New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jun 29, 2023 at 12:57 PM
    #391
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Well I tried to install the wheels but the old lug nuts do not fit the new wheels. I ordered up some socket type lug nuts but they won't arrive until Saturday. Will be working on the ac system getting it charged and whatnot until then...
  2. Jun 29, 2023 at 5:37 PM
    #392
    Called it! Good job sir.
    shifty` and Bmktw2[QUOTED][OP] like this.
  3. Jun 29, 2023 at 6:09 PM
    #393
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Yes you did. One bad coil drops two cylinders.
    Just wild how two coils went out at the same time
    bmf4069[QUOTED] likes this.
  4. Jun 29, 2023 at 7:48 PM
    #394
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Water inside the pack from pressure washing probably. Once they short, they're done for.
  5. Jun 29, 2023 at 8:13 PM
    #395
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I know that the v6s call for plugs like this
    I'm not sure why or what the difference really is but that is what it calls for.
    Glad it's good and running now though. Haven't been super active in your thread but have enjoyed seeing the truck come back around. Good luck going forward.
    Bmktw2[QUOTED][OP] likes this.
  6. Jun 30, 2023 at 5:23 AM
    #396
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    So I examined the 3 coils. The two on the right were misfiring and the one on the left was working.
    The metal ring that bolts the coil to the valve cover is extremely corroded on the right two. I think that is a ground for the coils. I think that the rusty ground and the rusty bolt and the corrosion also on the valve cover could have caused a bad ground for the coils leading to the coils not firing. When I swapped the coils for the junkyard ones, I also grabbed the bolts to go with it. Less rusty bolts and no rust on the coils now everything working. I think the ultimate test would be for me to sand paper the rust off the "bad" coils and retest them to see the result.
    What do you guys think?
    G_unit3000 and KNABORES like this.
  7. Jun 30, 2023 at 5:25 AM
    #397
    G_unit3000 and bmf4069 like this.
  8. Jun 30, 2023 at 7:26 AM
    #398
    I tend to agree with your hot take, and like I said earlier, the symptoms you described harken to bad ground.
    However, @assassin10000 is also correct - if moisture gets inside your coil pack while it's firing, they have a penchant for self destruction. I think it would all depend on whether or not that metal part is corroded enough to compromise the seal of the coilpack plastics. When something steel is running thru plastics, and the steel starts to corrode, I usually find it compromises the integrity of the seal of the plastic.
    Could be a fun/interesting test, and I don't see a lot of harm, but I'd stick to testing with the far-right coil pack in your picture because the other one is pretty far gone.
  9. Jun 30, 2023 at 8:25 AM
    #399
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Just got back from the yard...
    Scored big today. Pulled these gems:
    Muffler, pipe, O2 sensor, and rubber hangars, axle with brakes, lines, bumpstops and leaf springs with no rust!
    To replace this axle which is completely rusted through and leaking through the rust hole:
    N84434, Silet, Jack McCarthy and 5 others like this.
  10. Jun 30, 2023 at 8:26 AM
    #400
    Nice! CLEAN! Are your current ass-end parts toast, I don't remember?
    Also, do you know what gearing is in that rear end, and if it matches yours? Ratio in front diff needs to match rear, unless you're planning to only swap the housing. You may already know this, not trying to preach to the choir here...
    Bmktw2[QUOTED][OP] and w666 like this.
  11. Jun 30, 2023 at 8:30 AM
    #401
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I'm going to check the gear ratios as soon as I can
  12. Jun 30, 2023 at 9:03 AM
    #402
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    swap the case and throw a locker in that summama b ai itch already
    G_unit3000 and Bmktw2[OP] like this.
  13. Jun 30, 2023 at 9:22 AM
    #403
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Pray tell that you did not hook that trailer to your bike and pulled it back!?
  14. Jun 30, 2023 at 9:45 AM
    #404
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Haha
    No I had to borrow my brother jeep Comanche
  15. Jun 30, 2023 at 2:15 PM
    #405
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    So I'm trying to work on my exhaust because it's rusted to hell and leaking everywhere... I wanted to remove it from the crossover pipe and this happens:
    :facepalm:
  16. Jun 30, 2023 at 5:34 PM
    #406
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Looks like my original axle gear ratio is a 4.10 and the new axle is a 3.90
    :facepalm:
  17. Jun 30, 2023 at 5:54 PM
    #407
    On the plus side, you've got a great new housing. Just might have a little extra work to getting there. The bonus is, you've got all the time in the world to get it prepped and a bike to get you by during downtime :D
  18. Jun 30, 2023 at 5:55 PM
    #408
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    :drunk:
    JasonC. and shifty`[QUOTED] like this.
  19. Jun 30, 2023 at 6:14 PM
    #409
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Get a sequoia 3rd member if you want a less rusty one... or swap your current one to the new housing.
  20. Jun 30, 2023 at 6:17 PM
    #410
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    is there a different in diff, why not just change the ring and pinion
    Bmktw2[OP] likes this.
  21. Jun 30, 2023 at 6:47 PM
    #411
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Are you in Tampa?
  22. Jun 30, 2023 at 6:50 PM
    #412
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    California
  23. Jul 1, 2023 at 6:30 AM
    #413
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Replacing the cat-back exhaust with the rust free OEM one I got from the yard
    N84434 likes this.
  24. Jul 1, 2023 at 3:14 PM
    #414
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Front wheels on!!!
    Brother helping me pull vacuum on the AC system with his AC kit.
    It held vacuum for :30 min no problem so we charged 2 cans of freon in the system until the sight glass went clear. Now there is ice cold air!
  25. Jul 1, 2023 at 5:44 PM
    #415
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Got the old axle out:
    Was mortified to find a leaf spring broken:
  26. Jul 1, 2023 at 8:56 PM
    #416
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Legend
  27. Jul 1, 2023 at 9:26 PM
    #417
    I need to shop better salvage yards (someplace rust free). Damn, those are nice! Bump stops included!
  28. Jul 2, 2023 at 6:30 AM
    #418
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Scraped, brushed and cleaned:
    then rust inhibiting primer:
    Coat of black paint and then will remove and install in new housing...
    G_unit3000, N84434, bmf4069 and 2 others like this.
  29. Jul 2, 2023 at 6:42 AM
    #419
    How are you going to install that if the gear ratio is different? Or are you just using the new housing?
  30. Jul 2, 2023 at 6:50 AM
    #420
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Just swapping 3rd members between the axle housings. Have keep the matching 4.10gear
