  1. Jun 17, 2023 at 8:06 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Spike strips will fix that shit
    TaquitoBandito and CodyP like this.
  2. Jun 17, 2023 at 8:18 PM
    Outbound
    Aaron
    Northern Alberta
    or a gate to keep people out of the driveway entirely.
  3. Jun 17, 2023 at 8:26 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  4. Jun 17, 2023 at 8:51 PM
    Tripleconpanna
    Gate keeps 'em out; spike strips prevent them from doing that shit again, at least until they get their tires fixed.
    Plus... disrespectful, stupid behavior should either hurt or cost you money :D
    BTW.... :canada:
  5. Jun 17, 2023 at 9:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    pay attention to back right on top of your lawn...:rofl::rofl::rofl:
  6. Jun 17, 2023 at 9:43 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I did do that. Between the grass and the pavers there is a series of sharpened bolts. The green Ranger was the first victim. He drove away with a spike in the tire. Other vehicles after that one showed flaws in my defense system forcing my to remedy that issue. The spikes were being pushed into the dirt. Some strips of stainless steel under the pavers acted as a backing for the spikes.
    The bucket truck is the only one to thwart me designs by the shear weight of the vehicle. It pushed everything down and compressed the dirt by at least 4 inches.
    Had there been a fence or gate there I’m sure the asshole would have just driven through it. If you can see across the street where the green fencing ends there are three steel poles filled with concrete. They have all been tagged by people making too sharp a turn.
    I have no problem with people using my driveway for a three point turn. I have all the problems when they use my lawn to do it.
  7. Jun 17, 2023 at 10:25 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    not if you have 4" I beam 3' deep for fence post and 4x8 for fence board.
  8. Jun 19, 2023 at 1:47 PM
    Baja Mike
    South Bay, Ca.
    Concrete is dried. Pole is in. Didn’t even have to mess around with the pavers. The red one slid right into place.
  9. Jun 19, 2023 at 2:00 PM
    So I replaced two steps on my deck a few days ago and realized the rest look bad enough to replace too. How would you all deal with some of these cracks in the stringer? I tried wood putty on a few and it worked on one but already split on another. I may not have let it dry long enough before driving in new deck screws.
    Also, how long should I wait before staining pressure treated wood? Seeing conflicting info online.
    This crack is the worst.
  10. Jun 19, 2023 at 2:09 PM
    NWPirate
    Zach
    WA
    Looks good!
    Throw a towel on it and keep it wet for a week or more, it'll get a lot stronger that way.
  11. Jun 19, 2023 at 2:35 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    take it down and cut new stringers, nothing worth a trip to IR
  12. Jun 19, 2023 at 2:42 PM
    What does this help do? Slow the cure? Which makes it stronger?
  13. Jun 19, 2023 at 2:54 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Concrete takes should take 30 days to fully cure, if it dry too fast it just crack.
    Or just water it every day for a few weeks
  14. Jun 19, 2023 at 3:12 PM
    NWPirate
    Zach
    WA
    Yep.
    I've worked on DOT jobs in the past and they actually lay down burlap and keep sprinklers running 24/7
  15. Jun 19, 2023 at 3:32 PM
    Baja Mike
    South Bay, Ca.
    Done and done. Sprinkler head is right there. I’ll run the sprinklers twice a day to soak them. Thanks.
  16. Jun 19, 2023 at 4:02 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    On the smaller cracks, I would run a 2" or 3" screw through the crack to hold it together. On the larger posts/larger cracks, I would run a lag bolt/washer/nut through them.
  17. Jun 19, 2023 at 4:23 PM
    NWPirate
    Zach
    WA
    :thumbsup:
  18. Jun 19, 2023 at 4:36 PM
    Kung
    KG, VA
    Cleaned it out big time. In the last 2 weeks, I've
    - applied for a job 1K miles away
    - offered the job 1K miles away O_O
    - accepted said job
    - scheduled a PODS moving thingamabob
    - cleaned out 1/2 the stuff in our house
    - had the next door neighbors' kids tell us they want our house at asking price
    So yeah, been a tad bit busy.
  19. Jun 19, 2023 at 5:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Whoa. Where ya moving to?
    Also, for Father’s Day my father in law and brother in law wanted to help me with the treehouse. We decided to tackle the front railing…only took us about 4 hours, 3 guys, 8ft of railing lol. So sad.
  20. Jun 19, 2023 at 8:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :eek2:
    congrats on the new job
  21. Jun 20, 2023 at 6:59 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Kung[QUOTED] likes this.
  22. Jun 20, 2023 at 7:31 AM
    Kung
    KG, VA
    Somewhere near Dahlgren, VA. :)
    Thanks man! Looking forward to it, but holy crap there's a lot to do.
  23. Jun 21, 2023 at 10:48 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    keep us updated on the first moron that runs into it.
  24. Jun 21, 2023 at 11:21 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yup. Definitely needs a security cam on it to catch the carnage.
    NWPirate and TaquitoBandito like this.
  25. Jun 22, 2023 at 7:39 PM
    Baja Mike
    South Bay, Ca.
    Will do.
    Unless it's me, which it most likely will be.
  26. Jun 23, 2023 at 12:37 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Goodbye pampas grass, introducing black diamond crepe myrtle.
    gonna get another and some more dirt...
    supposed to grow into this.
    texasrho83, Bama, Sean492 and 10 others like this.
  27. Jun 23, 2023 at 12:41 PM
    Roof demo'd today. Nail strip, underlayment, and 2 inch polyiso is down.
    texasrho83 and T-Rex266 like this.
  28. Jun 23, 2023 at 6:31 PM
    snoope
    snoope The Old Man
    Florida's "Summer Rains" have helped bring my Hibiscus back too LIFE :hattip:
    Poor thing has not had a bloom or buds since our 'Lil storm last year but the move from Ft.Myers to the new Home has now shown great results...
    The little things in Life :cool::cool:
    Don't mind the sleeping Tundra in the background...it is liking Retired life just like me..:fistbump:
  29. Jun 23, 2023 at 7:24 PM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    2018 Silver Sky CM 1794
    Got a great deal on 3 pallets of zoysia sod. Yes I pushed the limit but it was only 4 miles down the street.
    Dad stopped by (with his Tundra) so we made two more trips and just split the loads to be safe
  30. Jun 24, 2023 at 1:17 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_4638.jpg IMG_4639.jpg Pulled weeds and fertilized all the palms. Summer is here :)
