  1. May 29, 2023 at 7:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm not against running 34.6"s since that's 9/10" inch more ground clearance, but only after having serious firewall/ cab surgery the proper way. I'd need to run spacers with my current wheels to clear any more width than 285s though since BFG doesn't make a skinny 16x35" tire.
    This is my driver's side frame rub after about 5 years of 285/75/16 with 4.5" backspace and ~4.0 caster.
  2. May 29, 2023 at 7:53 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Spacers. Then you'll rub the back of the wheel wells. Then you will want to adjust the caster forward. Or do some surgery
    oscardog86 likes this.
  3. May 29, 2023 at 7:57 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    My OCD says put LED bulbs in your corners so they blink as fast as your projector shrouds. LOL.
    FrenchToasty and Sunnier like this.
  4. May 29, 2023 at 7:57 PM
    DJenerated
    Dija
    The Lone Star State
    Those are angel eyes aka halos. Demon eyes are just center LEDs behind the projector like I have
    Hi06silver and FrenchToasty like this.
  5. May 29, 2023 at 8:02 PM
    DJenerated
    Dija
    The Lone Star State
    Some day. You'll see. You'll all see. :D
    RUSTYNUTS, oscardog86, NUDRAT and 3 others like this.
  6. May 29, 2023 at 8:15 PM
    DJenerated
    Dija
    The Lone Star State
    My current tires are 33.4x11.6 and my SPCs are set to -1.75°. if I install the 1" body lift in my parts pile and set the SPCs to -2.00° and buy Solo UCAs, I bet I can run 35x10.5 Kenda Klever tires with a little minor trimming of the fenders
    oscardog86 and bmf4069 like this.
  7. May 29, 2023 at 8:25 PM
    des2mtn
    SW
    Tonto cover
    Nice
  8. May 29, 2023 at 9:14 PM
    DJenerated
    Dija
    The Lone Star State
    That's what I'm thinking anyways. Time will tell.
  9. May 29, 2023 at 9:19 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You can try #1 although I don't know much about SPC...
    I had very minor frame rub in the same place that stopped as soon as I had a bit of wear on the tires.
    I run 3/4" steel spacers up front. Those won't come off.
  10. May 29, 2023 at 9:20 PM
    alb1k
    Left Coast
    It's good
    I mangled it pinning up against a big rock. So I took it off.
  11. May 30, 2023 at 4:27 AM
    Spacers are OK. Been over a year with mine.
    Voss, oscardog86 and DJenerated like this.
  12. May 30, 2023 at 4:29 AM
    Yup. My search for 35x10.5x16 turns up nothing but some serious mud tires. They have em for 17s though.
    DJenerated likes this.
  13. May 30, 2023 at 4:52 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Nope. They are just a little led chip that illumatrs the "eye" or glass part for a different look. I don't have them wired in because I wasn't aware the stuff I bought didn't come with the driver needed to make them shut off when the actual headlight turns on
  14. May 30, 2023 at 5:01 AM
    I’ve had mine on for 17 years with no issues.
  15. May 30, 2023 at 6:36 AM
    Fun times ^^
    Look who came back to pay a visit today. Same story as before: Code appeared within 3 blocks of the house after a very-cold start. This go-round, the truck was dragging ass a little after each shift so I popped in my MX+ dongle, cleared the code, and it immediately began running like normal. Checked after stopping, no 'pending' code. super weird.
    Really not looking forward to popping off my intake to investigate, so I may just buy a snake cam to look under the manifold. I know 100% where I park the truck every night is sealed, indoors, with zero evidence of rodents, and that's the only place it's stayed overnight in years. I suppose it's possible something crawled up in there while I was getting a line wet or parked off the beaten path, but ... Meh.
  16. May 30, 2023 at 8:39 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Just seeing this. Do you have a single color demon?
    Just found out I have to either run a separate switch or just have the demon eye be drowned out by the projectors at night...I swear I saw there was a way to wore in a driver of some sort to make them turn off but apparently that's only for the RGB setup.
    RUSTYNUTS likes this.
  17. May 30, 2023 at 8:45 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Ha, but then I'd have to get a resistor to trick the computer outta hyper flash. I'll just post a video every week to help cure your OCD on this.
  18. May 30, 2023 at 9:55 AM
    Well I think I solved the mystery of why only I can’t bleed the rear brakes with a 10 mm box wrench.
    Turns out the OD on the 1/4” ID hose needs to be 5/16” instead of 3/8” for the box end to fit over it.
    Now if I could only find where they sell it at a local store. Everyone seems to only have the 3/8” OD hose.
  19. May 30, 2023 at 11:05 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Go with #1 first and take it to "G." I rubbed a bit on the front fender flare after that. I used a dremel to take out a bit of the inside where it's not visible and no more rubbing. If that doesn't work, or isn't your choice, then I would go #3, just because I don't like spacers.
  20. May 30, 2023 at 11:26 AM
    DJenerated
    Dija
    The Lone Star State
    Mines cheap, so the LED is one color and comes on with the ambers. It is drowned out by the HIDs when the headlights are on
    RUSTYNUTS and Hi06silver[QUOTED] like this.
  21. May 30, 2023 at 11:36 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Replaced driver side shock after 20yrs/205K miles. Fortunately it's been a W TN resident it's whole life and F'n rust was not an issue. Pretty sure once I get pass side on tomorrow and do a test drive, I might notice a difference. Seems driver side had seen better days.
    2-shocks....OEM 48531-09330(48531-AF110), same as originals
    2-retainer, cushions....90948-A2003
    4-retainer, cushions....90948-A2004
    Voss, abcinv, bmf4069 and 7 others like this.
  22. May 30, 2023 at 1:43 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Success!
    Voss, bmf4069, NickB_01TRD and 9 others like this.
  23. May 30, 2023 at 2:04 PM
    Hi rise!
    Voss and Mr.bee[QUOTED] like this.
  24. May 30, 2023 at 2:05 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    if i trim the buells windshield a bit & back it in, it'll fit.
    the windows work, the back glass shocks work, the latches work. Might have to seal the front window.
    interested how much its gonna DP my fuel milage.
  25. May 30, 2023 at 2:07 PM
    Now pop out the windows, scuff sand and spraypaint it black!
  26. May 30, 2023 at 2:08 PM
    You can double penetrate your mpg?
  27. May 30, 2023 at 2:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    oscardog86 and NUDRAT like this.
  28. May 30, 2023 at 2:13 PM
    Need an ac unit sticking out the back window. o_O
  29. May 30, 2023 at 2:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Roof unit?
    Voss, bmf4069, DJenerated and 4 others like this.
  30. May 30, 2023 at 2:16 PM
    Holyshit, you still have the Ferd?
    I had to drink a bottle of that stuff as a kid for some GI contrast stuff. I was 12 or 13 at the time and had just passed my 1st kidney stone. This was bitd, before doctors recognized kids readily got kidney stones. They made me do so many friggin tests man. Never did figure it out, not 'til I was in my late 20s and had 4-5 episodes under my belt.
    bmf4069 and Mr.bee[QUOTED] like this.
