General Supercharger Thread
  1. Jun 1, 2023 at 9:44 AM
    #8671
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Being busy is good, but dang, communicate and 95% of the time, all will be good!
    snivilous[OP] and reywcms like this.
  2. Jun 1, 2023 at 9:45 AM
    #8672
    HulkSmurf14
    2014 Tundra Limited
    I threw in a TRD Radiator Cap this morning...we'll see...I had a 10 min roll into work so not enough to see anything...
    Winks4x4Toy, reywcms and M3Tundra-JK like this.
  3. Jun 1, 2023 at 9:55 AM
    #8673
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ordered a couple wide bands for us. Hopefully get that in here soon and get his tuned. Then install all this crap in a few weeks that I have in the garage. lol
    Winks4x4Toy and 50Shades like this.
  4. Jun 1, 2023 at 10:48 AM
    #8674
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Found this dyno testing result of a TB coolant bypass on a WS6. Really looking forward to driving the truck more and seeing if the lower IATs remain consistent. If it’s truly 10-12 degrees cooler I think it’s worth leaving bypassed for the summer months. That was just a way larger drop than I was anticipating seeing as the air passes through there so fast, and it’s such a small surface area. Its 90 here today, maybe I can drive the truck some more after work and collect more data. http://www.ws6.com/mod-8.htm
  5. Jun 1, 2023 at 11:20 AM
    #8675
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Whelp guess I’m heading to get a barbed fitting lol.
    Also discovered craven speed is basically down the street from me so I’ll head there and grab a mount lol
  6. Jun 1, 2023 at 11:32 AM
    #8676
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I had already bypassed the TB coolant, when I did the SC, I just removed the original hoses with the barb in the middle & ran a single hose, cleaner.
    If you have a gauge that is on the bigger side, see if you can get longer bolts for the pods.
    Saltyhero13 and reywcms[QUOTED] like this.
  7. Jun 1, 2023 at 11:35 AM
    #8677
    Silver17
    Eastern PA
    Technically you don’t even need that fitting if one of the hoses is long enough to just go right to the thermostat housing. I chose to do it with the barbed fitting so that everything was right there to put it back how it was quickly, and also it’s at a higher point so I figured I’d lose less coolant. It’s pretty negligible though I’d say.
    reywcms[QUOTED] and HulkSmurf14 like this.
  8. Jun 1, 2023 at 1:19 PM
    #8678
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep noticed that when I was doing it.
    Silver17[QUOTED] likes this.
  9. Jun 1, 2023 at 1:21 PM
    #8679
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I told them about the AEM issues I’ve read about they said bring it in and they’ll add the hardware and spacer etc when I get it all in
    e30cabrio[QUOTED] likes this.
  10. Jun 1, 2023 at 1:46 PM
    #8680
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yeah there is some fitment issues with the newer AEM X series and the Cravenspeed pods. You'll need spacers and mod to the mount. Take a look at the CS reviews page for the product; highlights the complaints and potential fixes.
    reywcms[QUOTED] likes this.
  11. Jun 1, 2023 at 1:55 PM
    #8681
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep, saw that. They based their initial designs off of another brand gauge. I'll get it updated for them and they can adjust it moving forward. They may use the rig for some dev of other items but we'll see.
    Saltyhero13[QUOTED] likes this.
  12. Jun 1, 2023 at 2:11 PM
    #8682
    Saltyhero13
    Yeah that will be great. Most people just want out of the box fitment. The old pods just take some magic to make it work.
  13. Jun 1, 2023 at 2:30 PM
    #8683
    Saltyhero13
    RE LTH Picked up some small gains, may not be all LTH gains. Sound is deeper and mellow. No drone or obnoxious sounds as I suspected but also on stock muffler. The sound emanates further back behind the driver position; stock header sound is is more forward between dash to below the driver.
    Modest gains:
  14. Jun 1, 2023 at 2:37 PM
    #8684
    Saltyhero13
    Oh and the Frankenstillen fuckery didn't constrain the top end even though the ID of the new tube is slightly smaller than PS intake and I am using a dry AFE filter instead of the oiled K&N.
  15. Jun 1, 2023 at 3:23 PM
    #8685
    Saltyhero13
    Yep. Same reaction as I was reading Silver's finding lol. Looks like I'm may have to consider joining that club too.
  16. Jun 1, 2023 at 4:49 PM
    #8686
    Silver17
    Eastern PA
    I did some more driving today with temps in the upper 80s. Even after driving 20 minutes and then idling it for 10 and letting it heat soak to 133, after I resumed driving I returned to roughly a 27 degree delta whenever I was lightly on the throttle. 86 ambient and 113 IAT for example. I’d call it an 8-12 degree improvement over prior to the mod. If you’re gonna do it maybe you can record your findings as well. I’d be curious if you have similar results. Also, with the trans cooler thermostat pinned open the max temp I saw today was 183, normally would have been 200+.
  17. Jun 1, 2023 at 6:27 PM
    #8687
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Drove mine this afternoon and can confirm Iat at idle in traffic cooler with longer time to heat soak. Coolant temp also down. I typically see 198-200 maybe 203 if crawling or running hard. Driving in town I saw 194-198. Once it hit 200 but then quickly back down in temp.
    Silver17[QUOTED] and HulkSmurf14 like this.
  18. Jun 1, 2023 at 6:32 PM
    #8688
    e30cabrio
    I don't have with the coolant going through, but heres my findings.
    Sitting in a parking lot 93 ambient 10 minutes, ac on, 131 IAT.
    Driving on the freeway, 10 minutes average 65mph. Ambient 93, intake 96.
    Silver17 and Saltyhero13 like this.
  19. Jun 1, 2023 at 6:39 PM
    #8689
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I also have had my trans pinned since I got the truck huge difference in temps. But I also drive in s4 full time then s5 on the freeway.
  20. Jun 2, 2023 at 5:39 AM
    #8690
    nags
    nags New Member
    Once I put headers on I never heard another whine again. Unless it was my girlfriend whining about the sound from my headers.
  21. Jun 2, 2023 at 5:44 AM
    #8691
    nags
    nags New Member
    ProSpeed outsources it to IPT.
    Saltyhero13 likes this.
  22. Jun 2, 2023 at 5:49 AM
    #8692
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    I don't know for how much longer until they start doing them in house. Mine handles the increased pressure so far so good, I'll keep giving updates later this year on it as well.
    HulkSmurf14 likes this.
  23. Jun 2, 2023 at 5:55 AM
    #8693
    nags
    nags New Member
    Is that something they're working on? When I did mine "through" ProSpeed they just had me ship it straight to IPT myself to save time on the middle-man and then I was just billed through ProSpeed.
    M3Tundra-JK and HulkSmurf14 like this.
  24. Jun 2, 2023 at 5:59 AM
    #8694
    nags
    nags New Member
    I will be grabbing one of these for sure as well.
    Winks4x4Toy[QUOTED] likes this.
  25. Jun 2, 2023 at 6:14 AM
    #8695
    nags
    nags New Member
    From what I read he was selling this and one of his other cars for some business opportunity that popped up. The other was a Skyline or Viper or something.
  26. Jun 2, 2023 at 6:22 AM
    #8696
    Winks4x4Toy
    Maryland
    I'm leaning towards yes after the conversation about it with them. Again they found stuff left on the table that they adjusted or upgraded that allowed the unit to handle more line pressure for the tuning with the hp I was at.
  27. Jun 2, 2023 at 6:26 AM
    #8697
    Winks4x4Toy
    Maryland
    Yeah the business opportunity was the new Raptor R and a F250 6.7 lol... I know I shouldn't say those words around here. He literally just needed to make room for a new project, seeing that it took so long he lost interest in it pretty much before it was even completed. I'd love to have drove that thing.
    nags[QUOTED] likes this.
  28. Jun 2, 2023 at 11:27 AM
    #8698
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    i acutally like the subtle/no whine. sounds like an old school naturally aspirated muscle car. my girlfriend would tell me to keep the windows down when we're cruising haha
  29. Jun 2, 2023 at 12:06 PM
    #8699
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    They have always been good for me, most things i get in three days.
    reywcms and Winks4x4Toy like this.
  30. Jun 2, 2023 at 7:03 PM
    #8700
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
