  1. Jul 16, 2023 at 6:58 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Needs moaaarrr! How’s the new setup!?
  2. Jul 16, 2023 at 7:04 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It’s…
    I’m getting all sorts of confidence to do even dumber shit, so I’m sure I’ll be making other upgrades in no time.
    Cthulhu, Blowdart, endagon and 6 others like this.
  3. Jul 16, 2023 at 7:14 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Hahah yea… I know the feeling lol
  4. Jul 16, 2023 at 8:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Do the Radium cans have drains in them?
    I'm finding that with all the shit stuff I have mounted around the battery, getting to the J&L can to unscrew it is a bit of a pain. SO I ended up going way too long without checking it...
    :anonymous:
    I remember seeing somewhere that one of the brands of catch cans has a drain built into it. Otherwise I might be looking to drill and tap on into the J&L can, though mounting on the passenger side would be kind of nice to free up space.
  5. Jul 16, 2023 at 8:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    For years I planned on doing that to my DC.
    Then I sold it and bought the CM.
    :D
    PomDad likes this.
  6. Jul 16, 2023 at 8:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    In my build thread I've got the numbers I ended up settling on to get my 295's reading right. It's not nearly the difference that the "book numbers" say it should be. I think Toyota calibrates these trucks for a larger tire than they actually put on them.
    1794TX and Tundra234[QUOTED] like this.
  7. Jul 16, 2023 at 8:17 PM
    cconzelmann
    cconzelmann Extra new member
    Chad
    SLO, CA
    2017 Crewmax 4x4
    So stock.
    Just installed some Method 707s in 18x9", +25mm offset and Toyo AT3s in 285/70R18 in load E. Digging it so far and I kinda like the look on stock suspension. Just need to do some plastic manipulation.10.jpg 9.jpg 11.jpg
    BR73, Wallygator, occruiser and 15 others like this.
  8. Jul 16, 2023 at 8:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Managed to get my oil changed and switched to an AFe dry engine air filter.
    Waiting on the 2 quarts of liquid gold Toyota Transfer Case oil to show up before I pull my skid plates and do the front and rear diff and transfer case fluids and all the rest of the stuff on my checklist for 60k miles.
    Also rotated tires on two cars today, changed the oil on two cars today, and did a bunch of other maintenance.
  9. Jul 16, 2023 at 8:31 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Mine is dead nuts for the 285/70r17s that I put on. Not sure on what the tire actually measures but I do think that is the largest factory tire size they ever put on a Tundra.
  10. Jul 16, 2023 at 10:04 PM
    AZTundra
    Paul
    Phoenix, AZ
    Correct, you can add the radium engineering drain kit to their catch cans. I have their dual can setup, but no drain kit on mine.
    http://www.radiumauto.com/Catch-Can-Petcock-Drain-Kit-P367.aspx
  11. Jul 17, 2023 at 4:29 AM
    Thanks. I found it....post #96 showing 32 and 33.5. I'll try those. With my current setting using the 255/70 and 295/70 (it adds the inches automatically), I am off 1 to 2 mph depending on which GPS (Waze and radar detector) I'm looking at. If I am on a straightaway and set the cruise, Waze and the radar detector match. Normal driving, the Waze is usually 1 mph behind the radar, but I contribute that being caused by the wireless android auto. I had to adjust the speed in my SG3 as well. Not to sidetrack, but the SG3 is weird anyway. It doesnt read the same thing that the dash shows....IE the tire pressures read different on it compared to what the dash display says. I'll have to email them to see what their thoughts are.
  12. Jul 17, 2023 at 5:16 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Upgaded to 2.5 Fox coilovers w/ resi (non-DSC). Things are beefy! They replaced Toytec boss coilovers.
    Overkill for this grocery getter/family vehicle...but they're freakin cool...lol
    BR73, Wallygator, AggiePhil and 11 others like this.
  13. Jul 17, 2023 at 6:38 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    The radium’s do not but they do have a dipstick to check the level. Update no idea that you could add the drainage bolt. That’s cool
  14. Jul 17, 2023 at 6:47 AM
    Vizsla
    Vizsla 2 = 2.5
    :smokertransformer:
    FIFY :D
  15. Jul 17, 2023 at 7:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have a drain barb and petcock with a rubber oil/fuel safe tube that came with my setup from Radium...I didn't hook it up as it's less of fa mess just checking and draining it when I remove it...
    RainMan_PNW and reywcms[QUOTED] like this.
  16. Jul 17, 2023 at 7:24 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Eh maybe here soon lol.
    trevorklat and Vizsla[QUOTED] like this.
  17. Jul 17, 2023 at 3:13 PM
    1794TX
    Steven
    N.TX
    '20 1794
    I'm kinda thinking that may be the truth. I have 60R20 Coopers, which they say are 33.7" in diameter, and at 40mph (according to the little radar 'Your Speed' devices I normally ignore) I'm less than 1 mile over. If I ever move to 35's I might get a calibrator; but I'm fine without for now.
  18. Jul 17, 2023 at 7:22 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    bulldog93 and reywcms like this.
  19. Jul 17, 2023 at 7:33 PM
    cconzelmann
    Chad
    SLO, CA
    2017 Crewmax 4x4
    So stock.
    BTW I put some additional info here with heights and weights of my setup that some one may find useful. It’s info I was looking for when I was debating my decision.
    reywcms likes this.
  20. Jul 17, 2023 at 8:14 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Sprayed matte clear on the shifter surround. Hated the glare from it. So much nicer now.
  21. Jul 17, 2023 at 9:19 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Dropped my dad off at SFO, stopped far enough away to not smell the piss.
  22. Jul 17, 2023 at 10:15 PM
    SAGE63
    San Diego County
    Yerba Buena Island in down wind of the city...lol
    Toe404[QUOTED] likes this.
  23. Jul 18, 2023 at 4:51 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    :fistbump:
  24. Jul 18, 2023 at 7:16 AM
    king.cong.1119
    king.cong.1119 New Member
    Took the 37s equipped tundra for a 300miles road trip and it did pretty well. 13-13.5mpg calculated. Not bad.
    [/QUOTE]
    13.5 MPG, not bad
    BR73, AggiePhil, Tundra-XP and 7 others like this.
  25. Jul 18, 2023 at 7:57 AM
    DesertDoesIt
    DesertDoesIt New Member
    Always looking to upgrade
    Desert Does It Seat Jackers and MMP
    That's Awesome! This is Joe (part owner of DDI and the one that invented the original Tacoma Seat Jacker). He just got back from a cross country trip visiting Family in Vermont.
    Very cool that you spotted him.
  26. Jul 18, 2023 at 8:29 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Yes! They worked great. I have the daystar cradle on the bottom so I'd guess that made a difference so they won't over stretch.
    Tripleconpanna likes this.
  27. Jul 18, 2023 at 8:31 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Shouldn't the speedo be calibrated to whatever's on the door jamb sticker? It stinks that we have to play with the numbers because the info on the sticker doesn't seem to jive.
    AggiePhil and Tripleconpanna like this.
  28. Jul 18, 2023 at 8:35 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you just comment on your original post? :monocle:
  29. Jul 18, 2023 at 8:36 AM
    king.cong.1119
    not sure how it works, but didn't want to double post, so I quoted my own post? if that makes sense? lol
    Tripleconpanna and RobertD like this.
  30. Jul 18, 2023 at 8:46 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pokin' fun atcha but try the ol Edit
    Tripleconpanna and Taco-Spike like this.
