  1. Jul 4, 2023 at 9:15 AM
    shifty` Goons of Hazzard
  2. Jul 4, 2023 at 9:23 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    Speaking for myself, I've found my night vision isn't what it used to be. The LEDs give a significant improvement in lighting the way, mine are noticeably brighter. Also, if you adjust the headlights correctly you won't blind anyone.
    abcinv[QUOTED] and shifty` like this.
  3. Jul 4, 2023 at 2:06 PM
    daveeasa
    Swapped my battery from the 31 I had to a 27F, replaced passenger airbag (still need to reset it) and installed a new headlight harness which unfortunately does not work :(
    one wonders if any progress was actually made.
    Methinks, from probing, that I’m actually power switched. Ooops.
    Tripleconpanna likes this.
  4. Jul 4, 2023 at 7:07 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    @shifty` I got rid of those cones as soon as I saw them. I mean whose idea were those?
    shifty` likes this.
  5. Jul 4, 2023 at 7:26 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    did your lights work after swapping the integration relay?
  6. Jul 4, 2023 at 7:47 PM
    daveeasa
    Yep, worked great with the old harness. My bad for assuming we were all ground switched I guess.
  7. Jul 4, 2023 at 8:03 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Retrofit all the things!
  8. Jul 4, 2023 at 8:19 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    shifty`[QUOTED] likes this.
  9. Jul 4, 2023 at 9:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Old folks and children deserve it the most.
    bmf4069, Tundra2 and Tripleconpanna like this.
  10. Jul 4, 2023 at 9:11 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    hey... he's not that old; plus when he looked over at the other guys, I'm pretty sure it was the look of 'laugh now, but i've got something for you'!!!
    DJenerated[QUOTED] likes this.
  11. Jul 4, 2023 at 11:05 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My headlights were terrible. Couldn't hardly see with them. Never had issues with my daily driver though so I knew something was different. I tried cleaning my lenses with minimal improvement. Did the 100 watt upgrade with a aftermarket relay harness, still junk. Getting new housings and doing the projectors made a huge difference. I would have happily left mine alone but they just weren't cutting it.
  12. Jul 4, 2023 at 11:12 PM
    artsr2002
    'Yonder
    Ever since I did my first retrofit with cheap Amazon projectors and headlights for a Nissan Frontier that I had at the time, I have been upgrading lights on my vehicles. I will look around for reviews and videos of best LEDs to use for a particular vehicle through the use of forums. Headlight Revolution has been a great resource of quality videos showing the massive improvements that lighting has made over the years. If I can get away with LED bulbs that don't create dangerous glare for other other drivers, I'll go that route and if not, I don't mind trying to retrofit a pair of lights for my own vehicles. Its easy as long as your headlights aren't sealed with Permaseal sealant. Those are a bitch to take apart and require many heating cycles at lower temps. The lights I have used on my olden Tundra though have all been sealed with butyl rubber and that stuff is easy to take apart.
    DJenerated likes this.
  13. Jul 4, 2023 at 11:46 PM
    artsr2002
    'Yonder
    I love it when my vehicles have separate high beams. This allows me to use very bright high beam LED bulbs even if they don't have razer sharp cutoff because, 1) I don't roll around in my 64 with the high beams on, 2) I love the instant on of LEDs for flashing vehicles to give them a heads up that Tundra2 took out another deer just down the road, LOL, I kid of course, and 3) during night driving, I want a wall of light out in front of me when driving home out in the sticks and there aren't any other vehicles and the only ones complaining of glare are the critters on the side of the road thinking of running out in front of me.
    Tundra2 and DJenerated like this.
  14. Jul 5, 2023 at 12:17 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'd like my fogs & aux lights to strobe.
  15. Jul 5, 2023 at 12:19 AM
    artsr2002
    'Yonder
    Just flick the switch on and off really fast. Adjust speed accordingly. :D
    Mr.bee likes this.
  16. Jul 5, 2023 at 12:21 AM
    artsr2002
    'Yonder
    I remember one time my cousins turn signal switch on his El Camino stopped working. He manually switched the turn signals on and off every time he went to make a turn. Lol. No problems just solutions.
  17. Jul 5, 2023 at 1:09 AM
    DJenerated
    Dija
    The Lone Star State
    I'd like my fogs to turn on anytime and stay on with my hi beams on
  18. Jul 5, 2023 at 1:14 AM
    artsr2002
    'Yonder
    Relays yo.
  19. Jul 5, 2023 at 2:11 AM
    DJenerated
    Dija
    The Lone Star State
    I'm not an electrician
  20. Jul 5, 2023 at 2:16 AM
    artsr2002
    'Yonder
    When I had my Tahoe I hated that the lows would turn off when the high beams were engaged. I get on the forums, forums are awesome, and found a how to. Using a diode, all I had to do was jam it in where the low beam relay and high beam relays were located in a specific orientation between two specific pins of the relays and boom, quad high beams. The diode would cause the high beam relay to re-energize the low beam so I had a wall of light with all 4 bulbs a burnin'! Noice!
  21. Jul 5, 2023 at 2:17 AM
    artsr2002
    'Yonder
  22. Jul 5, 2023 at 3:35 AM
    DJenerated
    Dija
    The Lone Star State
    KingSequioa007 likes this.
  23. Jul 5, 2023 at 6:50 AM
    Good time to point out @Headlight Revolution is also a Vendor on the forum. Their subforum is a bit sparse but they have been known to respond to folks on here.
  24. Jul 5, 2023 at 7:47 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I had this same problem. Thought the Tundra headlights were garbage and couldn’t understand why people online were saying they were pretty good.
    turns out my drl relay was bad causing my headlights to be dim all the time.
    ended up doing projectors but this may help others with dim headlights.
  25. Jul 5, 2023 at 7:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, this. All the things
  26. Jul 5, 2023 at 8:11 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    If you don't install them upside down they work even better. :/ I was busy with kids and parade stuff yesterday so I rushed the install; I tested mine last night and my truck looked like it was sending up searchlights. Had to turn them off so Batman didn't show up at my house.
    NUDRAT, bmf4069 and SateenC1[QUOTED] like this.
  27. Jul 5, 2023 at 8:14 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    This was before my new dbag sylvanias.
    oncomers wont mind if i spread to cover more of the other shoulder.
    artsr2002, bmf4069 and JasonC. like this.
  28. Jul 5, 2023 at 8:42 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Also, were anyone else’s headlight connectors this covered in grease? Good grief. Took me a while but I got all the external stuff off and cleaned up the four wire looms too (2 headlights and 2 side markers).
    artsr2002, KNABORES, Mr.bee and 3 others like this.
  29. Jul 5, 2023 at 9:03 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    That's dielectric grease...it helps keep moisture and other schmootz off the contacts. Now that you've got it all cleaned off nicely, go buy a tube and slather it on!
    Tundra2, abcinv, bmf4069 and 4 others like this.
  30. Jul 5, 2023 at 9:12 AM
    Super lube is another that’s dielectric and edible/food safe in case your hungry
