Catalytic converter shield
Discussion in '3rd Gen Tundras (2022+)' started by Kap1, Sep 15, 2022.
  1. May 1, 2023 at 5:09 PM
    #91
    Topwhite007
    Topwhite007 New Member
    2023 1794 TRD
    Sorry if I missed this, but steel vs aluminum? Finding almost everyone, if not everyone, gets the aluminum one - why? Looking at Talon's pricing, for example, a steel one is a lot cheaper. Isn't a steel one harder to cut through? I feel like I'm missing something here...
    Randy Morton likes this.
  2. May 1, 2023 at 5:22 PM
    #92
    Randy Morton
    Randy
    Deepinahearta, Texas
    According to the service writer at the shop that installed mine, the aluminum shields clog the sawzall blades when they try to cut through them. I'm sure there's someone here that works with aluminum that can confirm or deny that claim.
    Topwhite007[QUOTED] likes this.
  3. May 1, 2023 at 5:40 PM
    #93
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    MillerCat here. Aluminum thickness is decent. Not as robust as the TRD skid plate but it will definitely waste a perp's time to go through it.
  4. May 1, 2023 at 5:40 PM
    #94
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    After looking at a number of different designs one of my concerns is the mounting screws/bolts used to install these cat protectors. If a thief can use a battery operated Sawzall to cut the Cat's out what is stopping them for also bringing along a battery operated grinder to cut the heads off the exposed screw/bolt heads (irrespective if they are tamperproof or not). The designs that incorporate countersunk mounting fasteners would be better in this case. Just saying!
  5. May 1, 2023 at 8:15 PM
    #95
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Nothing is going to stop a determined thief! The cat guards add a deterrent which will help them move to an easier target. If the thief had enough time and equipment, they would flip the truck on its side and take their time or they could just tow it away.
  6. May 2, 2023 at 5:21 AM
    #96
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Not sure about others but I would go with aluminum if I got one for less weight since I'm probably getting close to my payload capacity when I tow my travel trailer.
  7. May 2, 2023 at 5:28 AM
    #97
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What is stopping them is time. They want to hit it fast, under a minute, and leave. Sure, they can bring a grinder and a saw, make tons of noise grinding off 4 bolt heads, but they wont, generally speaking. They could hit like 5 cars in the time it would take to saw off your bolts.
    Plus, those steel bolts are not THAT easy to cut. I had to cut the head off of one bolt because I forgot bolt head protectors and sheared off the head of the bolt while wheeling, and it took a long time to cut it off.
    raylo, Mattedfred and Cpl_Punishment like this.
  8. May 8, 2023 at 6:27 PM
    #98
    Topwhite007
    2023 1794 TRD
    Appreciate the feedback. Haven't pulled the trigger yet. Not hauling, so weight wasn't really a concern until I started thinking maintenance. Would I need to take the shield off every time I take Tundra for a service...then it may eventually make a difference. Yes, it would be good to hear from someone who works with aluminum to get a better understanding if cutting through aluminum is not like going through butter..
  9. May 9, 2023 at 4:14 AM
    #99
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Depends on the service you are going in for. transmission, front diff and transfer case will all require the shields being removed, on a 2.5gen anyway, not 100% sure on the 3gen. I'm sure you could get the shop doing the service to pull and install the shields, just might cost extra.
    As for ease of cutting aluminum, it is obviously easier than cutting steel but it'll be loud and still take some time and most thieves are looking to be in and out quick. Someone mentioned being told the aluminum would gum up the blades, not unless the thief is using a really high tooth count blade.
    I chose aluminum for mine because I wanted them lighter to take away less from payload and easier handling during removal/install but also because I don't plan to use them as sliders.
  10. May 13, 2023 at 6:06 PM
    #100
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    For those of you who put a Talons Garage plate on with the TRD skid, what did you do where they meet at the front?
    Paul Moll likes this.
  11. May 13, 2023 at 6:30 PM
    #101
    Kap1
    Kap1 [OP] New Member
    San Francisco, CA
    Regarding cutting aluminum...
    I would expect thieves to carry a grinder with a metal cut off wheel, not a saw with tooth. So it hopefully will gum up the grinder wheel...
    And there isn't a way to get in there with a sawzal blade easily. It will definitely be a very inconvenient 5-10 minute sawing with hot aluminum flakes falling onto your face
    PBNB likes this.
  12. May 15, 2023 at 8:53 AM
    #102
    Gaston
    Gaston New Member
    Gary
    SE MI
    Well from pictures and videos I've seen of people getting caught climbing out from under a vehicle they've had a sawzall, not a grinder
  13. May 15, 2023 at 9:15 AM
    #103
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think there are a few tools needed to be an efficient thief.
    1) Cordless sawsall with a metal blade long enough to cut through the pipes.
    2) Cordless grinder with a metal disk to cut the cat cover off or to cut the bolt heads off (this thief would be a bit more prepared).
    3) Cordless impactor to remove the odd bolt (this would be a very dialled in thief).
    4) Key Fob cloning tool to just drive the truck away to the chop shop!
    The noise that cutting will make will be unbearable and should wake everyone up!
  14. May 15, 2023 at 9:52 AM
    #104
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    I believe Talon makes a skid that goes between the engine and the cat skids.
    I chose the Talon Garage Aluminum because I had Aluminum Skids on my Jeep and beat the hell out of them and they took a beating, the steel ones would rust and get bent. Add enough steel to your truck and it will start to affect payload and mpg's.
  15. May 17, 2023 at 12:13 AM
    #105
    Kap1
    San Francisco, CA
    Yes, they do have Sawzall, but it would be very tough to cut off the shield with Sawzall blade. The room is very tight and won't give much space for the reciprocating saw to go up down... You probably going to end up breaking the saw and it ending up in your face
  16. May 17, 2023 at 3:33 AM
    #106
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Talons plate is sandwiched between TRD skid and frame. You need to bend the tab on the TRD skid to make clearance for the Talons to fit flush. Make sure to install the third Talons hanger bolt on the front before you reinstall the TRD skid. That bolt holds the Talons plate up on the front so that the 2 smaller bolts... best to use the security bolts... only support the rear of the TRD skid. Some of the other cat protector brands seem to not have that front hanger bolt which seems a little sketchy to me. Plus, with a setup like the Talons, when you pull the TRD skid for an oil change you do not loosen or disturb the cat shield at all.
  17. May 17, 2023 at 6:14 AM
    #107
    Gaston
    Gaston New Member
    Gary
    SE MI
    there is plenty of room for a blade to go up and down under there, how else do you think thieves use sawzalls to cut the exhaust pipe? They aren't straight up and down but they aren't horizontal either and the exhaust pipe is closer to the underbody than the shield is
    besides, and I have yet to hear of a shield being cut off
  18. May 18, 2023 at 8:56 PM
    #108
    Kap1
    San Francisco, CA
    Have you installed a shield on a 22? I have
  19. May 19, 2023 at 5:29 AM
    #109
    Gaston
    Gaston New Member
    Gary
    SE MI
    nope, but I've looked under one and there is plenty of room for a sawzall to cut the exhaust and shield if a thief wanted to
  20. May 19, 2023 at 5:47 AM
    #110
    Kap1
    San Francisco, CA
    Ok, you're right.
    However, the points where shield mounts can't be accessed and cut easily, they'll have to cut a few inches away from the bolts meaning they'll be cutting about 10 inches of thick 1/4 in aluminum in 3 separate places to bend the shield off, and some of these places don't have any room behind it to get sawzall in. All I'm saying it's going to be not easy by any means and will take 5-10 min of loud and persistent cutting under the truck (assuming your blade won't break) . Then another few min to cut both cats off. They would really want your cats and not be afraid to spend all the time making noise hoping you won't come out to help them.
    raylo and Gaston[QUOTED] like this.
  21. May 19, 2023 at 6:26 AM
    #111
    Gaston
    Gaston New Member
    Gary
    SE MI
    Agreed
  22. May 22, 2023 at 7:46 AM
    #112
    Willyd6869
    Willyd6869 New Member
    22 Tundra TRD Pro
    Here is a photo of how they interact. Very easy install. Took half an hour. You do have to hammer down the little tab/hanger on the rear of the TRD Pro skid plate to make room for the shield to slide over. I didn't use the hanger bolt since it seemed like it would not allow the skid plate to sit flush to the shield. I will re-examine this though.
    My workflow was:
    Remove TRD Pro skid plate by loosening front 2 bolts and removing back 4.
    Slide it off and then hammer down the little tab.
    Re-install skid plate with bolts just engaged a few threads.
    Place the Talons shield between the skid plate and crossmember to hold the front up and support the back of it with your chest, leg, whatever.
    Remove one of the skid plate rear bolts and pivot the Talons into position, so the hole lines up (you use the hole and not the slot) and reinstall screw.
    Do the same on the other side.
    Now scoot to the rear of the shield and install the 2 bolts. It will be supported in the front and require minimum support in the rear.
    Then go around and tighten everything up.
    The Talons shield is very nice and fits great. Fast shipping too. I highly recommend it.
    ReCKzX, Yaboy, G3ardnut and 1 other person like this.
  23. Jun 15, 2023 at 7:31 AM
    #113
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    ??? any of you know if Talon or TacoTune have a history of running 4th of July sales? I'm looking to purchase soon. Possibly I should just call them! TIA.
    EDIT #1: Calling and asking about discounts works. Got the one I wanted for 15% off with security hardware and free shipping. Now waiting for delivery!
    EDIT #2: Got my Cat Shield and installed it. Impressive and perfect fit -easy to install. Thanks to Josh! Great Customer service to match their product and fast shipping/delivery. Call them. You won't be disappointed.
