Thermostat housing coolant leak
Discussion in '1st Gen Tundras (2000-2006)' started by terrward, Jul 16, 2023.
  1. Jul 16, 2023 at 9:40 PM
    terrward
    terrward [OP] New Member
    2004 DC SR5
    Cleaning my 04 DC this afternoon and spotted this gem. Looks dry at the moment and coolant overflow is still at the full mark.
    For the repair it looks like i need a new o-ring (96761-35035) and some sort of gasket maker for the square flange.
    08826-00100 = $$$$ green stripped tube
    00295-00103 = $20 a tube and I’ve read it’s been a suitable replacement.
    I’m leaning towards using the 103 tube, anybody done the same?
  2. Jul 16, 2023 at 10:33 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I did this repair before.
    I went with the same part number. I would recommend replacing your thermostat while you have the coolant out. Mine recently went out causing a grenade of problems
    Part Number
    96761-35035
    Engine Coolant Pipe O-Ring $4.11
    FirstGenVol and JasonC. like this.
  3. Jul 17, 2023 at 7:03 AM
    I would just add, courtesy this exact leak and a linkback to more info lives in this informational thread that covers many 1st Gen quirks and such: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It's in the 2nd reply of the thread, inside the coolant leaks bullet point. Search the page for the hyphenated phrase "t-stat" and click the link that follows that word. Common enough leak that at least half a dozen people here have found it. Hell, there was another guy with what is likely the same leak posting during the weekend.
    terrward[OP] likes this.
  4. Jul 17, 2023 at 7:18 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Super easy fix, took me 20 minutes I just used permatex gasket maker and a new oring. Also changed the Thermostat and gasket while I was in there!
    jerryallday likes this.
  5. Jul 17, 2023 at 10:00 AM
    terrward
    2004 DC SR5
    Which gasket maker did you use?
  6. Jul 17, 2023 at 11:00 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  7. Aug 17, 2025 at 6:46 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Is this the spot where rtv or gasket maker is used? Not exactly at the housing with the o-ring?
    Should I be concerned that there isn't much in the overflow? Radiator is steady.at the point in the picture with no visible leaks on the ground just the dried coolant directly below the intake tube
  8. Aug 17, 2025 at 8:25 AM
    bfunke
    bfunke Tundra Curmudgeon
    Yes. Your radiator will stay full until the overflow reservoir is empty due to siphoning and then it will decrease. I just did mine and used Aisin FIPG from Rock Auto and Toyota o-rings (2) and crossover gaskets (4).
    Hi06silver likes this.
  9. Aug 26, 2025 at 4:48 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Just now tracking parts down. Am I missing something? From what I can tell it's just 2 crossover gaskets and 2 o-rings. Is that right? Part # 16355a
  10. Aug 26, 2025 at 5:13 PM
    bfunke
  11. Aug 26, 2025 at 5:21 PM
    Just an note - verify part numbers. Only because I'm seeing a 2000 Tundra owner talking to a 2006 Tundra owner here... :D
  12. Aug 26, 2025 at 5:36 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Ha. I'm just stumbling through the f'n diagrams on parts look up and the website. Between going damn near cross-eyed following all their crayon drawings and the FSM showing 2 for each 1uz and 2uz I thought I'd double check. I have a feeling the person (my mechanic friend) that did the timing belt used the wrong fipg. That Toyota shit in the green tube is totally outta bounds on price. I went with the stuff mentioned above. Hopefully Toyota just has the o-rings in stock so I can just go pick them up tomorrow.
  13. Aug 26, 2025 at 5:38 PM
    bfunke
  14. Aug 26, 2025 at 5:46 PM
    bfunke
    Also - FIPG for Water Pump is PN 08826-00100 which is Seal Packing 1282B and sells for $83. I used AISIN AB1207B1 (Black) which sells for $14 at Rock Auto
  15. Aug 26, 2025 at 5:52 PM
    I bet the Aisin shit is probably the same stuff with a different tube.
  16. Aug 27, 2025 at 8:48 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    I read through a long version of it's what they use unless it's warranty work then they use the good stuff. I think that was on ih8mud...
    Another question: is there a handy dandy tool that helps with burping the system after refilling coolant so it eliminates the likelihood of hot spots or air pockets? Something like the motiv brake tool
  17. Aug 27, 2025 at 9:15 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    shifty` and jerryallday like this.
