2005 5SP Holding Gear
Discussion in '1st Gen Tundras (2000-2006)' started by Tundraip, Jul 20, 2023.
  1. Jul 20, 2023 at 12:55 PM
    Tundraip
    Tundraip [OP] New Member
    Hello there. I’ve had the truck for several years, and many times when the transmission is cold, it will hold a gear rather than shift up. Usually 1, 2 or 3. Yesterday was more concerning because i couldn’t accelerate on a freeway ramp to merge. Lasted about 10s, let off the gas, then it finally shifted up a gear. Thoughts?
  2. Jul 20, 2023 at 1:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The automatic transmissions have vanes inside that need to be open (temperature up) before it will shift properly. I don't know about the manual
  3. Jul 20, 2023 at 1:29 PM
    Have you done any maintenance to the transmission?
  4. Jul 20, 2023 at 1:33 PM
    Tundraip
    mine is A5.
  5. Jul 20, 2023 at 1:34 PM
    Tundraip
    No, never. I also don’t tow, but don’t know if prev owner did…
  6. Jul 20, 2023 at 1:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't know what a5 means. Your title saying 5speed inclines me to think you have a manual transmission which most trucks did not come with.
    If so, you are the minority
  7. Jul 20, 2023 at 1:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I guess all the a750's dont have dipsticks, i wonder if someone has put some fix-in-a-can in it & gotten the plastic balls gummed up.
    might be worth a drain & fill. Might need a proper flush, depending on milage.
  8. Jul 20, 2023 at 1:42 PM
    Normal behavior and one of the many things covered in this thread, which lists a lot of other quirks, oddities, and concerns for 1st gens.
  9. Jul 20, 2023 at 1:42 PM
    Tundraip
    Pardon, 5SP automatic.
  10. Jul 20, 2023 at 1:51 PM
    Damn, I just realized that thread may not actually contain a note about the slow-to-shift-when-cold. We've had a few chats about that here for the later-model 5AT trucks. The lag for me is typically from 2=>3 if memory serves. And it happens frequently. Other members have observed it, reported it, confirmed it. My transmission has well under 100k miles and does it also.
  11. Jul 20, 2023 at 1:53 PM
    Tundraip
    Hmmm, may look into that…
  12. Jul 20, 2023 at 1:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's normal for these trucks. Trans has to be warm warm
  13. Jul 20, 2023 at 1:57 PM
    Yup. And there are ways to heat the trans up faster. I updated the thread and added this 'lazy shift' item into the 2nd reply, 'nuisances and TSB' section.
    bmf4069 likes this.
  14. Jul 20, 2023 at 2:02 PM
    Tundraip
    So I just swiped through it pretty fast and didn’t see anything.
    Haven’t seen this issue mentioned elsewhere, but will have to check.
    Interesting…. I wonder if it’s just a harmless quirk that never goes away, or if there is a solution? Thank you
  15. Jul 20, 2023 at 2:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not saying you do not have a problem but after starting, how far had you driven before getting to freeway ramp ?
    The reason I ask is because my 04 takes about 2-3 miles before coolant and transmission temps reach the proper range. I've always viewed this as normal if for no other reason than what's noted in the troubleshooting section of an FSM.
  16. Jul 20, 2023 at 2:13 PM
    Tundraip
    Thank you
  17. Jul 20, 2023 at 3:11 PM
    Tundraip
    About 3-4 miles. Thank you!
    BubbaW[QUOTED] likes this.
  18. Jul 21, 2023 at 5:04 AM
    So, just being curious here, could it not be low on ATF? I had a grand Cherokee that would do the same thing, as well as my truck did the same when it was low after a spill and fill. Added ATF till full in both cases and it stopped. I have 0 problems with mine hanging even when cold, even in the winter.
  19. Jul 21, 2023 at 5:38 AM
    I suppose it could be, but - and this is just my experience - usually when I've had a auto trans that was low on fluid, I'd get a lurch following that late shift, and the lurch was more alarming to me than the late shift. And it was pretty persistent, hot or cold.
    bmf4069[QUOTED] likes this.
  20. Jul 21, 2023 at 11:46 AM
    Tundraip
    So I did a very basic oil level check a while back. I let the oil warm up and then loosened and Allen bolt to see if any leaked out and it did right away, which should imply it’s at full level. Also, it appears to be the lader models that have this lazy shift issue.
    bmf4069[QUOTED] and shifty` like this.
