  1. Jul 13, 2023 at 2:23 PM
    You sure it's the upper? Not just b/c the code says pre-cat, sometimes post-cat O2 will throw bad info and ECU will interpret the wrong O2 sensor is faulty. Just know, if code persists after, you're not the 1st guy to have it happen. General reco is to replace in pairs if you've got the $$.
  2. Jul 13, 2023 at 2:56 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    No codes, just the only one I haven't replaced lol. The driver's side was done a while ago as an "oh shit, emissions fail" moment. Then I replaced the rears about a year ago because they were looking rough.
    shifty`[QUOTED] likes this.
  3. Jul 13, 2023 at 5:10 PM
    metalpete
    ID
    Good grief! I'd like 5 minutes alone with the person that decided the location for the sensor :mad:. What a PITA
    Go at it from above.
    bmf4069 and shifty` like this.
  4. Jul 14, 2023 at 4:58 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Not to the Tundra bit I did find a good spot for my Tundras.com sticker!!
    (and post 700 since Jan '19)
  5. Jul 14, 2023 at 5:53 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    I will be interested to hear your thoughts on the Dirty Deeds injectors. Mine have been smooth as silk to date. I suppose it could be argued replacing old injectors would be an improvement no matter the brand. A very worthwhile install in my opinion.
    metalpete[QUOTED] likes this.
  6. Jul 14, 2023 at 6:47 AM
    Today, I stared longingly at it over a cup of fresh ground coffee with Bourbon cream. Day one of vacation.
    bmf4069, RUSTYNUTS, 805Tundra and 8 others like this.
  7. Jul 14, 2023 at 7:04 AM
    metalpete
    ID
    I took it for a little spin last night, but am going for longer drive here shortly. Definitely feels smoother. I can't believe how much tighter these feel compared to the old ones. I know the boot was coming apart and I could almost fully rotate them, but I'm wondering if they could be too tight?
    DJenerated likes this.
  8. Jul 14, 2023 at 7:26 AM
    Couldn’t stand it. Made a trash run and rolled over 268k
  9. Jul 14, 2023 at 7:31 AM
    bfunke
    bfunke Tundra Curmudgeon
    Is that 550 cord wrap on your steering wheel?
    Tripleconpanna likes this.
  10. Jul 14, 2023 at 7:37 AM
    Why yes it is. Did the grab handles too. Steering wheel leather was beat. Couldn't find a good replacement. This is my temp/perm solution. Adds some thickness and has worn great. Been on there for years.
  11. Jul 14, 2023 at 7:39 AM
    Pics from when I first finished it. 2018
    bmf4069, RUSTYNUTS, Voss and 5 others like this.
  12. Jul 14, 2023 at 7:41 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    That’s great. You could also use that in a pinch to hold an LBJ on when the castle but falls off (reference to that FB zip-tie dude). :)
  13. Jul 14, 2023 at 7:42 AM
    All that paracord is just waiting for it's opportunity to shine.
  14. Jul 14, 2023 at 7:43 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    We appear to be slippin’ a little. No odd sounds or jerkiness. Any thoughts?
  15. Jul 14, 2023 at 7:45 AM
  16. Jul 14, 2023 at 7:47 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    OEM harness appears to be intact, so really just downstream of that (i.e., inside of the taillight area) is where the ugly begins. You can see that trailer controller (see pics below) was run up into the taillight wire area and then tied into the wires inside there, so that might actually be a lot easier to "unwind" than I was thinking.
    Somebody was doin' some trailering. It's attached to a tow hitch that is by far the most affected by rust on my truck. Going to remove it and work it over pretty good when I get a chance, but not a high priority right now.
  17. Jul 14, 2023 at 7:47 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Dang. I need to do something like this. I just wrap my steering wheel in electrical tape.
    Normal. The driveshaft "shortens" when your rear suspension compresses.
  18. Jul 14, 2023 at 7:50 AM
    https://youtu.be/MKznMb2-Tj4
    des2mtn[QUOTED] likes this.
  19. Jul 14, 2023 at 7:52 AM
    I went knots to the inside/back of the steering wheel. And his wheel is solid, ours is squishy, no need to go super tight, just tight enough to feel the first bit of give.
  20. Jul 14, 2023 at 7:52 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Ok, new goal for the C10 with the sticky GM steering wheel....going to pull that this weekend (hopefully installing the rebuilt carb and buying a battery for it tomorrow) and bring it home and see if my very crafty girls want to tackle this.....
  21. Jul 14, 2023 at 7:59 AM
    Grabbed my Paracord at Hobby Lobby. Was supposed to be more dark brown and looked like it in the store, looked gold when I installed it. Think it was even called "Canyon Brown" or something like that. takes a lot. Buy a couple 100' spools.
    oscardog86 and JasonC.[QUOTED] like this.
  22. Jul 14, 2023 at 8:01 AM
    Doing some mind blowing mods today. Vacuumed and cleaned the interior. Mounted my fire extinguisher after they finally sent the correct mount. I also repaired my fender liner. This 425 piece fastener kit from Scamazon came in clutch. I noticed it even has spare tailgate rod clips.
    bmf4069, Voss, shifty` and 3 others like this.
  23. Jul 14, 2023 at 8:10 AM
    daveeasa
    I have a spare tow controller too if you want it. Swapped to OEM parts.
    JasonC.[QUOTED] likes this.
  24. Jul 14, 2023 at 8:43 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    @daveeasa I'm going to tear into it this weekend (probably Sunday) and will let you know. May take that off your hands and also that taillight harness if mine's as gnarly as I'm expecting it to be. Really appreciate you!
  25. Jul 14, 2023 at 9:05 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Temp 12v power!
  26. Jul 14, 2023 at 12:39 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :popcorn:
  27. Jul 14, 2023 at 12:42 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Minds still in great shape BUT that looks damn good. Any tips or youtube of how to secure properly.
  28. Jul 14, 2023 at 12:51 PM
    Posted a YouTube above
    BubbaW[QUOTED] likes this.
  29. Jul 14, 2023 at 12:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Well damn if you didn’t, thanks
    KNABORES[QUOTED] likes this.
  30. Jul 14, 2023 at 2:08 PM
    metalpete
    ID
    Alright, after cruising at 50mph, stop and go driving, and acceleration after low speed turns, I am extremely happy with the injector swap.
    10/10 would do it again.
    bmf4069, FirstGenVol, NUDRAT and 4 others like this.
