  1. Jun 4, 2023 at 6:00 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
  2. Jun 4, 2023 at 6:02 PM
    Mountainmanjh
    Mountainmanjh New Member
    Northern Utah
    2012 Black Crewmax
    Eibach Protruck coilovers and shocks Total Chaos UCAs, bed stiffeners Deaver U748 leaf springs with Camburg shackles TRD sway bars, front and rear Gear Dominator wheels (18x9 18+) Cooper AT3 XLT (275/70r18) RCI engine, trans, and A-arm skids Transferflow 46-gal fuel tank Yakima Outpost bed rack Curt front hitch receiver SumoSprings (yellow) StartX remote start *coming soon* Auburn rear LSD RCI sliders, diff skid, cat guards Coastal offroad front bumper Badlands apex winch Kenwood DNX577S head unit
    Utah got rid of theirs years ago
  3. Jun 4, 2023 at 6:12 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :hattip:
    ....got to go fix that shit!!!!! :anonymous:
  4. Jun 5, 2023 at 9:16 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Dropped the truck off a the shop to have new wheel bearings installed in the rear end….
    joseph_womack likes this.
  5. Jun 6, 2023 at 7:41 AM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    Finally got the new wheels and tires balanced and on the truck last night. From the steel wheels to the aluminum. To me a big upgrade.
    pvn.beluga, Neo258, hhenry_ and 15 others like this.
  6. Jun 7, 2023 at 8:54 PM
    Retroboy1989
    Northern Utah
    They dropped safety in Utah, but we still have to do emission and pay registration fees. The ones that lost out were the safety inspection stations.
    French Avocado likes this.
  7. Jun 9, 2023 at 8:06 AM
    Jtimon
    Jtimon New Member
    Very pretty!
    Yinzer73[QUOTED] likes this.
  8. Jun 9, 2023 at 5:12 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Not installed yet, but these just arrived.
    Edit: pulled the skid plate and front sway bar off. Put PB blast on all the front nuts/bolts that will get removed.
    Pulled the rear shocks off and they were thoroughly dead.
    Tomorrow, I'll put stands under all 4 corners and take wheels off. I will pull the coilovers off and then wash the frame and everything else I can reach underneath with soap, a rag and brush. Then, I will put stuff back together with the new suspension parts.
  9. Jun 9, 2023 at 6:10 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Had new rear wheel bearing installed...boy it's a quite ride now!
    On a side not, when I picked it up, and started to drive, a "check engine" light cme on, and the truck wouldn't go over 25mph.
    Went back to the shop and the owner thru a computer on it and it indicated a fault with the secondary injection pump....he cleared it and pff I went.
    This is the second time I've had this code trip if I recall correctly...
  10. Jun 9, 2023 at 8:11 PM
    Retroboy1989
    Northern Utah
    Gave it a between-camping-trips wash.
    Pulled like a champ, as always. 5w30 giving me piece of mind at 2800rpm in S4. Somehow managed 10.4mpg on the way home. 9.3 on the way there.
    Interior is still camping dirty, but the next trip is for a youth group. No doubt the interior will need a deep clean after that trip.
    D4x4TRD, Mountun Goat, WVI and 5 others like this.
  11. Jun 10, 2023 at 10:08 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    13:00 just came in from outside where I washed and clay barred my 2007 CM, then I finally worked up enough nerve to polish the beast. I used Griot's complete compound and my Bauer RO polisher. It was my first step ever into polishing and I'll have to say I am pleased with the results although they are no where near what some of you guys can do. Next up will be applying sealer, and then later on in the year a good paste wax to hold me through the winter.
    Mountun Goat, WVI and Tripleconpanna like this.
  12. Jun 10, 2023 at 10:45 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    :worthless:
  13. Jun 10, 2023 at 10:51 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Don't ever expect me to post pics of anything,no matter what it is. I'll live with worthless.:D
  14. Jun 10, 2023 at 2:19 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Installed a KTJO 4X4 power lock for the tailgate. Cheaper and easier than the pop n lock system. I’d highly recommend and wish I’d have done it years ago!
    D4x4TRD, Mountun Goat, tnbndr and 4 others like this.
  15. Jun 10, 2023 at 3:32 PM
    Retroboy1989
    Northern Utah
    Plug and play? Did I see that right?
    Tripleconpanna likes this.
  16. Jun 10, 2023 at 5:09 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Yessir! Zero wire splicing what so ever! Check them out! With military discount it was only $85!
  17. Jun 10, 2023 at 5:10 PM
    Windsor
    Homeless in Oregon
    Some.
    Just need to put the sway bar back on. Leaving the skid plate off until aligned.
    Not perfectly clean, but a vast improvement. I am drenched and there is a lot of mud in the driveway...
  18. Jun 10, 2023 at 6:20 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Soooo, chased the tranny man again and turns out my beast was throwing codes because it was missing about a quart of fluid. :angrygirl:
    Caused by a leaking gasket, new one should arrive this week. Begs the question why is a fully refurbished transmission leaking through a gasket, surely the chap used new gaskets when he put it back in?... :monocle:
  19. Jun 10, 2023 at 6:32 PM
    Retroboy1989
    Northern Utah
    Pinched, over torqued, under torqued
  20. Jun 10, 2023 at 6:54 PM
    Tripleconpanna
    Exactly!!! Like most of the problems these days; a lack of attention to detail :facepalm:
    TheBrit likes this.
  21. Jun 10, 2023 at 7:39 PM
    TheBrit
    Mark
    If this were some stealership with a high turnover of young wannabes I'd be the first to agree with you but this chap is old school and I've had occasion to use his services several times in the last ten years with no problems. Out here in the sticks he's recognized as the person to go to for tranny issues. Sure, we all have bad days so a torquing issue is quite possible but the bloke is quite OCD when it comes to mechanical stuff...
    The first time I used him I left him with an Explorer SportTrac to finish off after I stripped and rebuilt the tranny myself, all he had to do was put the torque converter in it and rehang it after I ran out of time and had to head back to work in Florida, so I do have some idea at spotting iffy mechanics.
    The wait has been a pain in the butt although I don't push it because he's always up to his eyeballs in work but prioritises the working man's vehicles when they roll up. When I, or several folks I know, haven't had a second truck for work he's shunted everyone else back to get them on the road again.
    It's not ideal being without the Tundra but at least the Frontier gets me from a to b, has done all I've needed from it and he is fully aware that, I'm sure he'd have had it on the ramp the same day I brought it back to check it out if I were stranded for a truck...At least, that's what I keep reminding myself :rolleyes:
  22. Jun 11, 2023 at 5:23 PM
    Windsor
    Homeless in Oregon
    Some.
    Pulled door panels out and cleaned them to get the super fine dust out out of the pockets. Went ahead and cleaned to inner door skin, door openings and all interior plastic (even the hidden stuff under/behind/next to seats) while I was there. Going to let the panels dry out over night before putting them back in.
    After dinner, I'm going to wash the truck. It'll be nice and clean for my next trip to town when I'm getting the alignment done. But before that, I'm going to find a nice flat spot to measure the fender height to figure out where to set the coilover height.
    joseph_womack and WVI like this.
  23. Jun 11, 2023 at 7:43 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    No code scan yet, but I disconnected the battery and let it sit while I mowed the yard and pressure washed the driveway. Reconnected everything and it woke up in a better mood. Took it for a quick test drive and it runs normally.
    The morning it threw a hissy fit I noticed the coolant reservoir was looking low. Now it always does and I constantly add to it because it’s never liked to stay at the factory full mark since new, probably because it’s not actually low…
    So anyway I added a bunch of premixed coolant and overflowed the reservoir with the truck running. I now wonder if there’s a sensor the tripped making the truck think it was overheated or something?
  24. Jun 11, 2023 at 7:54 PM
    Tripleconpanna
    Don't know; but much less of that going on in your '07 than in the TuRD Gens :thumbsup:
  25. Jun 12, 2023 at 10:07 AM
    Windsor
    Homeless in Oregon
    Some.
    Adjusting my eibach stage 2 coilovers. Got the passenger side dropped 1/2 inch. Started to do the driver side to drop 1/4" and the damn spanner wrench broke.
    Welded pin was brittle, crystal structure at the point of failure. Ended up cutting the welded pin out of the handle and having a buddy TIG a grade 8 bolt in (cut the thread off so it was just the smooth body of the bolt). It is a 1/4" hole, so I had plenty of bolts in the bin.
  26. Jun 12, 2023 at 1:10 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    I recall getting the door lock and window switch connectors apart was a serious PITA. An extra hand would have been useful.
    Anyone have a pn for that missing felt pad?
  27. Jun 12, 2023 at 2:27 PM
    Coal Dragger
    Kung Fu Dick
    Put a code reader on it:
    P2443
    Secondary Air Injection System Switching Valve Stuck Closed, bank 2.
    Well, that sucks.
  28. Jun 12, 2023 at 2:40 PM
    Tripleconpanna
    That does suck... Is that one of the codes the by-pass system can fix, or is it one of the excluded codes (meaning an actual mechanical problem)??
  29. Jun 12, 2023 at 3:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    https://hewitt-tech.com/codes/
  30. Jun 12, 2023 at 3:53 PM
    Tripleconpanna
