AM
    silk
    silk New Member
    2023 Lunar Rock TRD
    Question on the 275/70/18 tires, these are slightly larger than the factory 265/70/18. Curious on the impact on MPG with the larger tires?
  19. Jul 25, 2023 at 9:37 AM
    TundraMoe
    Very minor change. The mpg dropped a bit but it’s a truck so who cares. I can still get 22mpg on the highway.
    I’m going to be jumping up to the 295’s soon as I lifted the truck and it needs more tire, so I’ll have a set of barely used 275 BFG’s for sale
  20. Jul 25, 2023 at 10:48 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I just finished sanding my tires so that my TRD. Hopefully it will ride smoother. IMG_4947.jpg
  21. Jul 25, 2023 at 11:03 AM
    OC Limited Tundra
    OC Limited Tundra New Member
    2023 Celestial Silver Limited TRD Offroad
    I came from K02 on my Tacoma and I loved them, but they're a bit heavy. I'm considering going with Falken Wilpeak AT3 for my Tundra, I keep reading online that they behave better for on road use.
  22. Jul 25, 2023 at 11:03 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    should be pretty smooth on the highway now!
