5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jun 5, 2023 at 6:05 PM
    #1501
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Great quality, but pricey these days! PM me a 25% off code and you have yourself a deal lol.
    :cheers:
  2. Jun 13, 2023 at 5:10 AM
    #1502
    Genuine Cooling Systems [OP] New Member Vendor
    Congratulations to @ATV25 , he was our lucky winner! Thank you all, we will try to do something like this again.
  3. Jun 13, 2023 at 5:27 AM
    #1503
    Kung
    KG, VA
    Argh! That's what I get for not checking this site. :/ Moving in a month or two and this would've come in handy. Ah well, you win some, you lose some. :)
  4. Jun 13, 2023 at 5:57 AM
    #1504
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I want to thank GCS for this. I can't wait to get my mitts on the cooler. I will update on the installation. Once again THANKS !!!
  5. Jul 2, 2023 at 9:01 AM
    #1505
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    My brother and I got mine installed yesterday. We couldn't really get the truck that high off of the ground which made it a bit more of a pain, but we got her done.
    bulldog93, Spyker, Leek128 and 7 others like this.
  6. Jul 2, 2023 at 10:28 AM
    #1506
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    I was going to do mine this weekend but we're having temperatures in the 110°s. I think I'll wait. HAHA
  7. Jul 2, 2023 at 12:16 PM
    #1507
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Yea I did mine in the Florida heat unpleasant. But simple job just kinda tedious.
    ATV25[QUOTED] likes this.
  8. Jul 2, 2023 at 10:42 PM
    #1508
    MattAK
    Alaska and Utah
    '19 SR5 DC White
    Did some driving around in the Utah mountains today for about four hours or so. High temps today were in the low 90's in the valley and almost as hot in the mountains. Previously I'd see pan temps around 215-220 and torque converter temps getting up into the 240's on these drives. Today I didn't see the pan get over 195 and the TC made it to 205-210 once or twice. I am a satisfied customer. Also no leaks, huzzah!
    M3Tundra-JK, Lemuel1 and ATV25 like this.
  9. Jul 3, 2023 at 3:24 AM
    #1509
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Installed my kit yesterday...100 degrees....very easy install....took me probably 30 seconds with the hard lines so....I was in luck....now putting the skids and cat protection plate back on....that's another story...lol
    ATV25, Chip_Tundra and Lemuel1 like this.
  10. Jul 3, 2023 at 6:25 AM
    #1510
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I have skid plates, (full cbi offroad), guess those will have to get removed I am guessing.
    on average how long do these installs take?
    I have a 2020 tundra crewmax on 35s and stock gears. In Texas summers I see 245-250 degrees.
    anyone with the 15 or 20 row kit experience over heating the engine after install?
    looking to regear and then do this kit after, hopefully the full 20 row kits are available by then.
  11. Jul 3, 2023 at 6:41 AM
    #1511
    bflooks
    bflooks New Member
    Metrowest MA
    What is your question regarding overheating the engine after install?
    If based on location of the cooler, I can assure you that this is not a problem based on a few years of towing with the 15-row install, in ambient temps ranging from 45* to 102* F, running between 55 and 95% load on average. Coolant temps remain between 185 and 198.
    If based on something other than cooler location, I'm curious to hear about it.
    nobodyintexas and NoMoreGreen like this.
  12. Jul 3, 2023 at 6:45 AM
    #1512
    NoMoreGreen
    Robert
    2020 Tundra
    purely based on location and reduced? Airflow by stacking radiators.
    I would think if the 20 row caused problems the 15 row users would notice a change.
    I’m not a mechanic by trade, so I could be in the wrong ball park with this concern. You pretty much just convinced me it’s a non issue though.
    there are fan kits available for these radiators though as well.
    bflooks[QUOTED] likes this.
  13. Jul 3, 2023 at 6:46 AM
    #1513
    RollTide82
    Michael
    2019 Tundra 4x4
    Took me 4 hours or so.....an hour was the skids...
    NoMoreGreen[QUOTED] likes this.
  14. Jul 3, 2023 at 7:06 AM
    #1514
    yakeng
    yakeng 3URFE Apologist
    Similar results here.
    Lemuel1 likes this.
  15. Jul 3, 2023 at 7:18 AM
    #1515
    bflooks
    bflooks New Member
    Metrowest MA
  16. Jul 3, 2023 at 7:32 AM
    #1516
    bflooks
    bflooks New Member
    Metrowest MA
    I'm not a mechanic, either. Here's what I think is at play (based on my experience):
    1) factory coolant system has a healthy margin built in, including to run the latest "puck" as only trans cooler (225-250*)
    2) the new trans cooler doesn't block all air flow, just reduces it some, over a relatively small area
    3) with the trans cooler, trans temps nearly match the coolant temp - this makes the "puck" operate at about 0% designed load, more than making up for the reduced airflow addressed in #2.
  17. Jul 3, 2023 at 8:25 AM
    #1517
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Reminder I have a 20-row kit for sale, hardly used
    bulldog93 likes this.
  18. Jul 3, 2023 at 8:55 AM
    #1518
    bflooks
    bflooks New Member
    Metrowest MA
    I'm surprised this kit hasn't moved yet.
    I just need the bracket, otherwise I'd be all over this. Good opportunity for someone to get a kit with limited offering
    M3Tundra-JK[QUOTED] likes this.
  19. Jul 3, 2023 at 7:58 PM
    #1519
    To celebrate the 4th of July, we are having a FLASH SALE! The last 4 kits in stock are 10% off with coupon code "america". The flash sale officially starts tomorrow, but you are getting early access. Act quickly, they will likely go fast.
    Have a safe and happy 4th of July!
    bulldog93, yakeng, Bammer and 3 others like this.
  20. Jul 17, 2023 at 10:58 AM
    #1520
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    I installed the cooler on my 2020 Tundra.
    I have the Veepeak OBD reader and I’m using with the OBD Fusion app to read the ATF pan temp.
    Is there a way to monitor both the ATF fluid going out to the cooler and also coming back from being cooled?
    Do these readings even exist in the diagnostic system?
  21. Jul 17, 2023 at 11:19 AM
    #1521
    Chip_Tundra
    Chip_Tundra New Member
    Yes, with a scangauge.
    The temp going out to the cooler can be read by the pan temp. The temp coming back to the cooler can be read via torque converter.
  22. Jul 17, 2023 at 11:25 AM
    #1522
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    The fluid temperature going out to the cooler would be the torque converter temp. The returning fluid temperature would be the pan temp.
  23. Jul 17, 2023 at 11:44 AM
    #1523
    2TunGet1
    Awesome, thank you.
  24. Jul 17, 2023 at 12:48 PM
    #1524
    2TunGet1
    Thank you both, I appreciate it.
  25. Jul 19, 2023 at 1:30 PM
    #1525
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Is there anyone who has installed this kit and wants to part ways with this spacer? It's what gets removed and replaced with the thermostat on the trans. I'm going to be trading my truck in and I would love to pull off the cooling system to sell separately, but like a dummy, I tossed this piece and Toyota wants over $300 for it.
  26. Jul 20, 2023 at 5:58 AM
    #1526
    Bammer
    Monroe, CT
    I think I still have it, I'll check when I get home from work.
    EatSleepTacos[QUOTED] likes this.
  27. Jul 20, 2023 at 6:36 AM
    #1527
    EatSleepTacos
    Randy
    West Valley, AZ
    Thank you! That would be very helpful.
  28. Jul 29, 2023 at 8:19 AM
    #1528
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    @Genuine Cooling Systems thanks for the quick delivery and help! What a wonderful kit, this is really sweet, comes with everything you need! Going on my 2015 1794 that's fully built motor and trans with 700+ whp. Protecting my invest is what I told the wife.:rofl:
    :burnrubber:
  29. Jul 29, 2023 at 8:43 AM
    #1529
    2TunGet1
    You’re going to love it. Easy install, I did it without lifting my truck up. And the support you get from Genuine Cooling Systems is second to none. They were there every step of the way with quick responses to every question I had.
    Winks4x4Toy[QUOTED] likes this.
  30. Jul 29, 2023 at 8:44 AM
    #1530
    Winks4x4Toy
    Maryland
    First class service!
