GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jun 2, 2023 at 5:57 AM
    #3241
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
  2. Jun 2, 2023 at 5:58 AM
    #3242
    Jinkx
    Jinkx New Member
    Keith
  3. Jun 2, 2023 at 6:50 AM
    #3243
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Icon stage 7, Dobisons rear springs and track bar, Icon Rebound Pro wheels, MT Baja Legend 40s, JB4, Pedal Commander, AFE intakes and hot pipes
    I cut the rear crash bracket only and I have no rubbing so far. I've been off-roading but haven't done any rock-crawling. So, I cannot tell if I've technically "maxed out" the up-travel articulation yet.
    A good alignment shop should be able to push your caster forward. What UCA's do you have?
  4. Jun 2, 2023 at 7:08 PM
    #3244
    MF140
    MF140 New Member
    2023 Tundra Platinum WCP Crewmax 4x4
    I got an unrepairable flat on my front tire this week with less than 1,500 miles on them, so I decided to upgrade all four with a set of Toyo Open Country AT3s 275/65r20.
  5. Jun 2, 2023 at 7:20 PM
    #3245
    FLKX
    FLKX New Member
  6. Jun 2, 2023 at 8:28 PM
    #3246
    Markymrk
    Markymrk New Member
    2023 Tundra TRD Pro
    35" BF Goodrich KO2 Tires RetraxONE MX Bed Cover Yakima Overhaul HD Rack w/ 68" Bars
    ytank1, GojiraPRO, AND and 6 others like this.
  7. Jun 2, 2023 at 8:56 PM
    #3247
    Avy
    Avy New Member
    what's the tire and wheel set-up?
  8. Jun 2, 2023 at 11:31 PM
    #3248
    dodgemaniac
    dodgemaniac New Member
    That's the exact swap I am thinking of doing. How is the ride with AT3 compared to stock tires?
  9. Jun 2, 2023 at 11:45 PM
    #3249
    MF140
    MF140 New Member
    The shop says they'd be a stiffer ride, but I really don't notice much of a difference. I am really happy with them so far. I wanted a little more height without a lift and it fills the space up nicely.
  10. Jun 2, 2023 at 11:52 PM
    #3250
    FLKX
    FLKX New Member
    Vossen custom HF6-4, 20x9.5 +30, hub 95.1
    Pirelli Scorpion Elect/RIV 275/65R20
  11. Jun 3, 2023 at 7:26 AM
    #3251
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Group, I have a question regarding lug nuts, apologies for the ignorance if this has already been stated [tried searching].
    I have just bought a set of wheels from a company and I have no clue if I can use my existing lug nuts [2022 TRD OR - M14x15] or if I need to get a new set [60degree mag / flat seat lug hole length, etc.]. I have asked the distributer twice, no responses. Cannot get a number for the manufacturer to even call them. So a bit at a loss in terms of length and type I would need, if any, for these new wheels.
    Any help would be great.
    ARCOVT23 likes this.
  12. Jun 3, 2023 at 8:57 AM
    #3252
    Jinkx
    Jinkx New Member
    Keith
    That looks like a TRD knock off so would think it would use stock lug nuts but not 100% sure. I can tell you that the stock lug nuts will not work with after market wheels but again those looking like TRD knock offs you may want to try and see if it fits. You would know immediately yea or nea! Good luck. Maybe someone else can give a more definitive answer.
    iiawah808 and Yaboy like this.
  13. Jun 3, 2023 at 10:39 AM
    #3253
    Mrconnsmythe
    Rolled the dice, assumed they would work! Yup, no problem. Thanks for the quick reply.
    =JSG=, ryanwgregg, AND and 4 others like this.
  14. Jun 3, 2023 at 10:47 AM
    #3254
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Looks good :thumbsup:
    Keeping the moustache silver?
  15. Jun 3, 2023 at 11:11 AM
    #3255
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    What’s the company? eBay wheel?
  16. Jun 3, 2023 at 12:42 PM
    #3256
    Mrconnsmythe
    OEPlus is the Co.
  17. Jun 3, 2023 at 12:42 PM
    #3257
    Mrconnsmythe
    Nope, mustache next.
    =JSG= likes this.
  18. Jun 3, 2023 at 12:45 PM
    #3258
    Mrconnsmythe
    Probably a bit more poke than what I was thinking but that probably is because of the rubber ?! Regardless, that’s going from an OEM +60 to a +15.
    in_the_mud, PNW4X4 and Yaboy like this.
  19. Jun 3, 2023 at 1:44 PM
    #3259
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    295/70 R18
    2/1 Cornfed leveling kit.
    TundraMoe and Avy like this.
  20. Jun 3, 2023 at 4:18 PM
    #3260
    Black widow TRD
    Manuel
    truck looks great, what tonneau cover is that ?
  21. Jun 3, 2023 at 6:56 PM
    #3261
    FLKX
    FLKX New Member
    Thanks! it's the diamondback HD.
  22. Jun 3, 2023 at 7:01 PM
    #3262
    jlh589
    jlh589 New Member
    2023 Tundra Limited TRD Off Road
    285/60r20; tow hooks; screen protector...for now
    285/60r20 BFG KO2s, no lift/level. Traded in an F-150 Tremor for this...ZERO REGRETS
    [​IMG][​IMG][​IMG]
    mayan, OutCasT, ncart and 3 others like this.
  23. Jun 3, 2023 at 10:41 PM
    #3263
    Alohaservedaily
    Alohaservedaily New Member
    2023 Windchill Limited
    Trd lift kit 3” Advan 17” wheels Yokohama 35/12.5/17 tires
    What’s up guys, here’s my build out on Oahu. I got 17” Advans wrapped in 35x12.5x17. I installed the trd 3” lift as well. Minor wheel well modification but no cutting was done. Aloha
    mayan, OutCasT, ReCKzX and 4 others like this.
  24. Jun 3, 2023 at 10:46 PM
    #3264
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Servco installed the trd lift?
  25. Jun 3, 2023 at 11:00 PM
    #3265
    Alohaservedaily
    No, I took it to Mj motorsports
    iiawah808 likes this.
  26. Jun 4, 2023 at 4:09 PM
    #3266
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Love the Advans RGD2. I was considering advans in bronze metallic but they only have one size for bolt pattern 6x139.7 and it's too much poke for me with -10 offset. Would love to see it in a 18x9 and positive offset like +10. Love the concaveness of advans, way more then my Gramlights 57DRX. Advans are superlight at like 21lbs.
    mayan and iiawah808 like this.
  27. Jun 4, 2023 at 4:42 PM
    #3267
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    FN BFD are 18x9, +20, with correct hub size. Also just a hair over 22.5 lbs
  28. Jun 4, 2023 at 5:08 PM
    #3268
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Just looks like a rep of my gram lights but with correct bore size. :monocle:
  29. Jun 4, 2023 at 5:21 PM
    #3269
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    What does the center cap look like?
  30. Jun 4, 2023 at 8:24 PM
    #3270
    Bourbonator
    North ID
    '23 LE CM 6.5
    I don't know which came first, but the BFDs have been around since about 2013.
    I don't honestly know. I inspected the wheels to make sure there were no visible flaws and then put them in storage. I won't be mounting tires on them until next Spring. I didn't even open the box with the center caps. If I can finagle it, I'll just reuse the Toyota center caps.
