Strange intermittent vibration at 65 mph, driveshaft?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GNX6, May 1, 2017.
  1. Dec 8, 2019 at 6:15 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Has to be aftermarket then because I have a 2014 and have zerks. That may be your problem, shafts aftermarket and not balanced properly?
    15whtrd and Rica25 like this.
  2. Dec 8, 2019 at 6:22 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    I’ll raise it at work and have a closer look. I got under the car and just felt around with it in the driveway.
    I know when I worked at GM original joints had no grease fittings but replacement GM ones did.
    Does the fitting stick out or is it sunk in?
    Rica25 likes this.
  3. Dec 8, 2019 at 6:23 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    From what I recall, it's in there.
    When my wife gets home and takes over little man duties I'll take a quick pic if I don't forget....tired lol
  4. Dec 8, 2019 at 6:28 PM
    Rica25
    Ricardo
    Tulare
    Mine is also two piece with no zerk.....and I've had it since 2008 so no it's not aftermarket
    Rocko9999 likes this.
  5. Dec 8, 2019 at 7:05 PM
    15whtrd
    15whtrd Mr. Blonde
    The zerks are painted over and it needs to be scraped off.
    Rica25 likes this.
  6. Dec 8, 2019 at 7:08 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Pics are for RWD and not the forward shaft.
    Fed ones hidden, main shafts are right there easy to see, access.
    Rica25 likes this.
  7. Dec 8, 2019 at 7:14 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    You 2wd or 4x4?
  8. Dec 8, 2019 at 7:15 PM
    Rica25
    Ricardo
    Tulare
  9. Dec 8, 2019 at 7:16 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    @GNX6 are you 2wd or 4x4?
    Starting to think maybe 2wd don't have zerks.
    15whtrd and Rica25[QUOTED] like this.
  10. Dec 8, 2019 at 7:38 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Talked with my chassis buddy at Toyota...there is no rhyme or reason, some have em some don't
    Rica25 likes this.
  11. Dec 15, 2019 at 8:26 PM
    Wahayes
    Will
    2017 tundra limited
    So I had an issue similar to this when I bought mine. I have the 20 inch wheels and had 275/55r20 , then switched to 275/60r20 d rated. Mine turned out to be an air pressure issue. I kept 275/60r20 at 55 psi (recommended by tire manufacturer and have zero issues.) If i air down to 45 it vibrates at that speed. When I had the stock tires p rated they always vibrated regardless of air pressure. I came to the conclusion p rated tires were too weak a tire for the weight of our trucks. With the d rated tires it requires more pressure to prevent the tire vibration. Just my experience.
    Rica25 likes this.
  12. Apr 26, 2021 at 3:18 PM
    mosestoyota
    mosestoyota New Member
    2002 4X4 TRD SR5
    I have a 2002, it shakes a lot.... It also makes a clonk sound when I press the pedal, every time.
    I was surprised to see the owner manual recommended 29 and 26 PSI in the tires! My Ford is 60 & 80.
    Im curious if it's the tires.....
  13. Apr 30, 2021 at 7:35 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    My 2020 CM TRD Sport with only 6k miles does the same thing. Very irritating!
  14. Mar 31, 2022 at 7:44 AM
    HuntFish.
    HuntFish. New Member
    2021 Tundra
    I have same problem. From 60 to 70mph vibration. Seems Front right passenger side. And yes I do hear a clunk when begining my drive in the morning. And every time after starting my truck & putting it in drive.????
  15. Mar 31, 2022 at 7:46 AM
    HuntFish.
    2021 Tundra
    No one mentioned alingment,or wheelbalance. I’m driving factory Nitto Grapperlers18”
  16. Mar 31, 2022 at 8:10 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    clunk is probably the ABS self check. Normal.
    and yes, most often vibrations are usually related to wheel balance if the truck is in good shape and no worn suspension/steering components.
  17. Mar 31, 2022 at 1:42 PM
    HuntFish.
    2021 Tundra
    Ty for your reply!
  18. Jun 12, 2023 at 8:29 AM
    Seraphinwolf
    Seraphinwolf New Member
    10’ 4.6 Grade TRD Offroad
    In case someone else comes looking. Also check your parking brakes. There’s an outrigger inline under the truck about where the driver’s door and rear door meet. Seizes up BAD! Mine was so bad in my 10’ that the cable at the pedal was sticking out like 1.5-2”. Blasted the out of it with PB Blast and grabbed a big hammer to pull the tension back on and remove the slack at the pedal.
    Figured it was worth sharing.
