Suspension options for terrible roads & gravel logging roads
Discussion in 'Suspension' started by 207Angler, Jul 17, 2023.
  1. Jul 17, 2023 at 5:05 AM
    207Angler
    207Angler [OP] New Member
    2021 Nighthshade Edition
    Hi all! New Tundra owner from Maine and new member to the forum. I just picked up a 21' nightshade edition which will be primarily used as a weekend warrior rig with many trips to the northern part of the state which is mostly gravel logging roads with many potholes and washboards. I am not planning on doing anything too technical with this truck (I have a 4runner for that) but would like to make it a more comfortable ride on some of the nastier logging roads we have up here. Here is my criteria to narrow down the selection...
    • Something that will hold up to salt/corrosion (lots of salt used on the roads up here in the winter)
    • improved comfort at moderate speeds on rough roads/logging roads
    • looking to lift approximately 2-2.5" max
    I have done a lot of searching but there are just so many options out there. I appreciate any and all advice/opinions.
    PermaFrostTRD likes this.
  2. Jul 17, 2023 at 10:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Quality 2.5” coilovers up front, and Deaver springs in the rear with good shocks…
    Air down and go to a smaller diameter wheel!
    2mchfun and ATV25 like this.
  3. Jul 18, 2023 at 10:10 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I have just a couple questions for you here first -
    • What's your budget?
    • How much extra weight (if any) do you have on the truck? I see the tonneau cover, but is it generally empty except for loading up with gear on the weekends?
    RobertD and Chad D. like this.
  4. Jul 18, 2023 at 10:23 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  5. Jul 18, 2023 at 6:03 PM
    207Angler
    I’d like to keep it under $3k. It seems like there are many options out there that would fall under this budget. I would only be loading up with my gear on the weekends. No plans for any heavy accessories.
  6. Jul 18, 2023 at 6:11 PM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
  7. Jul 18, 2023 at 6:15 PM
    207Angler
    2mchfun likes this.
  8. Jul 18, 2023 at 6:23 PM
    TRDblvd
    TRDblvd New Member
  9. Jul 18, 2023 at 6:28 PM
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    Long travel and 37’s. Problem solved. :cookiemonster:
    Dsptundra, reywcms and PomDad like this.
  10. Jul 18, 2023 at 6:31 PM
    mountainpete
    Elka is very popular up here in Canada because of its corrosion resistant materials. I’ve had Icon on a Tacoma and they were much more pitted and required rebuilds every 2-3 years.
    2mchfun and Rodtheviking like this.
  11. Jul 18, 2023 at 9:37 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Nice truck. So what did you pay for it and how many miles where on it if you don't mind me asking?
  12. Jul 18, 2023 at 9:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Step one is 18 inch wheels and air down a little
    207Angler[OP] and Rodtheviking like this.
  13. Jul 18, 2023 at 9:53 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Elka, Kings or Dobinsons.
    2mchfun likes this.
  14. Jul 19, 2023 at 3:41 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I’m not sure of how other suspensions feel but I also have a cabin in Northern Maine (70 miles down the Golden Rd) and I know the roads your probably talking about. We all drive Tundras and for the most part they handle those roads solid but my father has a 2020 TRD Pro and it seems like those roads were made for that suspension. I can drive 70 in that truck on those logging roads and it soaks them up smooth. It seems the faster you go the better it feels. Also it’s great on the technical off the path winter roads sucking up ruts and what not. I’d say find a pair of take offs or news ones but I don’t know if what others are suggesting are a superior suspension.
    Oey12 and 207Angler[OP] like this.
  15. Jul 19, 2023 at 4:22 AM
    207Angler
    I picked it up for $47k with approx. 21,000 miles.
  16. Jul 19, 2023 at 5:06 AM
    2mchfun
    Off topic, but before you start throwing money at the truck, give the frame a really good rustproofing with woolwax or fluid film. Take your time and get up inside the blind areas with a spray tube. Try to keep it off the rubber components. I would also carefully take out each transmission pan bolt one at a time and apply anti seize so if you ever need to replace a solenoid you won't be breaking bolts. Carry on!
  17. Jul 19, 2023 at 5:20 AM
    207Angler
    I plan on doing it this fall before the snow starts to fly. Been using fluid film and wool wax for years. Has kept my 4runner's frame looking like new.
    2mchfun[QUOTED] likes this.
  18. Jul 20, 2023 at 4:08 PM
    207Angler
    After a ton of research I am strongly leaning towards the Toytec Aluma series 2.5 (made by Elka) anyone on here have any experience with this setup?
    2mchfun likes this.
  19. Jul 23, 2023 at 11:07 AM
    TRDblvd
    TRDblvd New Member
    Several folks on here with that setup. You'll be happy with it
