The proper way to set the transmission fluid level.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Jul 24, 2021.
  1. Feb 16, 2023 at 8:17 AM
    Rocko9999
    Rocko9999 New Member
    Except those temps are for AB60. A760E/F, and fluid level check temperature range is 127-138. That detail alone could cost someone a missed 3oz of fluid. ;)
    Joe333x[QUOTED] and JLS in WA like this.
  2. Feb 16, 2023 at 10:17 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Correct, i just know off have the temp i need to remember but obviously someone with the 4.6 should know theirs, i feel like the majority here are 5.7 though, 4.6 seemed more popular in the 2nd gen than the 2.5.gen.
    Dirtytruck likes this.
  3. Feb 16, 2023 at 11:35 AM
    NWPirate
    Zach
    WA
    Do all 5.7l Tundras have the AB60 trans?
    Can't seem to find the info anywhere
  4. Feb 18, 2023 at 2:46 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Can't remember where I found this, think it's a screenshot from a video.
    Droptarotter and Joe333x like this.
  5. May 2, 2023 at 8:02 AM
    myoung2746
    myoung2746 New Member
    I've been having trouble getting my 2012 Toyota Tundra 4.6L with 6 speed transmission (no trans cooler/tow package) into trans fluid check mode. These are the steps I do:
    • Warm the truck up, engine temperature close to normal operating range
    • Jump the specified terminals on the ODII connector (lights are now flashing on the dash)
    • Shift P-R-N-D
    • Shift D-N with 1.5 seconds between many times
    No A/T Temp light or Drive gear selection light will ever come on.
    Could this be because I have a check engine light for catalyst below efficiency?
    Is there anything else I should be doing to get into fluid check mode?
  6. May 2, 2023 at 9:01 AM
    Chip_Tundra
    Chip_Tundra New Member
    Just buy a cable and the bootlegged Techstream. Best tool to have when doing this type of stuff. You can also get a Scan Gauge II or III. Makes life a whole lot easier.
  7. May 2, 2023 at 9:39 AM
    AZBoatHauler
    So.Arizona
    Engine needs to be cold/cool when starting. The temp to check is in the low 100’s so if the engine is warm you’re already way passed that.
  8. May 3, 2023 at 6:13 AM
    myoung2746
    Thanks for the tips, I'll try starting with a cold engine, then check into the scanners
  9. Jul 14, 2023 at 8:18 AM
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
  10. Jul 14, 2023 at 8:32 AM
    Dirtytruck
    2021 SR5
    Agreed. 99-111 degrees for my 2021 SR5.
    My scan gauge reads the torque converter temp not the pan temp. It’s always higher in degrees than my pan temp according to my thermal gun which makes sense since the T/C is where the most heat is generated.
    I point the laser of the thermal gun directly into the Allen wrench hole of the plug to read the pan temp. Pointing it onto a painted metal surface like the pan can give an erroneous reading according to the thermal gun instructions.
    I’m confident it’s accurate this way because during my last drain and fill the plug temp reading was the same as the fluid being drained during the final drain. I also checked the temp of the painted surface of the pan before pulling the plug and if memory serves it was 10-15* cooler.
    Anyway, the bottom line is I don’t know how else to do it and I find it difficult to trust someone else to do it.
    My SR5 does not have a way to read TFT temps from the cab other than my scan gauge which reads the T/C temp, not the pan temp.
  11. Jul 14, 2023 at 11:01 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I read on the Tacoma forum to hit the outlet line.
  12. Jul 14, 2023 at 12:26 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Or got to lower AZ during summer, and you already are at the correct temperature when you start anytime after noon lol. Just make sure your fluid has been sitting in the garage overnight.
  13. Jul 14, 2023 at 7:22 PM
    Chip_Tundra
    I mean, most people here who say, "USE THE SEARCH FUNCTION" don't care to help others in need anyway. The way people reply here sometimes, it's as if they own the forum. If you don't like what you see, it takes less energy to just keep scrolling.
    Anywho, I love these threads. lol
    17inferno likes this.
  14. Jul 14, 2023 at 8:06 PM
    Joe333x
    Joe333x Member
    Boston
    The torque converter temp is actually the same as the pan temp until you start driving, the torque converter only gets hotter than the pan when its being used while unlocked, when the torque converter is locked up the temp will basically mirror the pan temp as well. I watch my temps almost every drive with my OBDlink MX+.
    I happen to be the person who keeps reciting the same information over and over or else I would not have said to search, I have more likes than I do messages, Im always willing to help people but it gets frustrating when you see the same posts over and over. If someone has a question they could at least find a thread on the same topic instead of starting a new one.
  15. Jul 14, 2023 at 8:36 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    It'll read both pan and converter temps. I usually have both displayed.
    These are the codes I pulled off the Tacoma forum some years ago for a 2nd gen Tacoma. Same codes worked for Tundra (2.5 gen) & 4Runner (5th gen) that I've used same scan gauge in.
    Dirtytruck[QUOTED] likes this.
  16. Jul 15, 2023 at 12:48 PM
    Dirtytruck
    2021 SR5
    I appreciate that.
    Currently mine reads “TFT190” or whatever the temp is at the time.
    I realize my thermal gun could be off a few degrees but when I fire it on the torque converter housing that temp is always the closest if not exactly what the scan gauge reads. The pan temp doing the same thing is always cooler. I think I said there was a 10-15 degree difference between the t/c and the pan temps in my previous post. It’s more like 5-10 degrees. My bad.
    I’m not embarrassed to say say that I’m not very savvy without really easy to understand instructions which ofcourse is relative to begin with, so I had the factory set it for my truck before they sent it.
  17. Jul 15, 2023 at 1:02 PM
    Dirtytruck
    2021 SR5
    Good to know. Makes sense since the t/c will be the hotter of the two while driving better to know it’s temp.
  18. Aug 7, 2023 at 9:23 AM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    My OBD2 terminal doesn't have a wire connected to the #4 pin as directed in procedure. Has anyone seen this before or know if there is a different "check level" pin out?
    Mine only has 1,2,3 to top and 12, 13, 14, 15 on bottom.
    2020 Tundra SR5 4x4 purchased new.
    Thanks
  19. Oct 6, 2023 at 10:03 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Hi John, @Rocko9999
    You are the first to post about the 2nd Gen 4.6L A760 trans having a different check temperature. This is late in the game for an ask, but I plan to dump the fluid in the 4.6 2010 tomorrow. Can you reveal the source of this information?
    A post upstream shows TSB TC009-07 lists all 07 Tundras (2Gen) as 115 - 133F with no mention of engine or trans type. Its not much of a difference and I guess its related to the pan volume at those temperatures OR the overall operating temperature of the two different transmissions. Higher op temp equal higher fluid levels and vice versa.
    As best I know, my 2010 4x4 with 108K miles has never had fluid dumped and has no obvious seeps or leaks. It does have the tow package cooler. I also have a 2013 Lexus IS-350 RWD with the same A760 RWD trans, which I dumped the pan/filter from at 100K (late IMO) and filled with Amsoil. Its temp check range tops at 115F IIFR, which aligns close with the numbers posted above. Anyway, 20K and not issues with the 350 and it gets hammered on.
    Any input on the 4.6L/A760 fluid temp check is welcome. This is by means of OBD scanner, not paperclip method.
    Thanks!
  20. Oct 7, 2023 at 4:55 AM
    #50
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    All I want to know is what is the TOYOTA definition of a Trickle
    nobodyintexas likes this.
  21. Oct 7, 2023 at 5:04 AM
    #51
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    when I do mine, I use the general urologist definition.
    served me well.
    NWPirate likes this.
  22. Oct 7, 2023 at 5:06 AM
    #52
    19PlatinumCrew
    Dave
    So that would be clearing your shoe wile peeing,or just light to modest dribble on the toes
  23. Oct 7, 2023 at 5:08 AM
    #53
    nobodyintexas
    nobodyintexas What?
    South of Houston
    don't dwell on the nuances
    you'll know it when you see it.
    kinda like the real inflation number.
  24. Oct 7, 2023 at 5:15 AM
    #54
    19PlatinumCrew
    Dave
    I didn't realize your a Renaissance Man
  25. Oct 7, 2023 at 5:20 AM
    #55
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Why you guys bother with exact temperature? I was draining and filling back the amount I drained for 4 years until transmission cooler was installed and I didn't know its capacity. No adverse effects, no nothing, it just worked.
    Chip_Tundra, ATV25 and Rob's Inferno like this.
  26. Oct 7, 2023 at 5:36 AM
    #56
    nobodyintexas
    nobodyintexas What?
    South of Houston
    for the record, I never bothered with exact temp.
    I only did the trickle thing because I was down there anyway & it insures the correct level.
    and yes, no adverse effects.
    Chip_Tundra likes this.
  27. Oct 7, 2023 at 12:18 PM
    #57
    Joe333x
    Joe333x Member
    Boston
    I wait til its not flowing hard enough to go straight down and starts to flow along the pan.
  28. Oct 7, 2023 at 4:38 PM
    #58
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    That is what I have done on 2 Tacomas and now Tundra. I tried a one Tacoma to do the temp check thing and could not get it in temp mode. Works fine for me.
  29. Oct 7, 2023 at 6:59 PM
    #59
    Chip_Tundra
    As long as the truck isnt hot, it shouldnt affect anything. If anything I think the transmission is better off woth a little more fluid than less when you drain the check valve cold.
  30. Oct 8, 2023 at 9:42 AM
    #60
    rodm1
    rodm1 New Member
