New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jul 2, 2023 at 4:51 PM
    #421
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    First 3rd member removed:
    Second 3rd member removed:
    Both chunks:
  2. Jul 3, 2023 at 2:20 AM
    #422
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  3. Jul 3, 2023 at 2:43 AM
    #423
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
  4. Jul 3, 2023 at 7:07 AM
    #424
    Mmmmm.... I can smell the used gear oil from here :rofl:
    The Black Mamba and Bmktw2[OP] like this.
  5. Jul 3, 2023 at 8:12 AM
    #425
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Yeah me too :puke:
    I got the 4.10 in the new housing and everything is right and tight.... Now I need to muscle this heap up under the truck
    The Black Mamba likes this.
  6. Jul 3, 2023 at 10:05 AM
    #426
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    My brother showed up just in time to help me pick the axle up, set it on the jack and position it in place. It is in! It's great to have a brother.
  7. Jul 3, 2023 at 10:18 AM
    #427
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I just wanted to comment how bad the condition of the original axle was after I took it all apart:
    The housing was rusted through and leaking, the brake lines snapped when I tried to undo them at the wheel cyls, the driver side leaf spring was broken at the rear pigtail, the wheel cylinders were rusted and seals blown and an outer axle bearing was bad.
    What a relief it is to have a whole new everything under there!
    bmf4069, shifty`, FirstGenVol and 2 others like this.
  8. Jul 3, 2023 at 10:36 AM
    #428
    Rust has killed more first gen Tundras than anything else. It's awful.
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  9. Jul 3, 2023 at 10:37 AM
    #429
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I think I saved this one just in time
    bmf4069, Silet, shifty` and 1 other person like this.
  10. Jul 3, 2023 at 11:55 AM
    #430
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    To be honest, apart from the paint, I think you have a pretty brand new truck at this point....
    Bmktw2[QUOTED][OP] likes this.
  11. Jul 3, 2023 at 12:03 PM
    #431
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Everything is connected, tighted up and the axle is full. Now all that's left is to bleed the brakes
    The puddle under the axle is the stain from the old unit. This axle is sealed tight
  12. Jul 4, 2023 at 3:31 PM
    #432
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I was planning to remove the exhaust to work on it. When I tried to undo the catalytic converter from the crossover, the bolt snapped. The stud was still left in the flange. I diddnt want a leak later down the road so I worked to remove it all together.
    My idea was to weld a nut on the broken stud and back it out....
    If at first you don't succeed, try and try and try and try and try and try and try and try and try and try again.
    If that doesn't work, try something else.
    I ended up having to completely drill the bolt out. It just refused to thread out!
    Here, after 4 hours, I have the new bolt installed. It was a bad situation in a tight spot:
    While I had the welder out, I made some repairs to a flange and a couple hangars
    The exhaust is all tight and good to go for a little while. I am satisfied...
  13. Jul 4, 2023 at 4:57 PM
    #433
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Tried to go for a maiden voyage but when I pressed the clutch, one of the hard hydraulic lines from the master to the slave busted from a rust spot and the pedal went to the floor.
    I was suspect this would happen so I already ordered a new "master to flex hard line" from mcGeorge Toyota. Should be here on the 7th....
    Also ordered a pair of new 2005 year model 13wl calipers, hoses and pads. Should be here right at the same time as the clutch line.
    bmf4069, w666, Winning8 and 1 other person like this.
  14. Jul 4, 2023 at 4:58 PM
    #434
    Bummer, but it couldn't have happened at a better time/place...
  15. Jul 4, 2023 at 10:54 PM
    #435
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Make sure that breather cap is free or just replace for peace of mind. Could also extend it up behind the tail light if you plan to do some water crossings.
    I really thought I remembered you saying you had the big brakes already.
  16. Jul 5, 2023 at 3:54 AM
    #436
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I'll check the breather, thanks.
    Yes it has the 13wl brakes already but the bleeder is rusted frozen on the passenger side so I could not bleed the caliper and they look so rusty I'm afraid of having issues with them seizing up down the road
    Even the dog agrees...
  17. Jul 5, 2023 at 4:24 AM
    #437
    That's about par for the course. We spent 3 days replaced everything in my suspension and steering. Put it on the ground and the power steering hose popped. Go figure. :rolleyes:
  18. Jul 5, 2023 at 4:52 AM
    #438
    w666
    Maryland
    How the hell did that truck get so rusty in Florida?
  19. Jul 5, 2023 at 5:09 AM
    #439
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The PO lived right on the water and the owner before him lived in new york and the truck sat a lot
  20. Jul 5, 2023 at 5:39 AM
    #440
    I'm surprised whomever replaced the frame didn't do the brake lines. They're supposed to be replaced along with the frame.
    Bmktw2[OP] likes this.
  21. Jul 5, 2023 at 5:45 AM
    #441
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Give those rotors some wire brush love.
  22. Jul 5, 2023 at 6:22 AM
    #442
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    10.4 Mr.Bee
    Toyota replaced the frame... and yes they did install new fuel lines and brake lines back in 2016. I don't know exactly how they got so rusty.
    Toyota should have replaced the lines with stainless steel IMO. It's not that expensive.
    I have inspected the rest of the lines and they appear to be in perfect condition since they were replaced with the frame and located higher up.
  23. Jul 7, 2023 at 12:26 PM
    #443
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I got the new hydraulic line and it's an exact match. Installing it took me about 3 hours. That was not fun at all.
    Now I'm having problems with the clutch pedal. It just slams to the floor and stays there. I have the bleeder open on the slave, the master resevuar full and the back of the truck jacked up to level out the master cyl. I've been pumping the pedal like crazy but still nothing coming out of the bleeder....
  24. Jul 7, 2023 at 12:30 PM
    #444
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Clutch need to open bleeder and paddle down then close bleeder and paddle up til you get fluid shoot out. 2 man job
  25. Jul 7, 2023 at 12:35 PM
    #445
    I'm curious if all that rust on the driveshaft will present an issue anytime soon with any balancing or U-joint issues. Maybe not.
  26. Jul 7, 2023 at 1:22 PM
    #446
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Let it gravity feed for an hour and then hooked up the bottle and fluttered the pedal down at the bottom a bunch and then the fluid started to flow. I got it now
    Flushing out the old fluid
    Pumping pedal from bottom
    bmf4069 and shifty` like this.
  27. Jul 7, 2023 at 1:23 PM
    #447
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    That's no issue
  28. Jul 7, 2023 at 1:24 PM
    #448
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    One man army here
    shifty` likes this.
  29. Jul 7, 2023 at 2:09 PM
    #449
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The truck is about to leave the driveway for the first time:
  30. Jul 7, 2023 at 2:12 PM
    #450
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
