New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. May 25, 2023 at 10:18 AM
    #151
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    isnt there a sight glass somewhere?
  2. May 25, 2023 at 11:44 AM
    #152
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Looks like one here.... What am I looking for?
    Here's all the parts spread out on the floor for you to see
    bmf4069 and Winning8 like this.
  3. May 25, 2023 at 11:53 AM
    #153
    Where'd you buy the aftermarket parts? I know you can't get an OEM dryer. Those are discontinued. Reason I ask is that I need some O-rings myself for it.
  4. May 25, 2023 at 12:02 PM
    #154
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    no clue. But it means something? Right?
    Bmktw2[QUOTED][OP] likes this.
  5. May 25, 2023 at 12:05 PM
    #155
    He’d be looking for bubbling in the sight glass when the AC is on. I can’t remember if that’s good or bad from what I recall. I think bad, like low on coolant or something. Have to look it up myself.
    Bmktw2[OP] likes this.
  6. May 25, 2023 at 12:15 PM
    #156
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Rockauto
  7. May 25, 2023 at 12:16 PM
    #157
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Here is where I'm at with it so far... Now it's about to start to raining again ️
    bmf4069 and Jack McCarthy like this.
  8. May 25, 2023 at 3:00 PM
    #158
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The bolts are crusty rust. I'm using penetration spray on everything. A few of the bolts just snapped off at the head... so on the survivors I'm having to dress them with the die. The bracket is really dirty too. Going to use this opportunity to try and clean this stuff up
    The idler pulley looks like it needs some TLC. I'm going to remove it, clean and grease it up.
  9. May 25, 2023 at 4:29 PM
    #159
    Silet
    Silet New Member
    The differential is open. No limited slip.
    FirstGenVol, shifty` and Bmktw2[OP] like this.
  10. May 25, 2023 at 5:14 PM
    #160
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The timing belt still looks good, Silet.
    FWI y'all: Silet is the previous owner of this truck. I invited him to the forum so he could see his old truck.
    I'm tryin to decide if I should do the timing belt, cam seals, water pump and tensioner. I think the timing belt has 90k miles on it
    bmf4069, Silet, FirstGenVol and 2 others like this.
  11. May 25, 2023 at 6:51 PM
    #161
    Silet
    Silet New Member
    If you're this far into it, you might as well do it. Get the water pump and thermostat with the idler pulley with belt kit. Having the AC compressor off will make it easy. The original water pump was weeping when I got to it at 169 k miles.
    JasonC. and Bmktw2[OP] like this.
  12. May 25, 2023 at 11:22 PM
    #162
    Casper421
    In the woods
    06 DC
    Yes, you’re already there
  13. May 26, 2023 at 5:30 AM
    #163
    Timing belt maintenance cycle is 9yr/90k miles per Toyota. Is it necessary to do it under that cycle, assuming you used OEM? No. Plenty of people have gone longer. Just know if you choose non-OEM (i.e. not Toyota/Aisin/Denso brands) from a reputable source that isn't scamazon or fleabay, you may need to do it sooner. I've seen some belts look like hell after 30k miles.
  14. May 26, 2023 at 7:54 AM
    #164
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Ordered these parts now. Will be here on Sunday. This truck does have the oil cooler
  15. May 26, 2023 at 8:02 AM
    #165
    Never buy replacement parts from scAmazon or fleaBay, whether auto, appliance, small engine, or otherwise. You will get counterfeits, possibly very authentic looking ones, but yeah. It's not a question of "IF" but "WHEN". Several people here have had it happen. And before you ask, yes, someone who ordered the Aisin kit, I believe on this very site, checked their belt ~20k later and it was cracked to shit. Ask @FirstGenVol about his fun spark plug experience.
    If it were me, I'd cancel that order, and re-order from Summit Racing or Rock Auto. Guaranteed to be authentic. And Rock Auto does 5% discounts all day to offset shipping.
    Ask yourself: What the hell is the point of replacing the timing belt, such a critical time-intensive piece, only to order from a place that's notorious for having counterfeiting issues?
    EDIT: There are some times when you may want to order some replacement parts. Headlight housings, for example? But again, if the idea of getting a fake knock-off of what you actually ordered, while paying nearly full price for authentic doesn't sit right with you, you should avoid those two sources. And here lately, Walmart's website is having the same issues. Basically, if an online store allows 3rd parties to sell parts, you DO NOT want to buy parts there, because those are the places organized groups use to peddle counterfeits at near-MSRP pricing to make a fortune. And all of those storefronts claim they're "unable to do anything" about it.
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  16. May 26, 2023 at 8:13 AM
    #166
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I appreciate the warning.
    It was shipped from and sold by Amazon. My brother says it's good.
  17. May 26, 2023 at 8:16 AM
    #167
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    My buddy swares by this silicon sealer for doing the valve covers. But it's a week out with shipping. Can I use a good permatex sealant instead or should I use the Toyota stuff for sure?
  18. May 26, 2023 at 8:18 AM
    #168
    No, I'm sorry, it's not good. And here is why.
    You do you, believe what you want, but what is outlined in that reply I just linked is what's been going on for a number of years. It's very well known, and many people have been bitten by it. It doesn't happen every day at every warehouse, but Amazon charges vendors extra to have dedicated storage, and the vast majority don't pay the extortion fees. And even then, someone on here that actually works in an Amazon warehouse told us, "A lot of times when things get returned to the bins, or doing reconciliation, the item gets tossed in the wrong bin, so there's still risk".
  19. May 26, 2023 at 8:24 AM
    #169
    Lots of valve cover info (for V8, but some shared part numbers) here: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    To that point, you can get Toyota's FIPG, ordered online, for pickup at your local dealership which probably has it in stock for pickup today, here: https://autoparts.toyota.com/products/product/fipg-oil-pan-0029500103
    While MSRP says "$20", via the nat'l parts program Toyota runs you get a discount ordering online. My local dealership lets me buy it at $14 as long as I start the order through Toyota/com link I pasted, it's the same product you linked.
  20. May 26, 2023 at 8:33 AM
    #170
    Oh - and if you want to see some of the recent purchases people have made on scAmazon and they got counterfeits - including counterfeit Denso parts - check these out, although this is just what I found in 5mins, with 10-15 minutes I could dig up a few dozen more:
    https://www.tundras.com/threads/real-vs-fake-denso-plugs-w-pics.60880/
    https://www.tundras.com/threads/in-need-of-a-proper-diagnostic-tool.112820/#post-2918397
    https://www.tundras.com/threads/psa-fake-benchmade-knives.97059/
    https://www.tundras.com/threads/counterfeit-bilsteins.120762/#post-3098043 (read this reply, but scroll thru the thread for other counterfeit stuff received, including Bilstein parts!)
  21. May 26, 2023 at 9:03 AM
    #171
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    My brother ordered the parts thru his account. He said it will be here Sunday and if it does not look good, I can return it.
  22. May 26, 2023 at 9:52 AM
    #172
    The counterfeit spark plugs I got were from eBay but he's right about Amazon too. Unless you have a very skilled eye, you can't pick up on the fact that they aren't authentic. I would order from Rock Auto and avoid Amazon like the plague.
    bmf4069 and Bmktw2[OP] like this.
  23. May 26, 2023 at 3:22 PM
    #173
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Really excited about this
    bmf4069, Jack McCarthy, w666 and 2 others like this.
  24. May 26, 2023 at 3:24 PM
    #174
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    650 lb or 700lb springs?
  25. May 26, 2023 at 3:53 PM
    #175
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Curious if the v6 manual got 550lb springs or something.
  26. May 26, 2023 at 3:56 PM
    #176
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    bmf4069 and Mr.bee[QUOTED] like this.
  27. May 26, 2023 at 4:20 PM
    #177
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  28. May 26, 2023 at 4:27 PM
    #178
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Wanna buy em?
    Jack McCarthy and JasonC. like this.
  29. May 26, 2023 at 4:44 PM
    #179
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    “Off a southern truck, always garage kept, perfect condition I just don’t need em anymore.”
  30. May 26, 2023 at 4:54 PM
    #180
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    OEM spring color codes:
    2000-06 Tundra Stock 4X2: Drivers: yellow-white, Passengers: blue-white
    2000-06 Tundra Stock 4X4: Drivers: yellow-green, Passengers: blue-green
    2000-06 Tundra TRD 4X4: Drivers: yellow-yellow, Passengers: blue-yellow
    2000-06 Tundra TRD 4X2: Drivers: red-yellow, Passengers: purple-yellow
    No mention about V8 vs V6.
    Bmktw2[OP] and Mr.bee[QUOTED] like this.
