DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jun 23, 2023 at 11:19 PM
    #2791
    SAGE63
    San Diego County
    Mountun Goat likes this.
  2. Jun 23, 2023 at 11:28 PM
    #2792
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Yep, I did exactly that.
    After the springs settled, its exactly at 3" of lift and fenders measure exactly where they were with the spacer blocks. It rides fantastic.
    I did experience the "Tundra lean" after the spring install and had to put a 1/4" thick shim on drivers side to get it 1/2" higher.
    VietGuy[QUOTED] likes this.
  3. Jun 27, 2023 at 4:50 PM
    #2793
    coTony
    Tony
    Montrose, CO
    So how big of a hit was the performance going from 35's to 37's? I have 5.29's and the tire weight is going to be 3lbs more at each corner. I am NA not lucky enough to be SC... but ya never know
    CaptRussia253 likes this.
  4. Jun 27, 2023 at 7:29 PM
    #2794
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    With 5.29s you’ll be just fine.
    rockmup and SAGE63 like this.
  5. Jun 27, 2023 at 7:51 PM
    #2795
    coTony
    Tony
    Montrose, CO
    Just ordered them, now to find a new home for my 35's
    CaptRussia253, reywcms and SAGE63 like this.
  6. Jun 28, 2023 at 6:55 AM
    #2796
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    How are you getting 37's to clear and still running the stock front mud flaps?
    Dragracer_Art[QUOTED] likes this.
  7. Jun 28, 2023 at 2:08 PM
    #2797
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I did mine since I went to 37's. A simple mod.
  8. Jun 28, 2023 at 4:05 PM
    #2798
    coTony
    Tony
    Montrose, CO
    what's a mud flap? :monocle: :rofl:
  9. Jun 29, 2023 at 3:05 AM
    #2799
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I chopped the body mounts and trimmed the mudflaps for clearance.
  10. Jun 29, 2023 at 3:10 AM
    #2800
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I'm not a fan of mudflaps at all but they are needed when towing shiney things behind the truck. :D
    I had to add hitch-mounted Rock Tamer mudflaps to mine for towing. There are numerous rock chips in the gelcoat of my boat from a previous owner.
  11. Jun 29, 2023 at 4:42 AM
    #2801
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Nice setup! :thumbsup:
  12. Jun 29, 2023 at 3:36 PM
    #2802
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Finally Join the Club
    Did the DRT CMR as well
    IMG_20230629_182532_01.jpg IMG_20230629_182535_01.jpg IMG_20230629_182538_01.jpg IMG_20230629_182601_01.jpg
  13. Jun 30, 2023 at 10:23 AM
    #2803
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    New set of 37x12.5 RT Trails
  14. Jul 3, 2023 at 1:01 AM
    #2804
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    @Dragracer_Art
    did you ever end up doing the body mount chop?
  15. Jul 3, 2023 at 3:49 AM
    #2805
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yep, a day after the 37's went on. They were OK when driving in a straight line... but rubbed when turning and I needed more room for the front end to be properly aligned.
  16. Jul 3, 2023 at 5:24 AM
    #2806
    NoMoreGreen
    Robert
    2020 Tundra
    Thanks! I’m debating on making the jump to 37s after regear. I have 35s now. Also trying to avoid moving my casater? All the way forward.
  17. Jul 3, 2023 at 8:03 AM
    #2807
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I had my alignment done at a local offroad shop. (Southern Offroad Specialties) They couldn't get much positive caster without messing up the camber... so I told them just get camber and toe set so it doesn't eat tires. Camber is at 0.0 and Caster ended up at around .8-1.0 degrees. It steers and drives just fine so I'm not too worried about it. I have upper arms for it but haven't gotten around to slapping them on yet.
    The cab mount chop was really not as big of a deal as it would seem. Just a quick surgical cut, a little grinding and fitting then weld it up.
    I hammered the pinch weld over and sprayed black engine enamel on everything. Worked like a charm.
  18. Jul 3, 2023 at 8:21 AM
    #2808
    CaptRussia253
    Ruslan
    What’s your wheel offset?
  19. Jul 3, 2023 at 9:15 AM
    #2809
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Method 18x9's with +25mm offset
  20. Jul 3, 2023 at 9:17 AM
    #2810
    NoMoreGreen
    Robert
    2020 Tundra
    Thank you for the information. After regear I’ll have to consider ordering 37s to see if they fit
  21. Jul 3, 2023 at 9:22 AM
    #2811
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    In a perfect world, 5.29's and 37" tires are the right combo... but after having these 37" BFG KM3's on stock 4.30's, I'm of the opinion it just isnt necessary... even when I tow 8000+lbs of boat behind me. Yes, it's a slug pulling out from a dead stop... but the 5.7 runs just fine on stock gearing and really doesnt struggle once up to speed. I just click into 4th or 5th and all is well. It is still perfectly capable of pulling my boat at terribly unsafe speeds. :rofl:
    CaptRussia253 and Shanet421 like this.
  22. Jul 3, 2023 at 9:47 AM
    #2812
    coTony
    Tony
    Montrose, CO
    My tires were supposed to be delivered on Wednesday but I checked this morning and they are out for delivery. Looks like I may be able to get them on Wednesday or Thursday. :burnrubber:
  23. Jul 3, 2023 at 8:05 PM
    #2813
    CaptRussia253
    Ruslan
    Damn should have kept my scs ray10s with +25mm. My 0 offset were touching even after my BMC haha.
  24. Jul 3, 2023 at 8:07 PM
    #2814
    CaptRussia253
    Ruslan
    I just got a quote for 5.29s but really thinking about saving the 4k and putting that towards something else. Towing my 5k trailer isn’t bad at all.
  25. Jul 3, 2023 at 8:44 PM
    #2815
    SAGE63
    San Diego County
    At that price a visit to riverside Is cheap...
    CaptRussia253[QUOTED] and vipgs3 like this.
  26. Jul 5, 2023 at 3:14 AM
    #2816
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yep, my boat and trailer are over 8000lbs and I'm totally fine with the way it performs. I'm old enough to remember a time when all we had were 3-speed automatic transmissions coupled to 2.73 or 3.08 geared rearends.
    We are terribly spoiled with all the modern horsepower, extra transmission gears and differential gearing options. :thumbsup:
    Edit to add:
    If I lived in Denver or had to pull a heavy load through the Rockies regularly... I'd probably opt for a set of 5.29's... or better yet, an F350 with the big gas engine. :D
    CaptRussia253[QUOTED] likes this.
  27. Jul 5, 2023 at 7:38 PM
    #2817
    king.cong.1119
    king.cong.1119 New Member
    So my 37s (36s actually) on +35mm are in. Will they fit without bmc? We will find out in the next week.
  28. Jul 6, 2023 at 2:19 AM
    #2818
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Yah sorry but I’ve been on 37s for a while and you don’t need gears I don’t even notice the difference if anything maybe breaking cause the weight get some upgraded breaks but for 4K I would rather just supercharger the thing
  29. Jul 6, 2023 at 3:30 AM
    #2819
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I experienced the same... going from heavy 35's to light 37's was barely noticeable. Really was a pleasant surprise. I will never go back to 35's now.
    reywcms and CaptRussia253 like this.
  30. Jul 6, 2023 at 7:33 AM
    #2820
    NoMoreGreen
    Robert
    2020 Tundra
    I’m more worried about them fitting, so many people say they don’t.
    I’m going to also do lockers (likely ARBs) which while they are in there they might as well regear. If lockers weren’t on the table, I’d likely consider regear less.
    I also worry about transmission temps and load, I routinely see 230-240 and once 250 in Texas summers.
