Chrome delete...
Discussion in '2.5 Gen Tundras (2014-2021)' started by icodeintx, Mar 21, 2022.
  1. May 28, 2023 at 1:31 PM
    #61
    icodeintx
    icodeintx [OP] New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    After removing that terrible plasti-dip from my bumpers I have finally completed the Raptor bedliner. To me the texture is perfect and this finish is awesome.
    1. Scuffed up the chrome with 80 grit orbital sander. It took about 2 sanding disk per side.
    2. Used some Goo Gone to remove any last bits of the plasti-dip.
    3. Washed the chrome.
    4. Used Was and Grease remover to clean them well.
    5. Applied 2 coats of self etching primer.
    6. Applied 2 coats of Raptor 2K
    Sanding took the most time. After the sanding was done all the rest was done in about 2 hours. Easy project with fantastic results.
    mountaingroan and Tundra234 like this.
  2. May 28, 2023 at 1:51 PM
    #62
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    DAMN! Not bad at all.
    icodeintx[QUOTED][OP] likes this.
  3. May 28, 2023 at 4:40 PM
    #63
    icodeintx
    Scott
    Palacios, Texas
    I used one can of primer and one can of Raptor for the rear. The front chrome I also used one can each.
    So looks like it will take one can to do the front bumper next week. Great deal.
    Tundra234 likes this.
  4. Jun 1, 2023 at 12:38 PM
    #64
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    I like the texture. Subtle. This is my back up plan if / when my plastidip starts to fail.
  5. Jun 1, 2023 at 12:43 PM
    #65
    RobertD
    Robert
    DFW, Texas
    I used Rustoleum Turbo bedliner right over my plastidip. Just as an option that works with what you already have.
  6. Jul 7, 2023 at 10:30 AM
    #66
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    Went the plastidip route. The glossifier wasn’t quite as glossy on the grill surround and hood bulge. Not sure if it’s because it was plastic or not. Not sure if I’ll eventually get bumpershellz or ypgrade to the Pro grille
    EC1 likes this.
  7. Jul 12, 2023 at 7:09 AM
    #67
    EC1
    EC1 Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    If/when you go BumperShellz, please make sure ALL the plastidip has been removed. Otherwise, your Shellz can and will fall off. We've experienced it first-hand
  8. Oct 15, 2024 at 9:27 PM
    #68
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    How has this held up?
  9. Oct 17, 2024 at 7:44 AM
    #69
    roughfisher
    JP
    Northern Minnesota
    I swapped the stock wheels with aftermarkets last August, I did notice some parts along the base of the spokes that pulled loose underneath. I also put a new front bumper this spring, but the bumper caps would also pull free around the fog bezels after extended highway driving. The rear caps have held up great, I touched up one little spot this spring that got scraped off road. The hood bulge and grill surround have been fine and held up through one winter and look ready for another.
