anyone know
Discussion in '1st Gen Tundras (2000-2006)' started by Keith P, Jul 21, 2023.
  1. Jul 21, 2023 at 10:14 AM
    Keith P
    Keith P [OP] New Member
    Keith
    06 tundra limited
    None
    Does anyone have any tips on fixing or replacing this section of my truck? I'm thinking of getting a resistance welder as I'm replacing the radiator support assembly, any help would be greatly appreciated.
  2. Jul 21, 2023 at 10:16 AM
    Keith P
    Keith
    06 tundra limited
    None
    Also anyone know where I can get one of these? Headlight connector
  3. Jul 21, 2023 at 10:16 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    JakeJake, hagrid, Beefnbread and 4 others like this.
  4. Jul 21, 2023 at 10:19 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You're actually prime to do the 2014+ conversion.
    McNeil offers a kit that includes the bedsides which typically don't get done when ppl piece the front together.
  5. Jul 21, 2023 at 10:26 AM
    2mchfun
    Salvage or eBay should get you one
  6. Jul 21, 2023 at 12:05 PM
    Welcome from NY.
    Aaron @Outbound can answer that question.
    Outbound likes this.
  7. Jul 21, 2023 at 1:03 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Looks like a fairly major project.
  8. Jul 21, 2023 at 2:55 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  9. Jul 21, 2023 at 2:57 PM
    Outbound
    Aaron
    Northern Alberta
    I've never actually used a resistance welder or done body work. My first instinct would be to TIG weld it due to how thin the metal is.
  10. Jul 21, 2023 at 3:23 PM
    Retired...finally
    I've MIG'd auto sheet metal before but it's a time consuming process. MIG for one second and blowgun for 10 to cool it back down. I'd love to have a TIG.
    Outbound[QUOTED] likes this.
  11. Jul 21, 2023 at 4:43 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Welcome to the best gens forum. :D
    Retired...finally likes this.
  12. Jul 21, 2023 at 6:46 PM
    There was a guy down in FL, bay area IIRC, who basically did this exact same job for his son after he wrecked it. Wish I could find the damn thread...
    JasonC. likes this.
  13. Jul 21, 2023 at 7:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Where are you located ?
  14. Jul 22, 2023 at 5:08 AM
    But back to the point, yes, while a junkyard is your best bet, and normally parts you need can be easily tracked down HERE, the part you're looking for is part of the actual headlight housing, and NOT a factory harness. You'll need to replace the housing to get that little wire harness, or hit a JY and pull it off a vehicle there. I recommend buying something CAPA-certified, either from DEPO, TYC, Eagle Eyes, RockAuto is a great choice to buy from online. OEM is pretty spendy, most go aftermarket. BE CAREFUL WITH YOUR CHOICE. The headlight housings on these trucks are wildly variable depending whether you're double cab or reg/acc cab, whether you have DRL, and by year. Don't believe me? See for yourself, here's the harness you need, sitting on my brand new aftermarket housing from a couple months back... :
  15. Jul 22, 2023 at 5:17 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    MIG setup with .023 wire is my go to for automotive sheetmetal. I use a block of copper to backup the weld area and act as a heatsink. Aint nobody got time to do the required amount of prep for TIG bodywork.
  16. Jul 22, 2023 at 6:04 AM
  17. Jul 22, 2023 at 2:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    I did a repair like this on a couple of salvaged Toyota trucks I got from a wrecking yard and rebuilt in the 80s. Spot weld drill, air chisel and a MIG welder are what I used. I also had access to a hydraulic dozer that a friend who was a professional welder made. Back in those days aftermarket body panels were readily available in CA but usually required some working to get the to fit properly. I was a broke student and this allowed me to drive decent vehicles and make a few bucks
