Help bought a lifted 2x4 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nygmen124, May 30, 2023.
  1. May 30, 2023 at 1:19 PM
    Nygmen124
    Nygmen124 [OP] New Member
    Jesus
    KY
    2014 Silver Lifted Crewmax
    6 in lift kit on a 2wd. Done by previous owner. Don't blame me.
    So I bought this truck because it was a great deal. I have a couple of issues that I need resolved. First, is there a way for me to know if the gears were changed out? (truck has 6 in lift with 35's)
    Second, because of the lift and it being a 2x4, the driveshaft, looks like they fabricated a bracket for the center bearing dropping it 2 inches and 2 inches back with a slight angle from the original bracket location. When the truck is on a flat surface I can see that the front yoke is not all the way in, about 2 inches out. Will this be a problem or is there a solution to this? Sorry, I have always had toyotas but this is my first truck so I'm not knowledgeable in this area.
  2. May 30, 2023 at 2:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Could use gps v dash speed to find if gear was change, have no idea for drive shaft tho
  3. May 30, 2023 at 2:22 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Weird about that driveshaft. They should've been able to just drop the carrier bearing without moving it forward or backward.
  4. May 31, 2023 at 7:48 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I'd start by removing the 6 inch lift ASAP.
    Black Wolf likes this.
  5. May 31, 2023 at 7:49 AM
    Lets see some pics
  6. May 31, 2023 at 5:59 PM
    Nygmen124
    Jesus
    KY
    20230531_203821.jpg 20230531_203803.jpg 20230531_203747.jpg 20230531_203727.jpg
    I would spend a lot more on removing the lift and having to replace everything than fixing the problem.
  7. May 31, 2023 at 6:10 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    kevine0001 and texasrho83 like this.
  8. May 31, 2023 at 6:13 PM
    I have never seen anything like that before.....:facepalm:
    V3N0M likes this.
  9. May 31, 2023 at 11:25 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    How is the truck lifted in the front?
    V3N0M likes this.
  10. Jun 1, 2023 at 5:55 AM
    Nygmen124
    Jesus
    KY
    It has the Rough Country 6 in lift kit.
  11. Jun 1, 2023 at 6:38 PM
    Nygmen124
    Jesus
    KY
  12. Jun 1, 2023 at 6:51 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    unfortunately no, I wasn't really aware there was another option. seems like a quality piece from some quick searching, Wheeler's off road plus other sites offer it, so don't see an issue running that instead if the drive line bolt pattern matches.
    Even though the coachbuilder option is a bit higher in price, recommended it based on his great reputation for quality parts and personally running some of his other stuff in the past.
  13. Jun 1, 2023 at 6:52 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Not to mention David caters to the Tundra crowd.
    Ryuu[QUOTED] likes this.
  14. Jun 2, 2023 at 8:39 AM
    Nygmen124
    Jesus
    KY
    ok i've ordered both the driveline spacer and the carrier bearing drop kit from Coachbuilder. I'll update you guys once installed. Thanks again.
    GODZILLA, Ryuu and 1UP like this.
  15. Jun 2, 2023 at 8:49 AM
    1UP
    1UP Truck Gang
    Good luck OP
  16. Jun 9, 2023 at 4:26 AM
    Nygmen124
    Jesus
    KY
    So I got the spacer and drop kit put in and now the truck runs a lot better. Thank you Coachbuilder20230608_183025.jpg 20230608_183003.jpg 20230608_182957.jpg
    D4x4TRD, Jaypown, Jbehredt and 5 others like this.
