DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. May 24, 2023 at 12:54 PM
    #2671
    king.cong.1119
    king.cong.1119 New Member
    No problem, I tried to optimize my mpg by only driving 65mph on highway haha
    CaptRussia253 likes this.
  2. May 24, 2023 at 1:57 PM
    #2672
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Same
  3. May 24, 2023 at 7:56 PM
    #2673
    simmonzz
    simmonzz New Member
    Drew
    OR
    16 4U3 CM
    Just need to order some wheels whenever they come back in stock. Should look cool hopefully I can turn lol
  4. May 25, 2023 at 8:22 AM
    #2674
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Sick Color!
    simmonzz[QUOTED] likes this.
  5. May 25, 2023 at 8:23 AM
    #2675
    simmonzz
    simmonzz New Member
    Drew
    OR
    16 4U3 CM
    wasn’t my first choice but I really like it now. Army green wasn’t worth an additional $15k to me for the same exact truck in a different color lol
  6. May 25, 2023 at 8:25 AM
    #2676
    Boisefly
    Boisefly New Member
    Boise, ID
    Funny. I wanted army green as well. Ended up with the bronze mica. Like it a lot now.
  7. May 27, 2023 at 5:25 PM
    #2677
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Looking at everyone switching to 37s is awesome! I’ve had mine for a few years now and definitely would like to go up to 40s but I don’t want it any taller then it is now. Keep them photos coming so I can make bad choices!
  8. May 29, 2023 at 8:38 PM
    #2678
    CaptRussia253
    Ruslan
    First trip with the 37s and towing the trailer. Managed to average 11.2 mpg with lots of hill climbs. Not too bad.
  9. May 29, 2023 at 8:42 PM
    #2679
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    On 5.29? Or stock gears?
  10. May 29, 2023 at 9:26 PM
    #2680
    CaptRussia253
    Ruslan
    Stock.
  11. May 30, 2023 at 1:08 AM
    #2681
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    How heavy is your trailer? I’m on the fence with 35 or 37. I have a 5,060 dry weight camper. I pull it about 1 1/2 hours one way to the campground maybe 5 times a year.
  12. May 30, 2023 at 8:38 AM
    #2682
    Boisefly
    Boisefly New Member
    Boise, ID
    Sick truck!
    V3N0M likes this.
  13. May 30, 2023 at 8:57 AM
    #2683
    CaptRussia253
    Ruslan
    Just a little heavier than yours.
  14. May 30, 2023 at 9:04 AM
    #2684
    2014 Black tundra
    2014 tundra sr5
    Thanks. I really want 37’s. You also got a nice camper. :thumbsup:
    CaptRussia253[QUOTED] likes this.
  15. May 30, 2023 at 10:49 AM
    #2685
    king.cong.1119
    That looks so clean!
    Mind to share your suspension setup and possibly wheel/tire spec? bmc?
  16. May 30, 2023 at 3:42 PM
    #2686
    VietGuy
    VietGuy New Member
    Houston
    I wish she was clean.. haven’t washed the truck in 2 years lol… currently running the RC 3.5 vertex coilovers for the front and rear with JBA upper and icon add a leaf with 2” shackles. Alot of people knock on RC, but these are by far the smoothest coilovers I’ve ever had. Smoother than the fox and foam cell pro coilovers I’ve had previously. Method nv305 18” with +25 offset and BFG KM3 37x13.5x18. Smoothest and quietest mud tires ive ever had. BMC and flattened pinch welds. Max caster on alignment and you’re golden. No rubbing on full lock and articulation.
  17. Jun 1, 2023 at 7:42 AM
    #2687
    king.cong.1119
    Pulled the trigger on 37s finally. KORITAS TIRES have them brand new for dirt cheap.
    Got a set of 5 for around $1800.
    [Not a commercial of myself] If you use code 4WDISLIFE10 you get another 10% off.
    Can't wait to have them mounted.
    roughfisher, vipgs3, coTony and 4 others like this.
  18. Jun 1, 2023 at 7:59 AM
    #2688
    VietGuy
    VietGuy New Member
    Houston
    That’s an awesome price for 37s! I wish I had 17s from the beginning but I’m satisfied with 18s for now unless I can find a set I can’t pass up on price.
  19. Jun 1, 2023 at 8:03 AM
    #2689
    king.cong.1119
    yea man, I was looking at 18in wheels but then the price of 37s tires on 18 wheels is significantly higher so I gave up.
  20. Jun 1, 2023 at 8:15 AM
    #2690
    VietGuy
    VietGuy New Member
    Houston
    At the time I started all of this, I had alot of conflicting information about 17s not fitting on the tundra and 18s with a positive offset and alot less cutting will get me to 37s. There wasn’t a big selection on 17in wheels. That was 5 years ago. If I could start over, I would lol but I can’t justify the cost to switch because I already have 37s lol. Can’t wait to see your setup once it’s done!
  21. Jun 1, 2023 at 8:20 AM
    #2691
    king.cong.1119
    Yea. I test fit 37s on 25mm offset wheels and it was not rubbing but very close. So I am thinking to get 35mm offset so it’s 10mm further away than being close.
  22. Jun 1, 2023 at 8:27 AM
    #2692
    VietGuy
    VietGuy New Member
    Houston
    just remember the more positive the offset, the more the wheels will be pushed in. Watch out for the upper control arm clearance so that the 12.5 wide won’t rub on it. That’s the big issue with having more positive offset.also if you’re rocking sway bars, they will rub with that offset.
  23. Jun 1, 2023 at 8:42 AM
    #2693
    king.cong.1119
    will do, I currently have 25mm offset, with 12.5 wide tires there is sill a healthy amount of space between tire and uca.
    VietGuy[QUOTED] likes this.
  24. Jun 1, 2023 at 10:35 AM
    #2694
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I think +25mm offset is the true "sweet spot" for an 18" rim. I have a ton of room with the 37x12.5's and will likely jump to a 37x13.5 when these wear out.
  25. Jun 1, 2023 at 11:00 AM
    #2695
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Longer wheel studs are also a smart upgrade...
    Deaner, tundra_20, V3N0M and 3 others like this.
  26. Jun 1, 2023 at 11:09 AM
    #2696
    king.cong.1119
    for the stock length wheel stud, which lug nuts are you using? I am trying to see if the ones I have now to fit ICON wheels would work for the method 705 wheels.
  27. Jun 1, 2023 at 11:28 AM
    #2697
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    The stock studs required extended lug nuts. I dont have a part number or link handy at the moment.
    The longer studs allowed me to go back to a standard lug nut.
  28. Jun 1, 2023 at 2:20 PM
    #2698
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    I’m running a 13.5 on a +25 and I rub on my icon uppers and my fox resi’s. Something to consider if you have a similar setup. It’s not bad but close to full lock I’m all in it. I’m assuming it’s just from the 13.5. I got a killer deal I couldn’t pass up or I was going to run 12.5.
    Deaner, tundra_20, V3N0M and 2 others like this.
  29. Jun 1, 2023 at 2:21 PM
    #2699
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    37s holding strong
    Deaner, LS3, Mountun Goat and 11 others like this.
  30. Jun 1, 2023 at 2:23 PM
    #2700
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Definitely agree on the longer studs
    tundra_20 and CaptRussia253 like this.
