  1. May 27, 2023 at 7:53 PM
    AZTundra
    Paul
    Phoenix, AZ
    Going to be a bit of a slow project, but started removing the drywall from our patio ceiling last week. The drywall has been repaired a couple times already due to small cracks in the tapelines and screw heads over the years. Underneath the drywall I found another layer of ceiling which was a wood paneling that the drywall had been placed over. The wood paneling came down today. The plan is to replace with pine tongue and groove boards that will be stained and polyurethane coated with a satin finish. A new ceiling fan will go back in the middle of the ceiling and new electrical will be run adding a light switch and 8 or 12 flush mounted led recessed light either 4 or 6 on each side of the fan. Will post more pictures throughout the process, but will probably happen over the next month or so.
  2. May 27, 2023 at 7:56 PM
    Any reason the drywall was added over the wood paneling that you know of?
  3. May 27, 2023 at 8:06 PM
    AZTundra
    Paul
    Phoenix, AZ
    Possibly a small water leak in the roof over the patio before we moved in. We've been in the house since 2006 and the drywall has been up there since. The wood paneling had 2 small spots where it looked like possibe water stains maybe the size of a small plate near one of the corners. My guess is a small leak happened and they repaired the roof then decided to add the drywall over the paneling, but just my theory.
  4. May 27, 2023 at 8:31 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I actually have a hand one that doubles as a leaf blower. I have a large lot by California suburb standards but no where near big enough for ride on stuff.
    TaquitoBandito and TILLY[QUOTED] like this.
  5. May 27, 2023 at 9:01 PM
    Outbound
    Aaron
    Northern Alberta
    Make it a bourbon and you'll have a deal. Sign a green card app for me and the family, and I'll be your seasonal gardener. :)
  6. May 27, 2023 at 9:08 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Done! New England in the fall is pretty epic for a visit. :thumbsup:
  7. May 27, 2023 at 9:15 PM
    Outbound
    Aaron
    Northern Alberta
    Done deal for the bourbon or the green cards or both? :monocle:
  8. May 28, 2023 at 10:09 AM
    Usual lawn work, then put up a new led umbrella and hammock
  9. May 28, 2023 at 11:48 AM
    justcuz
    justcuz 2.5 Gen Member
  10. May 28, 2023 at 4:31 PM
    snoope
    snoope The Old Man
    Front of the house before the "FIX", Insurance is covering most of the damge after hail storm and this will be getting a refresh.
    When you are taking before & after photo's and someone decides to Photo Bomb... My bride :rolleyes: :cool:[​IMG]
    Side lawn work started but with New Windows being installed June 5th we will wait to install the edging & possibly wait till siding contractor
    gives me a "quick install date" More "damage replacement" :thumbsup:
    And last but not least, this Florida Room will get a complete Window replacement including Screens.. :hattip:and new siding & gutters..
  11. May 28, 2023 at 5:17 PM
  12. May 28, 2023 at 7:30 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Not to spoil your good times but how CLOSE is that to the wall and gate? I see your in Canada so might never matter but here that would probably cause high head pressure. Also nightmare to properly clean the coil if you cant remove the coil guards.
    EDIT- I was late to respond and @FrenchToasty had it covered.
  13. May 28, 2023 at 8:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Only took me 17-1/2 years after moving in, but I finally installed weather stripping around the garage doors since we just had the house repainted.
  14. May 30, 2023 at 12:07 PM
    AZTundra
    Paul
    Phoenix, AZ
    Removed all 4,613 nails and screws from the beams. Some of the nail heads broke off, so I just hammered those flush into the boards. I still need to scrape the perimeter to remove the old caulking.
    Went to Lowe's and found a fan I wanted, but they didn't have black in stock and no local stores appear to have it either. I'll have to order it online and go pick it up at Lowe's when it arrives.
    Reached out to our contractor that did our remodel about 2 years ago. Waiting for him to confirm availability and we'll get the electrical tackled next.
    I need to haul the trailer load of scrap to the dump and then go pick up the new tongue and groove boards also which will probably be next weekend.
  15. May 30, 2023 at 7:59 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    One of the first things I did when we moved into our house. I was amazed at what a difference it made in the winter. The fresh paint looks great!
  16. May 30, 2023 at 9:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    AND another "after only 17-1/2 years" knocked out tonight.
    When the house was built, two of the openings for the can lights in the porch soffit were cut a bit ugly. I had been talking for ever about making some custom round "trim" pieces to cover the ugly holes and then simply pushing the can light through a new (clean) hole.
    Well, after the repaint, I started looking and found out that they make "oops rings" made out of ~1/8" thick plastic for exactly that reason. So I ordered some, only to then discover that the can light trim on my lights are some odd-ball oversize can (6-1/2" ID) that was too big for the trim rings. So then I said eff-it, I'll just replace them with LED can lights instead. Found a set at HD with a "oil rubbed bronze" finish ring, then slipped the painted "oops ring" between that and the soffit, and done!
  17. May 31, 2023 at 4:41 AM
    justcuz
  18. May 31, 2023 at 9:21 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Gotta love goof rings, looks good!
  19. May 31, 2023 at 9:58 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Replaced 3 of 5 smoke detectors. One in my 4 pack was a dud, angry all the time. Dunno, gonna buy a couple singles & return the defect.
    AZTundra likes this.
  20. Jun 1, 2023 at 11:54 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Started the treehouse platform build for the kids. Man this is gonna be expensive!
    Going in between the two trees with the bottom about 6.5-7ft up. That’s a 2x10 on the top of the one tree brace for size reference.
  21. Jun 1, 2023 at 11:58 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    don't forget to copper green all cut edges
    CodyP likes this.
  22. Jun 1, 2023 at 3:43 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yes! Thanks. I knew I needed to cover them but wasn’t sure with what.
  23. Jun 1, 2023 at 4:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i use the same black stuff i use on live trees.
    CodyP[QUOTED] and FrenchToasty like this.
  24. Jun 3, 2023 at 2:58 PM
    NWPirate
    Zach
    WA
    I'm getting ready to pour a pad next week and looking to do an acid stain & seal on it. Does anyone have any tips/ products to use or to stay away from? I hear a poly seal is best for a satin finish.
    :hattip:
  25. Jun 3, 2023 at 8:14 PM
    PNW_Husky
    I’m a big fan of the Euclid luster seal WB 150 for a sealer.
    NWPirate[QUOTED] likes this.
  26. Jun 3, 2023 at 8:25 PM
    NWPirate
    Zach
    WA
    Appreciate it, do you have any pictures by chance?
  27. Jun 3, 2023 at 10:13 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_4604.jpg Nature doing the improvements. Front yard in full bloom.
  28. Jun 4, 2023 at 5:32 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Woke up this morning with all the aches and pains from power washing outside the house for the past 2 days. Looks really nice but not looking to doing that again anytime soon!
    TaquitoBandito, drobb and Fotnot like this.
  29. Jun 4, 2023 at 6:44 AM
    PNW_Husky
    I don’t. I use it on my exposed aggregate driveway every 3-5 years, but I’ve seen the satin (WB 150) and the high gloss (WB 300) used on stamped applications and it looks great.
  30. Jun 4, 2023 at 7:17 AM
    NWPirate
    Zach
    WA
    Good to know, thanks!
