New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jun 10, 2023 at 7:46 PM
    #241
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Yes I'm noticing this... The passenger side is set nice but the drivers side is positive camber (the top of the tire sticks out further than the bottom.)
    I need to move the driver's side eccentric to match the passenger side ....
    https://youtu.be/oH7x7d83TQc
  2. Jun 10, 2023 at 7:49 PM
    #242
    I’ve wirebrushed mine with die grinder, wire wheel and air compressor before applying the POR-15 degreaser, prep and 2 coats of POR-15 semi-gloss paint. It’s worked well and only began flaking after 8 years of salt/brine abuse.
    Yours look like they need sand/media blasting first to clean up the rust.
    JasonC.[QUOTED] likes this.
  3. Jun 10, 2023 at 8:53 PM
    #243
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    take it to an alignment shop, it's going to save you money on tires. next time use a marker and mark where the bolt sit.
    Bmktw2[OP] likes this.
  4. Jun 11, 2023 at 7:01 PM
    #244
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Moving slowly on the timing belt and valve cover. Lots of rusty bolts. The alternator adjuster was siezed and so was the alternator itself. Having to clean and dress all the bolts. Going to do the tare-down then make a trip to the junk yard to get all the replacement parts that failed...
    Silet, bmf4069 and Winning8 like this.
  5. Jun 12, 2023 at 5:54 AM
    #245
    Nothing a 3-4 hour soak in Krud Kutter wouldn't solve.
    Bmktw2[QUOTED][OP] likes this.
  6. Jun 12, 2023 at 6:32 AM
    #246
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The bracket is bent, the bolt is bent and siezed...
    shifty` likes this.
  7. Jun 12, 2023 at 6:57 AM
    #247
    "Just the tip" :rofl:
    Bmktw2[QUOTED][OP] and bmf4069 like this.
  8. Jun 12, 2023 at 7:58 AM
    #248
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Like new
    bmf4069 and shifty`[QUOTED] like this.
  9. Jun 13, 2023 at 9:19 AM
    #249
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    This is where I'm at with the 3.4:
    I'm about to remove the old belt, gears and seals.
    I have the crank lined up with the mark and this is where the cams landed...
    So my question: is the motor at TDC on the compression stroke? Is that necessary for it to be on the compression stroke? Everyone I've heard for this motor and job just says line the 3 marks together... Am I good here or what?
    2nd is, are the cams off one cog or is the belt stretched what's the deal here?
  10. Jun 13, 2023 at 11:12 PM
    #250
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Compression cycle is the TDC, Find TDC have to look at the intake and exhaust valve, when piston going up, both should stay close.
    If it’s still show the same, maybe the guy before install it wrong, off a tooth is not end of the day, just put it back on the mark.
  11. Jun 14, 2023 at 10:26 AM
    #251
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Gettn to the cam and crank seals
    FirstGenVol and w666 like this.
  12. Jun 14, 2023 at 10:27 AM
    #252
    Look at all the extra room in there! For activities!
  13. Jun 14, 2023 at 10:33 AM
    #253
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Fun facts
    Audi A4 you have to take the whole front end off to do a timing belt…:rofl::rofl::rofl:
  14. Jun 16, 2023 at 7:18 PM
    #254
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Double din w/Bluetooth OBD reader
    The Black Mamba, bmf4069 and Winning8 like this.
  15. Jun 16, 2023 at 7:45 PM
    #255
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    OMG it's a stick shift...:bowdown::bowdown::bowdown:
  16. Jun 18, 2023 at 5:15 PM
    #256
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Sr5 decal.... On the fence about it
  17. Jun 18, 2023 at 5:16 PM
    #257
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    When doing the valve covers, are you guys putting rtv on the cam plug?
    And why did Toyota put this bracket on back here? What does it do?
  18. Jun 18, 2023 at 8:40 PM
    #258
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I dont know if there are different 'grades' of the toyota FIPG, but i'm pretty sure thats what people use.
  19. Jun 19, 2023 at 5:29 AM
    #259
    Be careful leaving the reader plugged in all the time. Two main issues reported by others:
    1. Parasitic drain: There's a constant-hot lead on OBDII
    2. Bizarre CELs and other gremlin-like behavior
    Doesn't seem to be model-specific, but has been reported here a few times now. Dead batteries in the AM, tied back to the unit. Check engine light with weird codes, all disappears when dongle is removed. YMMV, just seeding this in case you encounter the same.
  20. Jun 19, 2023 at 1:37 PM
    #260
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thankyou for the heads up
  21. Jun 19, 2023 at 1:41 PM
    #261
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Moving along
    Put in new cam and crank seals.
    The tensioner pulley was bad and the tensioner arm was siezed up. Good thing I did the timing belt.
    It got dark
    Silet, bmf4069, shifty` and 3 others like this.
  22. Jun 19, 2023 at 2:38 PM
    #262
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I can't wait to drive this truck
    Only got to drive it once the drive straight home from purchase.
    shifty` likes this.
  23. Jun 19, 2023 at 2:53 PM
    #263
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It should feel faster, if the timing was wrong b4
  24. Jun 19, 2023 at 3:03 PM
    #264
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    That truck has the best security system in America; 5-speed/3-pedal millennial anti-theft device!
    Fun fact: I'm one of those rare millennials who can drive a stick shift!
  25. Jun 19, 2023 at 3:12 PM
    #265
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Yes it appeared to be one cog out of place.
    I also found 3 cracked vacuum hoses which were for sure leaking.
    shifty` likes this.
  26. Jun 19, 2023 at 3:13 PM
    #266
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    If I put the transfer case in neutral that would blow their minds
  27. Jun 20, 2023 at 10:58 AM
    #267
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Made a trip to the scrap heap and grabbed a new alternator and brackets
    shifty` and w666 like this.
  28. Jun 20, 2023 at 12:02 PM
    #268
    You gonna go ahead and swap in new brushes etc. while you've got it out?
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  29. Jun 20, 2023 at 12:41 PM
    #269
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Okay all done. All I have to do now is install the new AC system
    Mr.bee likes this.
  30. Jun 20, 2023 at 12:41 PM
    #270
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Don't have time. Have to send it.
