RCI Gas Tank Skid plate, install question
Discussion in '2nd Gen Tundras (2007-2013)' started by SC_TRD, Jul 18, 2020.
  1. Jun 21, 2023 at 12:07 AM
    #61
    moodywizard
    moodywizard New Member
    Lost
    2017 Tundra 4x4 Crew Max
    Sorry to bring up an old thread, but for those with the 26 gallon RCI skid does the front seem to hang lower than the rear? Mine has a 1”+ gap in the front which looks like a bucket loader. It’s installed correctly, only thing I can think of are the brackets not being bent correctly.
  2. Jun 21, 2023 at 8:55 AM
    #62
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Do you have any pics? 1 inch gap between the plate and the tank? Mine sits completely flat against the tank. I’m sure you’ve checked but is the front drivers side bracket that goes off the frame in correct orientation?
    moodywizard[QUOTED] likes this.
  3. Jun 21, 2023 at 12:22 PM
    #63
    moodywizard
    Lost
    I’ll get a pic when I get home but yeah it’s very noticeable. I thought it was weird too as I think the bracket only goes on one way. Been a while since I’ve messed with it since installed.
  4. Jun 21, 2023 at 12:50 PM
    #64
    moodywizard
    Lost
    Found a pic on my phone! Hard to see how low it hangs in front from the pic but the bracket looks installed correctly.
  5. Jun 21, 2023 at 1:25 PM
    #65
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    do you have the bracket on the other side of it connected as well?
  6. Jun 21, 2023 at 1:40 PM
    #66
    moodywizard
    Lost
    haha of course.
    MadMaxCanon[QUOTED] likes this.
  7. Jun 21, 2023 at 3:10 PM
    #67
    MadMaxCanon
    lol you never know......
  8. Jun 21, 2023 at 6:03 PM
    #68
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Yea that's pretty low! Bracket is installed correctly, I thought maybe they put too much of a bend in it but if the long bracket on the driveshaft side lined up then I wonder if the brackets were made longer for some reason.
  9. Jun 21, 2023 at 6:24 PM
    #69
    moodywizard
    Lost
    yeah that’s what I thought as well, either brackets are too long or maybe need spacers in rear. Even removed the long bracket and jacked up the skid plate to see if I could bend that bracket… no luck goes right back in place. Here’s some better pics, standing further back it looks worse.
    TG705[QUOTED] likes this.
  10. Jun 21, 2023 at 8:42 PM
    #70
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Maybe contact RCI with those photos and see what they say
  11. Jun 21, 2023 at 9:08 PM
    #71
    moodywizard
    Lost
    yeah I sent them an email today, just wanted to see some pics of others that had them installed.
    Only solution I see is shortening the brackets by cutting and welding back together… maybe an hour or so project will update and see what they say.
