New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jul 7, 2023 at 2:14 PM
    #451
    I liked this post, then unliked it so I could like it again. Let’s goooo!!!!
    G_unit3000, JasonC., bmf4069 and 3 others like this.
  2. Jul 7, 2023 at 3:21 PM
    #452
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
  3. Jul 7, 2023 at 3:55 PM
    #453
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  4. Jul 7, 2023 at 4:34 PM
    #454
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I couldn't be happier
    Everything is tight, no leaks, the suspension is smooth and the air is ice cold
    G_unit3000, N84434, bmf4069 and 11 others like this.
  5. Jul 8, 2023 at 6:39 AM
    #455
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Been awhile in catching up but kudos for where you are considering where you been....sweet job so far.
    Possibly moved on from this position but suppose you could test by having ignition coils in place and not replace 2 of 3 bolts and see result. According to EWD, that bolt passage does not appear to be used for a gnd connection.
    What you could do if you haven't already is to measure the primary/secondary resistance of the coils.
    Note to self: be cautious when pressure washing the engine bay !
    Bmktw2[QUOTED][OP] likes this.
  6. Jul 8, 2023 at 6:47 AM
    #456
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thankyou
    Okay so the bolt does not ground the coils...
    I have since thrown the old coils away but it's still good to know how to check them with the ohms meter. Thanks.
    Today I'm driving the truck to the Toyota service center to get the alignment done. I haven't installed the new front brake calipers and can tell one of them is stuck so I drove slow across town until I install it later today after the alignment service
    I'm being watched over
    shifty` and BubbaW[QUOTED] like this.
  7. Jul 8, 2023 at 1:27 PM
    #457
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The passenger side brake caliper was not releasing so I got two new calipers, pads and hoses installed.
  8. Jul 8, 2023 at 2:09 PM
    #458
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Thats a low tire. I mean, you do you, i see the value of wearing the corners, then airing up for the highway, but damn, might pull a vacuum at dead center.
    dont mind me, the tires i want are gonna let me run 60psi.
    Bmktw2[OP] likes this.
  9. Jul 8, 2023 at 3:44 PM
    #459
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I set them near what the manufacturer recommended @30psi front and rear
    I just got back from testing the truck on the interstate. Went 75mph was as smooth as can be. The rpms were at 2,500 @70mph in 5th gear.
    The truck is done. I have nothing else to do to it.
    Thank you all for every bit of the help.
    w666, bmf4069, Silet and 3 others like this.
  10. Jul 8, 2023 at 4:13 PM
    #460
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    3 pedals, I'm so jealous.
  11. Jul 8, 2023 at 5:41 PM
    #461
    That's awesome man, don’t disappear
  12. Jul 8, 2023 at 5:51 PM
    #462
    Exactly. I hope you stick around @Bmktw2 We've enjoyed watching you save this Tundra.
  13. Jul 8, 2023 at 7:41 PM
    #463
    Casper421
    In the woods
    06 DC
    Just my input with those tires, assuming they’re P rated not LT, I would set them at 34psi. You can always do the chalk test to see what’s best. And like others have said, it’s been awesome watching your progress! Stick around, you could help out a lot of the folks with v6/manual questions.
  14. Jul 9, 2023 at 6:31 AM
    #464
    Silet
    Silet New Member
    You've done an amazing job with the truck!
    Thank you!!!
    Bmktw2[OP] and KNABORES like this.
  15. Jul 9, 2023 at 6:15 PM
    #465
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
  16. Jul 9, 2023 at 7:25 PM
    #466
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Dunno, the truck he built is worth tenfold compared to one he could buy.
    Bmktw2[OP] and JasonC. like this.
  17. Jul 10, 2023 at 6:53 AM
    #467
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Yeah, totally agreed--no comparing a truck you've baselined yourself. I think am just jealous of those windoors on that camper.
    Mr.bee[QUOTED] and Bmktw2[OP] like this.
  18. Jul 10, 2023 at 7:00 AM
    #468
    Don't get too jealous, the back-end looks pretty janky on it, just SCHLOOMP! and it cuts off.
    Windoors are cool and all, but when paired with a goofy shell design, it becomes lipstick on a pig.
  19. Jul 10, 2023 at 12:15 PM
    #469
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    excellent work! im in central florida myself, i didnt know how much of a unicorn v6 4x4 manual tundras were until i followed this post and researched them haha.
  20. Jul 11, 2023 at 8:59 AM
    #470
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    After two visits to the Toyota service center they said my truck was too rusty and bent and the lower control arm bushings are bad, the truck is lifted and needs new lower control arms installed and that they could not do the alignment. They gave me my money and truck back with the passenger side camber way positive.
    Thanks to JBerry's write up and even though I ended up doing it slightly differently from him, I decided to take on the task of doing the alignment myself.
    Here's how I got the truck back from the alignment. With a positive camber on the passenger side:
    First thing I did was equal out all four eccentrics. (They had them all over the place)
    Once the eccentrics we're equaled, the wheels fell into a good camber. This truck is very straight:
    With the digital angle finder, I was able to set the camber to a -0.3 - -.04 for both sides which I was very happy with
    Next I made sure the wheel was straight then used a plumb bob, positioned on a center line printed on my new tires to make chalk marks on the concrete front and rear to get the toe
    I ended up with a 67.5" front and rear and was happy. The threads on the rack also equally spaced on the tie rod ends.
    This is how it ended up. I am happy with this:
  21. Jul 11, 2023 at 11:31 AM
    #471
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Oh Lordy, you dun gone and done it now :facepalm:
  22. Jul 11, 2023 at 1:34 PM
    #472
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    what's that
    sincerely, 4 speed owner
  23. Jul 11, 2023 at 4:32 PM
    #473
    chunk
    chunk New Member
    I just love the pooch. He / she seems to be very invested in the truck project.
  24. Jul 11, 2023 at 9:46 PM
    #474
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Don't sell us short, we have 5!
    L,1,2,3,OD :cool:
  25. Jul 11, 2023 at 10:04 PM
    #475
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Just an fyi. You want about 1/8-1/4" toe in when doing it this way.
    Also, when evening out the camber I would recommend only pulling the front two cam adjusters inward and leaving the rear ones (near steering rack) fully outwards.
  26. Jul 11, 2023 at 10:21 PM
    #476
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    What, no DIY offroad bumpers with winch???
  27. Jul 12, 2023 at 2:34 PM
    #477
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Great advice. Thankyou
  28. Jul 12, 2023 at 2:35 PM
    #478
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Considering a new rear bumper down the road due to rust. I like the look of the factory front, it's lightweight and a winch is unnecessary for what I'm doing.
  29. Jul 12, 2023 at 3:38 PM
    #479
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Coming back from a road trip to north Florida and back. Got it in 5th with the cruise set and tundras.com on the screen. Check out the RPM.
    This truck is sooo much more comfortable than my old single cab 1995 4cyl 5spd ranger with no ac or cruise
    G_unit3000, JasonC., dbittle and 7 others like this.
  30. Jul 12, 2023 at 3:39 PM
    #480
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Too beaucoup. Go back to being a hometown hero instead of a wizard.
