  1. Jun 9, 2023 at 6:06 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    New bumper idea. Just 250lbs for the 67".
    NUDRAT and Voss like this.
  2. Jun 9, 2023 at 6:10 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    How often do you use your rear seatbelt?7737E3A4-1100-47B9-9437-FCD1B2AC0BE6.jpg
  3. Jun 9, 2023 at 6:14 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I like your setup. Never use the rear seatbelt. How do you have that mounted?
    Voss[QUOTED] likes this.
  4. Jun 9, 2023 at 6:22 PM
    Voss
    2003 AC TRD 4x4
    For the top, same bolt used for seatbelt in same spot and took off the panel for the bottom bolt n nut. Put bottom on while panel is off then screw in original seatbelt bolt after panel is on
    oscardog86 and FrenchToasty like this.
  5. Jun 9, 2023 at 6:46 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Dude your rear seat delete is way nice.
    I need to step up me game. I just have to be careful with my electric rear slider window guts.
  6. Jun 10, 2023 at 11:46 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Got the emissions taken care of today, easy pass.
    bmf4069, Voss, NUDRAT and 1 other person like this.
  7. Jun 10, 2023 at 11:49 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Thanks for the reminder, I need to put this on the agenda for both vehicles. And 10 tires, 5 for both vehicles. Gonna be an expensive month...
    bmf4069 and FrenchToasty like this.
  8. Jun 10, 2023 at 11:53 AM
    abcinv
    Tommy
    NW Georgia
    That will cost ya! I've been chewing on new tires for the Tundra; think I'll keep putting it off. Plenty of tread but one hasn't worn well due to a leak I didn't manage like I should have; causes a little un-smoothness...
  9. Jun 10, 2023 at 12:10 PM
    I'm still going back and forth on sizing, and whether to update tires before or after lift. Gotta get realigned for both, so I'd prefer to knock out both at the same time, timing that out is a PITA for me.
    abcinv[QUOTED] and FrenchToasty like this.
  10. Jun 10, 2023 at 3:37 PM
    daveeasa
    Driving to alignment after lift, UCA’s and tires is entertaining.
    bmf4069, DJenerated and NUDRAT like this.
  11. Jun 10, 2023 at 4:21 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Are you mounting those on the new wheels you got or did you change your mind there?
  12. Jun 10, 2023 at 5:13 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I decided to have a second go at removing my stuck diff plug. No luck using heat, ended up stripping it out. Went to HF and picked up some easy outs, I've heard good things about the Icon brand so went with those. Hammered the sucker in, worked the breaker bar for a few minutes and it finally broke loose. Replaced it with Lexus plugs. Also picked up an air cleaner and some MAF cleaner while I was in town since I'm throwing a code.
  13. Jun 10, 2023 at 5:18 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Were you able to get the easy out out?
    oscardog86 likes this.
  14. Jun 10, 2023 at 5:20 PM
    des2mtn
    SW
    Tonto cover
    Nah, it wouldn't hold in the bench vise. Will try grinding some flat spots on the plug tomorrow, didn't feel like messing with it tonight.
  15. Jun 10, 2023 at 5:21 PM
    I’m surprised yours actually stuck being from South Cali. Do you have a slow leak there from the CV axle?
    oscardog86 and des2mtn[QUOTED] like this.
  16. Jun 10, 2023 at 5:25 PM
    des2mtn
    SW
    Tonto cover
    Axle seals are fine, that's probably WD-40 you're seeing. I tried messing with it about a year ago, but knew it was going to strip then. Only bolt that has really given me grief on the truck
    Toyota serviced the front diff at around 75k, maybe they put it on with an impact.
  17. Jun 10, 2023 at 5:27 PM
    You’re probably right about the impact. haha
    oscardog86 and des2mtn like this.
  18. Jun 10, 2023 at 6:23 PM
    Dunno about '04 but I noticed on my '06 diff plugs were allen-head for the first 6-8mm, then deeper into the plug it switches to Torx. I'm assuming this is a fail-safe in the event the allenhead gets stripped. Curious, yours weren't same?
    Pending work:
    • New rims, 17x9 / -12
    • New TPMS
    • New tires on those new rims
    • UCA + CO + ext sway links
    • Realignment
    Still debating on tires. Go with chunkier 275/70r17 which will fit w/o lift, but max recommended wheel width is 8.5" so I'm looking at a some stretch. Or go with 285/70r17 which I'll almost surely rub w/o lift.
    I really don't mind the stretch to fill that half inch, but I hate picking wheels and tires and haven't picked the brains of the two IRL friends I know who are savants with wheel/tire combos yet.
    Once I get the above bullets knocked off, I'll be finishing out stereo stuff.
    oscardog86, bmf4069 and abcinv like this.
  19. Jun 10, 2023 at 7:04 PM
    des2mtn
    SW
    Tonto cover
    Not sure, I did try a T-55 per TW's advice with no luck though.
  20. Jun 10, 2023 at 7:29 PM
    Confused_02_base
    Confused_02_base New Member
    2003 Base V6 - various nicks and dings
    STOCK
    New battery. Thank you AAA. 3 years old and done. Alternator tested 'good'. Tracking down the draw has been added to the list.
    bmf4069, Voss, JasonC. and 1 other person like this.
  21. Jun 10, 2023 at 7:45 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Could also grip the remover with the vice and use a pipe wrench (or knipex) on the plug.
  22. Jun 10, 2023 at 9:12 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I've heard a lot of people say they only got 3 years out of a modern battery. i think 5 years is becoming the exception.
    Date stamp on the RV's battery I was re-installing today is 12/11, but spends most of it's life sucking on the teats of a charger so...
    FWIW, it's a Walmart branded battery.
    w666, txagg and Casper421 like this.
  23. Jun 10, 2023 at 10:30 PM
    Casper421
    In the woods
    06 DC
    Installed my Odyssey March 2018 and 2 months ago it tested at 952 cca’s. Somehow more than their website states. :notsure:
    oscardog86, txagg, Voss and 1 other person like this.
  24. Jun 11, 2023 at 10:37 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    my sears die hard platium (odyssey rebranded back in the day) is 12 years old and still tests over 800 CCA. LOL
  25. Jun 11, 2023 at 1:03 PM
    Or grip the plug in the vise, spin the extractor in reverse. Or get a tap and die set, drill and tap a hole in some steel stock, then torque it down in with the extractor until the extractor comes free, then hang it on the wall as an award.
  26. Jun 11, 2023 at 5:00 PM
    Just reached out again today, since I can't remember wtf they said last time...
    But maybe pushing them every 6 months is the way to go about it, versus pinging them every year...
    Voss and FrenchToasty like this.
  27. Jun 11, 2023 at 6:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Not quite tundra specific... but grant me this.
    Made a set of double layer leather hinges for my big cooler.
    they open all the way, but dont wanna stay open. Perfect.
    next time i go to town i'll get a bag of ice for the big cooler and a bag for the cooler i had at t2s & see which one keeps longer. Both igloos, no rubber seals, and free.
  28. Jun 11, 2023 at 7:39 PM
    DJenerated
    Dija
    The Lone Star State
    Might check out Walmarts version of the yeti coolers while you're there. Probably the most cost effective way to save ice.
    oscardog86, FirstGenVol and KNABORES like this.
  29. Jun 12, 2023 at 9:43 AM
    Welp, guess I'll check back in 12 months to see if they're carrying 1st gen stuff :rofl:
    Voss likes this.
  30. Jun 12, 2023 at 12:01 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    When you walk into Renaissance Fair the witch lady at the gate will be like, "sir, that cooler's a bit anachronistic don't you thi--"//sees leather hinges, girdle splits open, faints//
