Update: Leaking main seal 2200 miles
Discussion in '3rd Gen Tundras (2022+)' started by silk, Jun 28, 2023.
  1. Jun 30, 2023 at 10:03 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    How a failed main bearing can push RMS out? In turbo engines a pushed crank/camshaft seal is due to excessive crankcase pressure, which indicates a failed or under-delivering PCV.
    PCV in turbo engines not only have to evacuate more blow-by gasses than in N/A engines, but it also has to be several times more complex, because there's simply no vacuum anywhere in the system when a turbo spools. Turbo fresh air inlet is the only unassisted point that have any vacuum, but it is insufficient in most cases.
    eddiefromcali likes this.
  2. Jun 30, 2023 at 10:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Unless pressure relief valve is sticking in the oil pump. In that case it lets the oil out at high RPM and then does not reset back promptly when RPM drops, which leaves the bearings without oil pressure.
  3. Jun 30, 2023 at 10:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    This is bullshit.
  4. Jun 30, 2023 at 3:42 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    No.
    Breathing Borla likes this.
  5. Jun 30, 2023 at 4:03 PM
    Breathing Borla
    AZ
    Me either I just ran to Costco and boosted like a mofo, if it breaks oh well
    Polo08816, pwpblue and iiawah808 like this.
  6. Jun 30, 2023 at 4:06 PM
    ArmygreenTRD
    Exactly. That is what warranties are for. If worried, buy the extended.
  7. Jun 30, 2023 at 4:13 PM
    Breathing Borla
    AZ
    This boost shit is fun, haven’t been in a turbo car since we had a TT SUPRA , turbo all trac celica manual , turbo mr2, etc
    I’m blending my breakin between easy and drive it like you stole it , let’s set those piston seals , ha!
  8. Jul 6, 2023 at 2:28 PM
    silk
    silk [OP] New Member
    2023 Lunar Rock TRD
    UPDATE: Dealer had the Toyota Rep. onsite to look over the truck, they did determine that it does have a oil leak, they are not sure from where until they tear it down. They indicated it is either the RMS or the housing around the seal. What a bummer, ever thought I would have a new truck with just over 2000 miles needing a tear down. Thanks Toyota !!!
    Polo08816, IsaiahCanada, Kap1 and 3 others like this.
  9. Jul 6, 2023 at 3:11 PM
    xc_tc
    xc_tc New Member
    This is really nothing new for Toyotas. There are a lot of 2GR engines that suffered oil leaks from the front engine cover. There are a ton of 3UR with oil leaks from the cam towers. Toyotas do last a long time and Toyota does stand by their product and tries to fix the issues that arise. I wouldn’t worry too much but do ask for more warranty.
  10. Jul 6, 2023 at 4:44 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    What a calm and measured remark. You didn't suggest suing anyone?
    MVRCA, Lovci, Polo08816 and 3 others like this.
  11. Jul 6, 2023 at 4:45 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    He’s currently arming the rebels. This is just his public persona.
  12. Jul 6, 2023 at 4:53 PM
    BoulderGT3
    Glen
    Crafty he is.
  13. Jul 6, 2023 at 4:57 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Or demanding a FrEeEeE TrUcK????
    Madness! :D
    ZappBrannigan likes this.
  14. Jul 8, 2023 at 5:54 AM
    BMP
    BMP New Member
    2023 Tundra SR5 SX MGM CM 4X4
    Or wait for the 24's.
    Brad
    Polo08816 likes this.
  15. Jul 8, 2023 at 6:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  16. Aug 16, 2023 at 4:46 PM
    noobtin
    noobtin New Member
    2023 SR5 TRD Off Road
    My lift outfitter saw this on when installing my lift @4,000 miles. Went to Toyota for them to look at it, and here’s the response I got today:
    “Hello! So my manager was in contact with our reps from Toyota corporate. They told us it is a known issue on the 2023 Tundra. There is an adhesive that they use, so when it warms up it melts and tends to look like a rear main seal leak. What they recommended is that we clean it up and you drive it for roughly 1,000 miles so if it does continue to leak we know it isn't that common issue. I hope this helps out, I will be off tomorrow but you can most definitely stop by and pick up the vehicle. “
    I will keep y’all updated after I drive it for another 1,000 miles.
    Leo's first, raylo and pwpblue like this.
  17. Aug 16, 2023 at 5:02 PM
    katekebo
    katekebo New Member
    The problem with 2GR timing cover leak is that owners are stuck with $4k repair. I ran a poll on Toyotanation and about 1/3 of owners report a leak. The repair is expensive because it requires dropping the subframe, engine and transmission to access the cover. Toyota has known about this problem since 2005 and never fixed it because most of the leaks start after warranty expires (or owners don't notice it until then), so Toyota's approach has been "not my money, not my problem". I actually reached out to some lawyers to see if we can initiate a class action suit and make Toyota extend the warranty for this specific problem to 10 years / 120k miles.
  18. Aug 16, 2023 at 5:13 PM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    ...sounds like they don't really know.
  19. Aug 17, 2023 at 6:35 AM
    silk
    2023 Lunar Rock TRD
    Update on this topic ... Toyota Corp/Tech requested the dealer to drop my transmission to assure it wasn't the rear main seal. Once removed they determined it was residual oil from the assembly process, they had me come in to see what they seen. The cleaned all the oil out (they tried before removing the transmission however the weep hole in the bell housing angles at a slant so they couldn't properly clean it without removing the transmission). No more oil residue. According to the Tech Toyota changed the assembly process to assure this wouldn't be an issue for the future builds.
    ZappBrannigan, BoulderGT3 and raylo like this.
  20. Aug 17, 2023 at 6:49 AM
    #50
    BoulderGT3
    Glen
    Compare and contrast to what Ford would do with an F150. It would take 8 weeks to get and appt to have them tell you they have no idea and another 4 weeks to get a ruling from Dearborn on what to do. Toyota handled it well for you.
  21. Aug 17, 2023 at 6:57 AM
    #51
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well don’t let it be said that they didn’t take care of you.
  22. Aug 17, 2023 at 7:05 AM
    #52
    silk
    2023 Lunar Rock TRD
    I agree!! I have a good friend that is a tech for a local Ford dealer, he couldn't believe it, said Ford would have had a "wait and see" for the next 36,000 miles :)
    BoulderGT3 and Breathing Borla like this.
  23. Aug 22, 2023 at 10:53 AM
    #53
    iforceAZ
    iforceAZ New Member
    Mine at 3700 miles. Very small amount. I will monitor.
  24. Aug 22, 2023 at 12:14 PM
    #54
    silk
    2023 Lunar Rock TRD
    40man .. great question! Believe me that was my first question!! The assy. oil would actually show up with the black light, what they didn't pick up was it is a different color than the dyed that they put into the motor oil. I didn't believe it until I seen it.
    Mattedfred likes this.
  25. Aug 23, 2023 at 3:41 PM
    #55
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Pull the dip stick, flash some black light on it and compare?
    pwpblue likes this.
  26. Aug 24, 2023 at 6:51 AM
    #56
    PikesPeakTRD
    PikesPeakTRD New Member
    23 Hybrid Limited TRD OR MGM
    Hope this “assembly oil” theory is correct because mine is doing it too. :-/
  27. Aug 24, 2023 at 11:40 AM
    #57
    silk
    2023 Lunar Rock TRD
    The dealer also wanted me to see the truck apart before they cleaned any of the oil residue off. I could wipe a clean white cloth around the RMC and plate, nothing. All the residue was at the bottom of the bell housing, it surely wasn't engine oil.
    40man and Mattedfred like this.
  28. Jan 31, 2024 at 9:04 AM
    #58
    Meskimo2021
    Meskimo2021 New Member
    I purchased a 2022 Tundra back in October of 2022, I have roughly 36,000 miles on it. October 19th of 2023 my engine went out and I had it towed to a Toyota dealer, after Toyota investigated the the problem it was discovered that the engine bearing wasn’t machined properly and wrecked the engine. After 3 months of Toyota having my vehicle they finally put it back together and test drove it. After they test drove the truck they noticed oil leaking from the rear main seal, so now they are currently working on that issue.
  29. Jan 31, 2024 at 10:01 AM
    #59
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    My 2003 tundra was solid, didn't care how badly I abused it. Multiple 4Runners and hundreds of thousands of miles, never an issue. I started offroading my '19 4R with fewer than 50 miles on it, and it never developed an interior rattle. That thing was as solid and well put-together on the inside as it was mechanically.
    The '23 tundra would be close if I could remedy the rattling driver window run and center console latches.
  30. Jan 31, 2024 at 11:28 AM
    #60
    AZBoatHauler
    So.Arizona
    Post the info on your engine failure here for tracking purposes.
    https://www.tundras.com/threads/3-4-i-force-engine-failures.121107/
