  1. Jul 10, 2023 at 12:06 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    That f'kn sucks :mad:
    No likes given on that post!
  2. Jul 10, 2023 at 12:10 PM
    Tripleconpanna
    I think one of your neighbors was trying to be funny and stuck a Canadian flag on your truck.... :eek:
    We should deploy @Outbound to investigate!!! :spy:
  3. Jul 10, 2023 at 12:45 PM
    Outbound
    Aaron
    Northern Alberta
    On it.
  4. Jul 10, 2023 at 12:52 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Installed a Veepeak OBD II scanner and OBD Fusion app to monitor engine, atf pan and torque converter for when hauling the travel trailer. Drove two hours from the mountain cabin and aft/tc didnt get over 190* on 37s which makes me happy.
    Now that I can monitor the temps Im going to do a drain and fill for the transmission. What temp do I pull the overflow plug?
  5. Jul 10, 2023 at 12:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I've had a few people question them.
    The funniest was when I was helping a lady in her Corolla get unstuck at the forest where I walk out dog in the winter. I pulled out the recovery boards and fold-up shovel and got her out in 20 seconds. She asked about the gear and then asked "What's up with your truck, are you government or something?". She said there are no decals or anything and you have those Canada flags. I explained no, just took branding decals off, served in the Reserves, proud to be Canadian etc, so put on some Canada flags.
  6. Jul 10, 2023 at 1:19 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Friends/family said the same, could've been a lot worse than just metal getting shredded. Thankfully I was in the car alone.
    Right, would've completely bashed the light instead of the beloved truck.
    I can appreciate this, thank you! However you do get a like.
  7. Jul 10, 2023 at 1:39 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Washed it over the weekend and noticed a part damage. Not sure if it was a bird strike or something else but it's clearly bent and a bit dinged up. Anyone know what this part is called and how I can order it? It's not metal, it's plastic.
    Note: it's the other side and I didn't take a picture but it's definitely damaged.
  8. Jul 10, 2023 at 1:43 PM
    coTony
    Tony
    Montrose, CO
    I am wondering if my OBD Fusion is set correctly to monitor my temps. It seems mine are always 198 lately, it is hot and I did not have my OBD a working for me until about a month ago before I went to Missouri. That is when I was seeing the numbers up there. What is the norm?
    CaptRussia253[QUOTED] likes this.
  9. Jul 10, 2023 at 1:55 PM
    #7 in the diagram. You will have to get them painted. I pulled it for a 2019 SR5...they should be the same part number for all trim levels.
    https://www.sparksparts.com/v-2019-toyota-tundra--sr5--5-7l-v8-gas/body--fender-and-components
  10. Jul 10, 2023 at 1:58 PM
    Too many variables to determine an average temp. You could always delete and reenter the PIDs to see if it makes any difference.
    coTony[QUOTED] and CaptRussia253 like this.
  11. Jul 10, 2023 at 3:09 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
  12. Jul 10, 2023 at 3:13 PM
    They are clipped in. This video shows how to do it.
    https://youtu.be/fQWXMGXDnLE
  13. Jul 10, 2023 at 3:22 PM
    moodywizard
    moodywizard New Member
    Lost
    2017 Tundra 4x4 Crew Max
    Was getting ready to camp out for the weekend and worked on the awning mount. One of the cons having a mid height rack is the awning mounting. Originally had it higher by 6” but it looked goofy and was higher up than when I had stock suspensions and tires. So shortened the brackets and doesn’t interfere with rtt etc. looks longer or sticking out further more so in the pic than real life. Bonus pic of it deployed this last weekend.
    BR73, Wallygator, Richard84 and 9 others like this.
  14. Jul 10, 2023 at 3:29 PM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    Which one is this? I've looked at so many different mods I want to do that I've lost track of whats what :facepalm:
    BR73 likes this.
  15. Jul 10, 2023 at 3:29 PM
    Taco-Spike
    Two Trucks
    Automatic windows on all windows
    And all illuminated
    Mike59 and HulkSmurf14 like this.
  16. Jul 10, 2023 at 3:35 PM
    Beach Toy
    SE NC
    2017 White SR5 4x4
    The cartrim ones? Or a different brand?
  17. Jul 10, 2023 at 5:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Added some carven tr mufflers to my DD midpipe. Sounds very clean and rowdy. Next to remove the secondary cats.
    https://youtu.be/ekVEp1TE1Mw
    Helo, IsaiahCanada, Tundra-XP and 8 others like this.
  18. Jul 10, 2023 at 7:40 PM
    French Avocado
    Utah / Wyo
    Looks like flying crap on I-15 damage to me.
    Quick - order tonight before the 20% off sale ends.
    https://autoparts.lewistoyota.com/products/product/panel-fr-end-rh-l-539310c903
    You need to add something else in order to get free shippping because the 20% off drops below the $75 minimum. (I am sure you have other goodies on the list or can get maintenance items.)
  19. Jul 10, 2023 at 10:05 PM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    I'm pretty sure the temp needs to be between 100-110F. I use the same thing (Veepeak and OBD Fusion). The temps are mentioned in this Transmission Cooler Install video: https://youtu.be/5DLkja6vXvc
    Funny that you mentioned this. I just got a new toy - an Xtool D8 scanner. It gives all sorts of live data including ATF temps. I'm really impressed. https://youtu.be/IVsrqxtlcDI
    :bananadance:
    I also ordered a Fumoto valve after making a mess draining my oil. Now I know why folks here are using it. Why do I have to learn the hard way? :facepalm:
    BR73, BlueRibbon4x4, ATV25 and 3 others like this.
  20. Jul 11, 2023 at 4:37 AM
    CaptRussia253
    Ruslan
    Thanks!
    Ya I love my Fumoto valve. Takes a bit longer to drain but no mess and I just drink a beer while I wait haha
    bulldog93 likes this.
  21. Jul 11, 2023 at 5:46 AM
    Mcdqpr
    Mcdqpr New Member
    New to this thread, looking to make some upgrades to my SR5. Has anyone installed the katskin leather? How does it compare to the oem tundra leather? Is the ventilation any good?
    Thanks
  22. Jul 11, 2023 at 5:47 AM
    bulldog93 and Tripleconpanna like this.
  23. Jul 11, 2023 at 6:21 AM
    engineer
    Seattle, WA
    By the way, if you're using the OBD to monitor your truck, remember to unplug it when you shut down. If you leave it plugged in overnight, it will drain your battery. Another lesson learned the hard way...
    :annoyed:
    bulldog93 and HulkSmurf14 like this.
  24. Jul 11, 2023 at 6:45 AM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    @Beach Toy I went with Cartrim one. There's a post about it. Let try and see if I can attach a link
    toyota tundra (cartrimhome.com)
  25. Jul 11, 2023 at 7:59 AM
    Ordered the Hypertech speedo calibration unit and TackForm wireless charging phone mount. Still waiting for my parts for the AC conversion.
  26. Jul 11, 2023 at 8:01 AM
    Beach Toy
    SE NC
    2017 White SR5 4x4
    J's 4x4[QUOTED] likes this.
  27. Jul 11, 2023 at 9:40 AM
    Taco-Spike
    Two Trucks
    Happy Birthday dude :proposetoast:
    Tripleconpanna likes this.
  28. Jul 11, 2023 at 10:01 AM
    Thanks! 50 today lol.
    HulkSmurf14, ATV25, Leek128 and 6 others like this.
  29. Jul 11, 2023 at 10:09 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Installed the usb c charger to replace the rear seat cigarette lighter outlet.
    Used the heat gun to push back some of the front wheel well liner that rubs in reverse at full turn.
    Wanted to get mud flaps back on the front to protect side body so did some cutting of mud flaps to prevent rubbing as well.
    Florida AF, BR73, AggiePhil and 5 others like this.
  30. Jul 11, 2023 at 10:38 AM
    Bergy24
    Bergy24 New Member
    What usb / C charger did you end up using? Any issues with it or the install?
