2023 Tundra Automatic Bed Step
Discussion in '3rd Gen Tundras (2022+)' started by djohnson1275, Feb 14, 2023.
  1. Feb 14, 2023 at 2:06 AM
    djohnson1275
    djohnson1275 [OP] New Member
    2023 Toyota Tundra 1794
    Roll n lock automatic tonneau
    Anyone have installation instructions for the Tundra automatic bed step?
    Taikowaza likes this.
  2. Feb 14, 2023 at 7:35 AM
    djohnson1275
    Thx for taking the time to help. Yes, I found one aftermarket. Right now only available through Toyota if it comes with the automatic package from the mfr. I have the 1794 with TRD package. Dealer said they can't do both due to risk of damage while off road. Impossible to find the automatic package.
    ryanwgregg likes this.
  3. Feb 14, 2023 at 8:01 AM
    djohnson1275
    Love the inserts!
  4. Feb 15, 2023 at 8:57 PM
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Fox 3.0 Camburg UCA's and Trailing Arms KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV K&N Cold Air Intake and charge pipes Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs and Focal Components 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    Smitty Built has an auto step. I bought one from 4 wheel parts. It’s a dual motor too.
  5. Feb 16, 2023 at 1:41 AM
    b0yax
    b0yax New Member
    can you link it or show an image?
  6. Feb 16, 2023 at 4:01 AM
    nodak67
    nodak67 New Member
    JR
    oem package is $1350 and included the bed step
    if you drop the bed step and do the labor yourself, the smity is comparable in price
  7. Mar 6, 2023 at 7:54 PM
    Wrutherf
    Wrutherf New Member
    How have they held up for you so far? Like them?
    How was the install - not much information on the SB site or 4wp
  8. Mar 23, 2023 at 10:25 PM
    HeavyB
    HeavyB New Member
    Joe
    I am wondering the same thing, I just purchased some online they dont show up on 4wp anymore, but $1200 vs $1850 figured I would give them a shot they have a 5 year warranty as well. I was wondering if the use the same magnet thing to trigger or something different.
  9. Mar 27, 2023 at 5:16 PM
    manih786
    manih786 New Member
    Muzammal
    Tundra 2023 1794
    just installed automatic bed step onto my Tundra 2023 1794.
    The installation instruction given to me by a Chinese guy and it worked perfect
    I have attached the instruction below
    you need to find white plug on the side on the bottom can panel.should have blue and white cable in the middle of the socket
  10. Mar 27, 2023 at 5:47 PM
    HeavyB
    HeavyB New Member
    Joe
    Where did you order it from?
  11. Mar 27, 2023 at 6:01 PM
    manih786
    manih786 New Member
    Muzammal
    Tundra 2023 1794
    4mm likes this.
  12. Mar 27, 2023 at 7:00 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    Gonna be honest, definitely not clicking on that pdf with those characters..............
    RadixRyder and doublethebass like this.
  13. Mar 27, 2023 at 7:12 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    WTF … how is that aloud on here…
  14. Mar 27, 2023 at 7:26 PM
    manih786
    manih786 New Member
    Muzammal
    Tundra 2023 1794
    Dont worry I have snapshot for that instruction too F8A35F3C-395A-421E-8AED-20EE96355C74.jpg9DCF03BA-D3C9-4919-AEBD-C4DCF961A298.jpg
    tlh1005, Henry1jg, 4mm and 1 other person like this.
  15. Jun 23, 2023 at 10:38 AM
    sampsonjw
    sampsonjw New Member
    So. I bought this bedstep off of eBay. Offered the $400 and accepted. I got it in less than a week from china. This thing is well built and sturdy. Very easy to install. The directions suck and pretty useless if you’re trying to find the right harness to hook up trigger circuit. The seller on eBay was useless. I sent several messages and they never responded even once. I have the whole kit installed and only needed the correct factory wiring to tie into. At this point the step was useless and I started a return with eBay. As a last resort I pulled the power step ecu out and took the cover off to see if I could see what the circuitry looked like for a clue to the voltage source (electrician) luckily the OEM company was written on the circuit board and I was able to contact them directly. The company is AKM4x4. They are a Chinese 4x4 supplier. I was able to talk to tech support over WhatsApp and took two seconds to find the proper tie-in
    This step works perfect and looks and acts just like OEM step.
    Mattedfred likes this.
  16. Jun 23, 2023 at 10:48 AM
    Pictures or it didn't happen! People have a hard time trusting someone with only 2 posts when the first post you had said you bought Go Rhino running boards and bed liner for $2100. Looks like product plugging with no photos.
    Henry1jg likes this.
  17. Jun 23, 2023 at 11:05 AM
    sampsonjw
    Yep. And not one person on this board responded to my question yet here I am helping others. There’s a nice way to ask and then there is your way. I’m good
    tlh1005 and abgiles like this.
  18. Jul 5, 2023 at 4:03 AM
    yukonrider
    yukonrider New Member
    Ignore the haters, do you have more info on how you did this? Which wire did you tap?
    The step comes down automatically when you open the tailgate or how does it work?
  19. Jul 7, 2023 at 4:57 PM
    sampsonjw
    Yukonrider…. The step works automatically with either the key fob, tailgate handle or tail light switch. I have been using it for two weeks now and I am super happy. The instructions from the seller are horrible but it is super easy to install if you have any mechanical aptitude. Finding the right wire to connect to was impossible until I found the parent company and they sent me pics over WhatsApp posted a couple of pics but I couldn’t upload video of operation
  20. Jul 9, 2023 at 4:34 PM
    Leatherhead237
    Leatherhead237 New Member
    Massachusetts
    2023 1794 TRD Off-Road
    Finally someone with a legitimate option. Do you have pics installed and maybe a video of operation?
  21. Jul 10, 2023 at 4:07 AM
    sampsonjw
    I have a couple of pictures and a Video that will not upload to this forum for some reason. It might be a format issue. The purple box is the control module and mounts right at the connection point behind the left hand kick panel.
    MEGA VOL and iiawah808 like this.
  22. Aug 11, 2023 at 8:03 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I had the dealer install a manual step on my 1794 TRD but they said there was no option for a powered step. Is there some way I can make it powered?
  23. Aug 12, 2023 at 10:18 AM
    Leatherhead237
    Massachusetts
    Yes, but likely not as an add to the factory manual step. I'm putting together a thread/how to on installing the import Auto Step off of eBay right now.
    Deez828 likes this.
  24. Aug 13, 2023 at 3:34 PM
    Starman2112
    Starman2112 New Member
    I have a different issue on mine (which still has under 500 miles on it). I have the step on my capstone edition but I also bought the bed extender so when I put the tail gate down, the step is out. Im wondering if theres something I missed relating to making the step stay in when the gate is down.
  25. Aug 15, 2023 at 2:29 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Just start driving and it will retract at like 3mph...
    Starman2112[QUOTED] likes this.
  26. Aug 7, 2024 at 2:07 PM
    Omnivore
    Omnivore New Member
    Aaronski
    2023 Tundra TRD Limited Edition
    That would be great to see a detailed breakdown of how to install it. I'm planning on buying one off of eBay also. There are several for sale all around the same price, but I think it may be the same or just a couple different companies selling them. Definitely a risk to buy anything from China.
    Have you had any issues with it since you installed it? Works as it should? No blown fuses or anything?
  27. Aug 10, 2024 at 12:53 PM
    billpat54
    billpat54 New Member
    2024 Toyota tundra 1794
    I have a 2024 1794 tundra with power tailgate step that is activated with tailgate drop. Has anyone figured out how to wire a switch to control the power step separately as i find when the step is not needed gets in the way and i have smashed my leg against the step several times in the month i have the truck. I am looking for the electrical schematic so i can figure out how to wire in a manual control switch. Thanks for any help provided.
  28. Aug 12, 2024 at 1:04 PM
    Leatherhead237
    Massachusetts
    https://www.tundras.com/threads/3rd...p-install-instructions-now-in-english.128910/
    honestly the thing has been money since I installed it, zero issues.
  29. Mar 30, 2025 at 4:20 AM
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
  30. Mar 30, 2025 at 7:37 AM
    Breathing Borla
    AZ
    in line fuse if right on the battery right?
