General Supercharger Thread
  1. Jul 1, 2023 at 7:57 AM
    #9361
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Ikr lol. Glad there's curious people out there!
  2. Jul 1, 2023 at 7:58 AM
    #9362
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Could one just enlarge the brass fitting's hole a bit more as a monitor improvements? I like this idea of losing it!
    e30cabrio and M3Tundra-JK like this.
  3. Jul 1, 2023 at 8:02 AM
    #9363
    M3Tundra-JK
    Scott
    2005 GX470
    I wasn't monitoring AFR or IAT on the Tacoma so no idea if that changed. I didn't see any surging on mine, but not to say it doesn't happen. The increased throttle response was noticable. Would definitely love to see some before/after logs. Haven't seen anyone do that on the Tacoma side
  4. Jul 1, 2023 at 8:32 AM
    #9364
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    If the new ECU calibration ID is the same as the old ECU calibration ID, you would just need to write your VIN into the ECU with Techstream and HPTuners wouldn’t know the difference. If the calibration ID is different, you will have to buy credits.
  5. Jul 1, 2023 at 8:35 AM
    #9365
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Thank you sir.
    e30cabrio and ViktorG[QUOTED] like this.
  6. Jul 1, 2023 at 8:44 AM
    #9366
    ViktorG
    Viktor
    Calgary, Canada
    Also, if the calibration ID is different, it may be possible to first update it with Techstream to the one that was in the old ECU. Techstream will allow calibration up, to a numerically higher or newer calibration, but not down to an older one.
  7. Jul 1, 2023 at 8:50 AM
    #9367
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ewkay, I wandered around without the jet in. It seems slightly more responsive, but I'm not sure I'm going to be comfortable with that when the roads become icy in the winter, and our roads are pretty jostling; we have more craters than the moon. Maybe by then I will have acclimated. I didn't really notice any change in maximum boost at WOT. I did see a reading on the boost/vacuum gauge on deceleration where it indicated over 25inHg. That's the highest that I've noticed, but I don't really monitor that. AFRs were a touch lower at WOT, 10-10.2 versus what I seem to recall seeing before, like 10.5-10.8. They seemed to be steadier and bounced around less. I'm going to leave it out for the time being and see if anything else of note crops up. Let's hear from the rest of you when you get the chance to experiment. :thumbsup:
  8. Jul 1, 2023 at 9:49 AM
    #9368
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Just took a drive, 20 minutes back & forth on the freeway.
    1)instant boost. Truck just takes off, immeadiately it's at 8.8 which seems to be as high as it is going now.
    2)no noticeable fluctuation in cruise driving & the IAT seems the same.
    3)AFR seemed slightly lower at WOT (10.0 from 10.5)
    The first ambient/IAT is just on the freeway, second after about 10 minutes on the freeway.
    I like it so far.
  9. Jul 1, 2023 at 10:20 AM
    #9369
    Saltyhero13
    Saltyhero13 Throbbing Member
    I'm same same.
    HulkSmurf14, Silver17 and e30cabrio like this.
  10. Jul 1, 2023 at 10:37 AM
    #9370
    Fastlane47
    Maryland
    2018 Platinum
    Looking good.
    e30cabrio[QUOTED] likes this.
  11. Jul 1, 2023 at 11:17 AM
    #9371
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Interesting findings on these without the brass fitting. Definitely need to see if I have one
    HulkSmurf14 likes this.
  12. Jul 1, 2023 at 11:30 AM
    #9372
    snivilous
    SW UT
    300k+ Supercharged 2008
    Wonder if it turns the bypass into more of an on/off switch. I mean removing the bypass will make response even better too :D
  13. Jul 1, 2023 at 12:15 PM
    #9373
    nags
    nags New Member
    You gotta go through a whole process to program it with Techstream. It is definitely not just plug and play.
  14. Jul 1, 2023 at 12:18 PM
    #9374
    nags
    nags New Member
    I did not need more credits on mine.
  15. Jul 1, 2023 at 12:19 PM
    #9375
    nags
    nags New Member
    This is exactly what we did in mine and I was able to continue tuning without the need to purchase more credits.
  16. Jul 1, 2023 at 12:22 PM
    #9376
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I believe the correct name for the brass fitting is a snubber. I’ve seen them before in hydronic systems to prevent gauge damage from rapid pressure fluctuations.
  17. Jul 1, 2023 at 1:56 PM
    #9377
    M3Tundra-JK
    Scott
    2005 GX470
    Need to see some redone Draggy runs with the restrictor jet removed too!
  18. Jul 1, 2023 at 5:13 PM
    #9378
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Doing some upgrades right now and have the magnuson up on some small blocks. I'd like to pull it out of the engine bay though, how much coolant are in the intake/outlet for the intercooler on top of the unit? Do I need to drain some inter-cooler coolant out first before attempting or is that high spot relatively empty when off?
    Side note the "softball trick" of using a heat gun + softball with the magnuson rubber intake works really well to fit over the RCF throttle body.
  19. Jul 1, 2023 at 5:34 PM
    #9379
    snivilous
    SW UT
    Just cap them off and then hold the hoses up in the air.
    Should've installed a sniv Speed Shop modular pulley while in there.
  20. Jul 1, 2023 at 6:25 PM
    #9380
    HulkSmurf14
    2014 Tundra Limited
    Took out the snubber...it's inbetween turning T/H on and not...when T/H is on...my tires go really soft and burn out EVERYWHERE! Haha suck it easy local high school kids!! :cool:
  21. Jul 1, 2023 at 6:29 PM
    #9381
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    So it sounds like drilling out that orifice to a specific size is the way to go for a good balance.
    Saltyhero13, Wynnded, VWTim and 2 others like this.
  22. Jul 1, 2023 at 6:40 PM
    #9382
    Silver17
    Eastern PA
    Saltyhero13 and M3Tundra-JK like this.
  23. Jul 1, 2023 at 7:05 PM
    #9383
    HulkSmurf14
    2014 Tundra Limited
    Hard saying ,not knowing...but for me I'm happy to get this secret move...I'd imagine a slightly larger office would optimize everything :smokertransformer:
    Saltyhero13 likes this.
  24. Jul 1, 2023 at 11:56 PM
    #9384
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    So update for people that try this, intercooler hoses come off pretty easy. The passenger side did have about a half cup of coolant come out immediately before I could cap off, I had paper towels ready though. The barbs are 3/4” for caps, I used a male to male for the hoses. Glad I took the supercharger out as I found some debris in a few intakes I had to clean up, also alot easier to get the nose back on when it’s sitting on a bench.
  25. Jul 2, 2023 at 6:15 AM
    #9385
    Geego
    Geego New Member
    Gary
    2007 double cab tundra
    20 inch bbs wheels
    I have a 2014 black crewmax which I am about to purchase a supercharger but I have never seen one perform in person or even driven in one. I live in south Florida and checking to see if there is anyone in sunny south Florida with a supercharged Tundra I can look at, or possibly get a pull in. I would greatly appreciate it.
  26. Jul 2, 2023 at 8:01 AM
    #9386
    Saltyhero13
    One pull is all it takes...you may end up on the wrong side of a chase cam :burnrubber:.
    Do you know which supercharger you are going with?
  27. Jul 2, 2023 at 8:14 AM
    #9387
    Saltyhero13
    Strange. Is it a blow off valve or bypass? I didn't think anything was vented to air on these just circumvent the rotors.
    "Magnuson supercharger bypass valves have been designed to relieve the pressure surge caused by changing gears or backing off the throttle quickly. These bypass valves can be plumbed back into the car's air intake, making them ideal for mass airflow (MAF) metered vehicles, where venting to the atmosphere can create a rich air/fuel ratio. If you need a top-quality racing bypass valve, these supercharger bypass valves by Magnuson will deliver!"
    Silver17[QUOTED] and M3Tundra-JK like this.
  28. Jul 2, 2023 at 9:51 AM
    #9388
    M3Tundra-JK
    Scott
    2005 GX470
    Here's the Taco S/C thread OP's opinion on the bypass valve restrictor jet being removed and any throttle surge lol
    e30cabrio and Saltyhero13 like this.
  29. Jul 2, 2023 at 10:02 AM
    #9389
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    It'd be worth a call to Magnuson's tech dept. and find out what the actual function of that is and why they picked that size for the orifice.
    Silver17[QUOTED] likes this.
  30. Jul 2, 2023 at 10:19 AM
    #9390
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
