  1. Jun 12, 2023 at 1:12 PM
    Jasons2006Tundra
    Jasons2006Tundra New Member
    2006 Tundra DC SR5 4wd 4.7 TRD
    I just bought a 2006 Tundra DB 4x4 TRD and this forum has already helped tremendously. Specifically with tightening the bolts to spec on the valve covers, that stopped a leak.
    So far I have replaced the wheels with snowflakes from a 2019 Tacoma. Replaced the air filter, PCV, and swaybar links. Cleaned the maf and throttle body. Next is fluid changes.
    Today the truck is at the local shop for a new spare tire and to get the brakes done (I don't yet trust my DIY skills to do the brakes myself)
    shifty`, DJenerated, bmf4069 and 5 others like this.
  2. Jun 12, 2023 at 1:20 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    How many miles are on it? Has the timing belt been done?
  3. Jun 12, 2023 at 1:39 PM
    Jasons2006Tundra
    Its got 160k. The timing belt, water pump, and radiator were replaced in December '22. It's got some rust underneath that's why I did the sway bar links right away, one was rusted off.
    I'd like to raise up the front so it sits level to the stock rear height, what setup would u recommend?
    Voss likes this.
  4. Jun 12, 2023 at 2:15 PM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    That's out of my area of expertise. Though I have no doubt that there may be more than a few members here that can help you out.
  5. Jun 12, 2023 at 5:06 PM
    Confused_02_base
    Confused_02_base New Member
    2003 Base V6 - various nicks and dings
    STOCK
    V70R has a 5 year old battery. Cranks just fine. Our 7 year old Nissan is strong as day 1 on the lot. Definitely something draining the Toyota. Read somewhere the likely culprit is the factory anti-theft system. Could also be AAA batteries lol.
  6. Jun 12, 2023 at 5:34 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Congrats on the new truck! As for the front lift, depends how much you wanna spend?$$$
    cheap and dependable, something I ran for many years were Bilstein 5100’s on I think the 1st notch.
    bmf4069, oscardog86 and FrenchToasty like this.
  7. Jun 12, 2023 at 8:09 PM
    Voss and bmf4069 like this.
  8. Jun 12, 2023 at 9:06 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My polaris side by side battery is original at 7 years old. As of Saturday night it's lasted longer than the engine. LINK
    Confused_02_base likes this.
  9. Jun 13, 2023 at 8:36 AM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    Quick question - I need to replace the grease zerk on my driveshaft slip yoke. Is this special to Toyota or can I just stop at Fleet Farm & grab some?
  10. Jun 13, 2023 at 8:58 AM
    bfunke
    bfunke Tundra Curmudgeon
    I think they are M6-1.0
  11. Jun 13, 2023 at 9:20 AM
    Jasons2006Tundra
    Bingo, I replaced one single zirk yesterday. The 1/4" size looks the same but doesn't fit. Had to go back to napa and ask for the metric size, they couldn't figure out which one I needed but I guessed at it and got it right somehow.
    NUDRAT, bmf4069, oscardog86 and 2 others like this.
  12. Jun 16, 2023 at 7:41 AM
    It’s like TS up in here :tumbleweed:
  13. Jun 16, 2023 at 7:50 AM
    Who is in charge of the Friday poll?
    bmf4069 and DJenerated like this.
  14. Jun 16, 2023 at 8:22 AM
    Summertime, everyone on vacation :rofl:
    I nominate you.
    bmf4069 likes this.
  15. Jun 17, 2023 at 5:14 AM
    Friday poll is whoever posts one first. If it doesn't get posted here, and say in the off topic thread, link it in the lunchtable.
  16. Jun 17, 2023 at 10:07 AM
    Voss
    Valod
    2003 AC TRD 4x4
    She got all cleaned up today. Sure had been a while7E6D18B8-FA69-41D0-A498-6D3C53CDF2C4.jpgAnd a clean air filter.
    Figured out my hood latch issue. Wouldn’t unlock unless someone pulled the hood up while someone pulled the latch… little plastic clip broke794D235D-5825-4DE6-87D3-020D1B8EAAA5.jpgluckily had a zip tie handy. Line now held down and works good enough. Bless the soul who created the zip tie.
    **Edit to note, the zip tie fix didn’t last long. I can open the hood but latch won’t retract now, keeping the hood unlocked. Worked for a bit but clearly not a long term solution. 20C6E3EA-C253-48CE-BBA2-015D8CB9AF41.jpg
    So many loose bolts! @FirstGenVol, I’ll be keeping the little wrench in a more accessible place after T2S lol.1BDC2DFD-F782-4423-A706-D9AF5350855D.jpg
    Halfway to losing a few skid plate bolts. 8E8BA9CB-EF9C-4641-AF63-760FA75E5C2A.jpg
    bmf4069, oscardog86, abcinv and 7 others like this.
  17. Jun 17, 2023 at 1:27 PM
    Confused_02_base
    STOCK
    Attempted to remove the shell. Epic failure :rofl:
    Gonna take 2 minimum to pry away all the old weather sealant along the bed. Put the clamps back on took it for a spin. Test fit the fog lights and ordered some Hertz K 170 components to replace the dead speakers. Happy truck :bananadance:
    For shiggles and giggles, I called my local dealership to get a price on drip molding for the RC...$138. "Wow! For the pair?" Nope, each. :spending:
    Wishful thinking. Buying the pair for $130 on the innerwebz (not Amazon shifty ').
    shifty`, Voss and oscardog86 like this.
  18. Jun 17, 2023 at 1:42 PM
    Jasons2006Tundra
    First oil change done. Changed the diff fluid in the front&rear diffs and transfer case, new washers, new rear diff fill plug. Greased all the zerks. Cleaned battery terminals.
    I think the Taco is getting jealous, the new Tundra is getting all the attention. :)
    bmf4069, NUDRAT, FrenchToasty and 3 others like this.
  19. Jun 17, 2023 at 6:29 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Sold it. Literally gone in 60 seconds.
    oscardog86, NUDRAT and FrenchToasty like this.
  20. Jun 17, 2023 at 10:21 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    You sold the 'Quioa? Dam, that was a nice looking 'Quioa.
  21. Jun 17, 2023 at 10:39 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Y'all talking about quinoa in here now?
    Mr.bee and FrenchToasty like this.
  22. Jun 17, 2023 at 10:44 PM
    artsr2002
    'Yonder
    No not quinoa, a 'Quioa. LOL
  23. Jun 17, 2023 at 11:58 PM
    drobb
    Yep, she gone. We had her 18 years. Great vehicle!!!!!!
  24. Jun 18, 2023 at 8:50 AM
    Fumoto Valves sure do make this easy. Finally changing the oil after T2S as I got closer to 5k miles. @jpink convinced me to go with Pennzoil this time and Wally World had it marked down.
  25. Jun 18, 2023 at 11:28 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Finished up a minor project I started yesterday that ties the front map lights into the back dome light circuit so they come on when opening the door or via open door with remote.
    Kicked back now watching US Open.
    artsr2002, shifty`, bmf4069 and 3 others like this.
  26. Jun 18, 2023 at 4:15 PM
    Casper421
    In the woods
    06 DC
    Drove her up to a favorite lake of ours to let the boys swim. Surprised at how much snow is still on the ground at 6k feet.
  27. Jun 18, 2023 at 4:23 PM
    Sup dogs
    Voss, artsr2002 and bmf4069 like this.
  28. Jun 19, 2023 at 5:38 AM
    I got spares on-hand :D
    If you ever want to refresh or lose one, skid plate bolt's p/n is 9008011373 aka 90080-11373
  29. Jun 19, 2023 at 9:54 AM
    New tailgate handle, and greased all the contact points, then spray glued the grass back down 9C3C28CF-CFAF-438B-9B37-5321096BAAF5.jpg89EBB4B0-859C-45FB-8513-7A3D73CE809E.jpg
    Bmktw2, metalpete, SateenC1 and 12 others like this.
  30. Jun 19, 2023 at 3:04 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    Had dual exhaust put on (Super Flowmaster 44), Dirty Deeds 12hole 250cc injectors, MSD Coils and AfE cold air intake. Runs and sounds great, so smooth. Also put on Pedal Commander set to City -3 and tuned out the big throttle hesitation at initial start off. 20230619_144708.jpg 20230619_144721.jpg 20230524_152920.jpg
