Do I need a specific sway bar link?
Discussion in '1st Gen Tundras (2000-2006)' started by judeB, Apr 7, 2022.
  1. Apr 7, 2022 at 5:46 PM
    judeB
    judeB [OP] New Member
    2006 Tundra
    Hello everyone Im new here and have learned a TON about my truck in the short time Ive been here, so thank you. First, I know this topic has been covered, but answers vary.Ive owned my tundra since 2007 with very low miles, Im now at 150k and its time to do some upgrades. For front suspension i decided to go with pre assembled 5100 bilstein coilovers with the emu coils, adding 1.5 inches of lift. When I looked under the truck i realized my sway bar link bushing on both ends of the sway bar had "pulled through", and are separated from the bar. So my question is with the lift do i need a specific sway link bar like the ones from summit racing? or should i go with the standard stock options? what is the preferred replacement for the sway links? Do i need the sway bar? Also any recs on brake pads? mights as well change it all while im in there. Thanks!!!
  2. Apr 7, 2022 at 5:50 PM
    judeB
    2006 Tundra
    heres a pic...
  3. Apr 7, 2022 at 7:10 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    For brakes you can't beat powerstop Z36, they're what I use and they're great.
  4. Apr 7, 2022 at 8:49 PM
    judeB
    2006 Tundra
    great thx. no thoughts on links?
  5. Apr 8, 2022 at 7:52 AM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Links are broken (not pulled through)... if not lifted, then stock ones will work fine
  6. Apr 8, 2022 at 8:14 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    My son's 06 Dbl Cab also has right at 150k miles. For the front brakes, I resurfaced the OEM rotors and installed Hawk LTS pads. For the rear went with OEM Drums and Shoes, aftermarket spring kit and AC Delco wheel cylinders. Once adjustments to the rear drums/shoes were dialed in, brakes are better than when I bought truck new in Jan 07'. As for sway bar links, we're still on OEM setup. I installed Bilstein 5100's in middle setting on stock coil (around 1.4in lift) and think the stock sway bar/links are holding up fine. Maybe just replace with standard OEM/aftermarket ones IMO.IMG_20211113_125503508.jpg
  7. Apr 8, 2022 at 8:57 AM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    As mentioned, the stock end links should be fine with minimal lift. I just did this job last week and want to mention that you will likely have to cut the lower link nut and bolt off in order to remove the end link. The lower link will rotate in the socket preventing the nut from turning off.
    I wasn't able to clamp the link well enough with vice grips to remove the nut so had to use an angle grinder to cut the nut and bolt. This video shows the process well:
    https://www.youtube.com/watch?v=crJkg4-qlGQ
  8. Apr 8, 2022 at 11:45 AM
    judeB
    2006 Tundra
    great responses thx everyone
  9. Apr 8, 2022 at 12:31 PM
    I would go with Moog. They're cheaper and warrantied for life; just hold onto the receipt.
    You can get them at advanced auto or elsewhere online. I've had my 2nd set for several years now.
    JakeJake likes this.
  10. Apr 8, 2022 at 1:25 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  11. Apr 8, 2022 at 10:25 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Yeah, links are broke. Go Moog on these. They are built well and are really cheap.
    Only reason I say Moog is because they are easy swap when they fail again, and new OEM is close to $500.
    Everything else always use OEM.
  12. Apr 9, 2022 at 12:38 AM
    evilrb
    evilrb New Member
    Jeremy
  13. Jul 20, 2023 at 2:11 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    If truck is lifted should I be getting longer ones?
  14. Jul 20, 2023 at 2:26 PM
    At somewhere between 2" your swaybar links become a limiting factor. More info on this can be found in the "Suspension, wheel and tires ..." section OVER HERE.
    Edit: SuspensionMAXX makes a great regular-length link and extended link for our trucks. Here's the part#s for stock-length and 1"-3" lift, underlined in blue:
  15. Jul 17, 2024 at 4:06 PM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    Altho going on a year old, i read this w/interest of "bang 4buck".
    My 06 AC 2wd still has its OEM End links w/173k. Since im staying on pavement w/out any lift mods or wheel upsizing, is MOOG [beckarnley] acceptable quality for End Links?
    Im refreshing a lot of stuff other than my OEM LBJs [bilstein 4600, Steer OutRods, Boots, Swaybar bushings and maybe PS soft lines] so, my $$meter is approaching redline. I see Toy OEM [$73 per] makes SuspensionMaxx look like platinum; how many notches down are Moogs [$50] for correct fit/function, longevity compared to others [near bottom shelf?] ??
  16. Jul 17, 2024 at 6:50 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    The only non OEM chassis parts I would buy would be Moog Sway Bar links. I have three first gen’s in my driveway all running them, and all three are holding up great. My Tundra has about 108k on them and they look new.
    The new design gets rid of the bushings and uses a plastic cup looking thing.
