4.7L Fuel Economy?
Discussion in '1st Gen Tundras (2000-2006)' started by BlueRay04, Jun 5, 2023.
  1. Jul 3, 2023 at 2:13 PM
    #91
    I got 16.7 MPG on the way to Florida Saturday. I like to believe my pawpaw cap helps my mileage.
    BlueRay04[OP] and abcinv like this.
  2. Jul 3, 2023 at 4:06 PM
    #92
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Good looking truck. I would rather have a cap like that, but opted for a locking roll up tonneau cover. Like the look of the cap but the practicality of toting large items is a plus. I'm sure those caps come in handy for camping if you wanted to sleep in the bed.
  3. Jul 3, 2023 at 4:40 PM
    #93
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    2001 stock gen 1, 2WD. I usually see around 15's mixed driving, sometimes a bit higher with more highway. My last tank was 90% highway, 65 mpg, cruise controlled. I calculated 18.2 mpg, a personal best. I rechecked the calculations to be sure.
    BlueRay04[OP] likes this.
  4. Jul 6, 2023 at 3:37 AM
    #94
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My last tank i was able to get about 16, had to make sure i could still go 300 miles, ended up going 320 on 20 gallons without getting the fuel light. Really uncomfortable running it under the 1/4 tank mark. I prefer to fill up closer to 1/2 tank, to keep the pump happy.
  5. Jul 6, 2023 at 6:46 AM
    #95
    Anvilhead
    Anvilhead New Member
    '03 Tundra 2WD Access Cab V8
    None
    It's my wife's truck. That means it's anyways on E when I get in.;)
    moresnow, abcinv and Riverdale21 like this.
  6. Jul 6, 2023 at 6:58 AM
    #96
    shifty` Bohannon Bohannon Bohannon Bohannon
    Nice truck, and welcome to the forum! Curious, what brand/model of cap is that?
  7. Jul 6, 2023 at 7:09 AM
    #97
    Anvilhead
    None
    Thanks. All I know is it says Vista on the back window.
    The cap came with the truck. I think Toyota had a deal. When we moved to Texas for a short while there were two identical trucks in our small town. Same color as ours. Got confusing a couple of times in the H-E-B parking lot.
  8. Jul 13, 2023 at 8:46 PM
    #98
    Tundraip
    Tundraip New Member
    17.1 mpg last time with hypermiling on mix driving.
    Usually 15mpg.
  9. Jul 13, 2023 at 9:23 PM
    #99
    BmBlB
    BmBlB New Member
    2006 White DC Limited
    2006 DC running 33" tires, I have averaged 12.6 mpg with the best tank at 17.6 mpg. That's over the last 4 years or so.
    I use fuelly.com. I can text at each fill-up and get the last tank and historical average sent back to me in seconds. Go here <https://www.fuelly.com/car/toyota/tundra/> and you can browse for your year and see what other folks are getting for MPG.
  10. Jul 14, 2023 at 3:33 PM
    #100
    Xcruiserguy
    Xcruiserguy New Member
    Pete
    Ontario, Canada
    ‘06 DC SR5
    Bilstein 6112/5100, SPC UCA, Sumo Springs, 265/75/16 Nokian Outpost AT, ARE cap. DD/335k km
    2006 4.7, DC, 31.5 tires (265-75-16), averaging 19-20 mpg over the last couple of months. Mostly rolling and curvey 2-lane/45-55 mph roads to and from work. Highway driving at 65 clicks gives me over 20.
  11. Jul 14, 2023 at 3:38 PM
    #101
    Tundraip
    Tundraip New Member
    That’s very high!
    Elevatorguy likes this.
  12. Jul 14, 2023 at 4:03 PM
    #102
    Xcruiserguy
    Pete
    Ontario, Canada
    ‘06 DC SR5
    I try to use a light right foot, and CC when traffic is light, which is usually the case during my commute time (early morning/mid-afternoon).
    If I had that engine in something smaller and more nimble, however, the milage would be in the low teens because I’d be digging into the revs every chance I had, lol.
  13. Jul 16, 2023 at 9:50 PM
    #103
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've hauled a trailer with every tank I've run through the truck in the last few months. My gas mileage right now is so bad I'm not even calculating it. From full to quarter tank is about 200 miles.
    The good thing is that when I'm pulling a trailer there's something fun on it so I try to think more in smiles per gallon.
  14. Jul 24, 2023 at 3:38 PM
    #104
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    Just took a trip from Tn to Co and back Odometer reading 2501 miles 156.3 gallons of fuel 16.0 MPG. When adjusted for tire size 2624 miles 156.3 gallons of fuel 16.79 MPG. 2006 DC 2WD
    157000 on the truck. Changed diff fluid, diy transmission flush, flushed the power steering, flushed brake fluid. Put in new denso radiator, denso fan clutch, belt and idlers before trip. timing belt has about 20k.
    Truck ran perfect
    shifty` and FirstGenVol like this.
  15. Jul 24, 2023 at 7:54 PM
    #105
    Tundraip
    Tundraip New Member
    Broke my personal record! 20 mpg on mostly freeway!
  16. Jul 27, 2023 at 11:39 AM
    #106
    Aerindel
    Aerindel New Member
    Montana
    Towing......I get 7.5
    which is.....fun....
  17. Jul 27, 2023 at 11:47 AM
    #107
    Casper421
    In the woods
    06 DC
    Have you weighed your homemade trailer yet?
  18. Jul 27, 2023 at 12:40 PM
    #108
    Aerindel
    Aerindel New Member
    Montana
    No....but its a 3.5K trailer, and fully loaded you can't see any flex on the springs.....so its not heavy.....I think its mostly air resistance.
