Anyone use these tow hooks?
Discussion in '3rd Gen Tundras (2022+)' started by Mrfritz44, Mar 22, 2023.
  1. Jun 29, 2023 at 11:07 AM
    swingdjted
    swingdjted New Member
    Please update when you get them; I'm curious to see how they perform in real life.
    wtrainer and 6thyota like this.
  2. Jun 29, 2023 at 11:14 AM
    Spickett78
    Spickett78 New Member
    Seth
    2023 Tundra Crewmax 6.7' Limited TRD OR Premium Magnetic Gray
    3" TRD lift Talon's Garage Steel powder coated transmission skid plate / Cat cover RCI Steel powder coated skid plate Go Rhino D6 steps Nytop front recovery points
    I will. Not sure how far out production really is. They didn't have a good answer. I'm just trimming the plastic to slip them through without their hybrid bumper insert.
  3. Jun 29, 2023 at 11:21 AM
    99ways2die
    99ways2die New Member
    I may also bite on these, but interested to know if Nytop will give you a cut-out template for the OEM bumper cover (if you're not buying theirs).
    I sure I hell don't feel like guesting where and how much to cut.
    This thing looks great in their CAD drawings; hope the real life outcome is equally professional.
    Spickett78 likes this.
  4. Jun 29, 2023 at 11:23 AM
    Spickett78
    Seth
    I wasn’t able to get a lot of specifics from them via email. I asked. I believe they will, it just seemed like they didn’t want to put stuff out till they finish testing. Going off the cad it should be easy for them to template the two cuts and have it be clean and exact. For $200 plus $35 shipping I decided I would risk getting ripped off since they do have other products that they have made.
  5. Jun 29, 2023 at 11:31 AM
    swingdjted
    Maybe Toyota doesn't want to have to build a frame that is strong enough to support a front tow hook that could potentially be used to recover the weight of a full truck plus heavy trailer. With the Taco, the likelihood of this would be less, since Tacos often don't get loaded down as much and don't tow as much and I guess they save weight by not needing all that beef up front. That said, I'd buy aftermarket if they become available, because while I use front tow hooks often, I don't plan on shock loading (yanking on) them, just pulling.
    I'd hate to admit this after owning Toyota vehicles only since 1994, I may need to look at F150 or F250. If Ford reliability improved and they put a composite bed (and maybe the roll down rear window for fun), I'd be very tempted to buy one, or I'd buy a new Tacoma if it would tow more.
    It just seems that Toyota wants to build this Tundra class of truck for pretenders, and they instead design the Tacoma for those that actually do stuff. Maybe that's why the 2005+ Taco had a composite bed, inverter/power outlet, locking differential and more when the more expensive Tundra, well, didn't. Even today, you can't even get a TRD Pro or Capstone with much of a bed (5.5 foot only) because they know buyers won't be actually using it for much anyway. They're too busy wanting a living room cab with a little stub of a bed on the rear end to pretend that they're a man.
    I hope these aftermarket tow hooks perform well. If so I may buy a Tundra.
  6. Jun 29, 2023 at 11:36 AM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I have a crew cab and 5.5 foot bed. I don’t pretend to be a man because of that.
    ChiefG, 22whatwedo, ArcticEd and 3 others like this.
  7. Jun 29, 2023 at 11:47 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    :rofl::duh: :der:
    Spickett78 and iiawah808 like this.
  8. Jun 29, 2023 at 11:51 AM
    99ways2die
    ...well, that's one way to base a $50+k truck purchase decision on.
  9. Jun 29, 2023 at 12:16 PM
    Spickett78
    Seth
    You also can’t get any off-road model from anyone with more than a 5.5. Please go find a raptor, trx, tremor, or rebel with a 6.5 bed, you can’t. You made up an issue that every truck maker has. Maybe you can pay 100k for an at4 Chevy. That the lifters will go out in but you can still say you have a v8.
  10. Jun 29, 2023 at 12:55 PM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Dont feed the trolls
  11. Jul 20, 2023 at 2:07 PM
    Spickett78
    Seth
    ChiefG likes this.
  12. Jul 20, 2023 at 2:11 PM
    Tom
    Tom New Member
    HighroadTRD likes this.
  13. Jul 20, 2023 at 2:16 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    We're they on sale? I guess I missed it. . I was thinking about pulling the trigger but 300 seems high for what you get.
  14. Jul 20, 2023 at 2:19 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    And I did order the afe hooks but haven't installed them yet. Trying to decide if that's the way I really want to go.
  15. Jul 20, 2023 at 4:48 PM
    99ways2die
    Spickett78[QUOTED] likes this.
  16. Jul 20, 2023 at 5:14 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    I want $200 hooks…. :sawzall: Willing to dremel the plastic!
    Spickett78 and Nomoredomestics like this.
  17. Jul 20, 2023 at 5:47 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
  18. Jul 20, 2023 at 5:53 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Well said and agreed 110%, you'll damage or rip off the plastic cowell(s) which will not be cheap to replace JMHO.CBI Covert Stealth bumper let's you know apon purchasing this item it asks if you have an active air damper and urge you to purchase their delete kit/plug if I remember correctly it's only $35 beans.
    These bumpers of ours are not old school 75# solid chrome where tow straps,rope or 1/2" chains would slide back and forth under serious pressure without even a friction burn,don’t get me wrong I absolutely love this truck but I wouldn't spend cheap cash on something that looks like it may help someone but when the time comes to depend on it in a "unique situation" which they always are your going to wish for something different as things unfold in the wrong direction.
    It's kinda like the fake looking convertible looks cool but anit worth a shit...
  19. Jul 20, 2023 at 9:44 PM
    Spickett78
    Seth
    Thanks. I hadn’t been back to the page after deciding to try it considering the cost. They do seem to stick out a bit however for good function and all that I’m ok with it. If they end up as solid as the design and all that I’ll be really happy considering the cost.
  20. Jul 20, 2023 at 9:49 PM
    #50
    Spickett78
    Seth
    Yeah, they were $200 for pre order. It’s at least $700 just to replace the middle of the bumper and get tow hooks so from that aspect $300 still seems decent with bolting to the truck solidly and if you have a lift there are no other options.
  21. Jul 20, 2023 at 11:32 PM
    #51
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    I did the afe hooks. Haven’t needed to use them yet. I like this other one, but at some point when I have the cash I’m just going for the CBI replacement bumper.
    Cbrash, HighroadTRD, ChiefG and 3 others like this.
  22. Jul 31, 2023 at 1:04 PM
    #52
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Wow they proud of those things eh? $751 doll hairs to pick them up locally (I'm in colorado) and with shipping somewhere else looking in the neighborhood of $850 doll hairs......WOW!!!might as well buy a full bumper for that price. Westin bumper is about $1k and you could add a winch and it comes with hookers or it a CBI for about $1k with winch mount as well. Or heaven forbid the Rough country bumper with winch mount and recovery points for $600.00. Yeah at $850 that seems a little optimistic to sell those tow hooks when a covert style bumper can be had for not much more than that and you get the added bonus of being able to add a winch later if you want and also ties the two frame rail together for a little added strength. Cool concept but I would just buy a bumper for that cost.
    https://www.westinautomotive.com/product-detail/58-411285/pro-series-front-bumper
    Spickett78 and Sixty9Four20 like this.
  23. Jul 31, 2023 at 7:37 PM
    #53
    Sixty9Four20
    2023 TuRD Pro
    Thanks for posting that link. I am saving these links for when I am no longer poor to functionally mod up the truck.
  24. Jul 31, 2023 at 8:04 PM
    #54
    LB-1889
    LB-1889 New Member
    I would agree, the CAD look good. However the real-time pictures look like they stick out to much. Wish they would have gone the shackle route for the tundra like they did with their Lexus design.
  25. Aug 2, 2023 at 7:04 AM
    #55
    ryanjay11
    ryanjay11 New Member
  26. Aug 30, 2023 at 1:06 PM
    #56
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    Is there any problem with the deployable air dam?
  27. Aug 30, 2023 at 6:02 PM
    #57
    NATE4SURF
    Laguna Hills, CA
    I don’t think I have that on the SR5
  28. Aug 30, 2023 at 6:22 PM
    #58
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    You should
  29. Aug 30, 2023 at 6:40 PM
    #59
    NATE4SURF
    Laguna Hills, CA
    Hmm. Ok. I haven’t gotten any warnings or anything when it deploys. Not even sure what it does. Haha.
  30. Aug 30, 2023 at 7:53 PM
    #60
    NATE4SURF
    Laguna Hills, CA
    Just looked not there.
