General Supercharger Thread
  1. May 25, 2023 at 10:14 AM
    #8581
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Rivets under the wrap no bueno
  2. May 25, 2023 at 10:15 AM
    #8582
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    You won't see them behind me anyway lol
  3. May 25, 2023 at 10:23 AM
    #8583
    snivilous
    SW UT
    300k+ Supercharged 2008
    For someone running leafs you talk a big game :cool:
  4. May 25, 2023 at 10:27 AM
    #8584
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    LOL!!
    HulkSmurf14 likes this.
  5. May 25, 2023 at 11:57 AM
    #8585
    snivilous
    SW UT
    Double checking dimensions then sending part prints out for quote for @reywcms Whipple to RCF adapter, which will eventually evolve into Whipple to GM adapter...
    Danimal86, rockmup, AZTundra and 6 others like this.
  6. May 25, 2023 at 11:57 AM
    #8586
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Solidworks for the win!
    snivilous[OP] likes this.
  7. May 25, 2023 at 12:01 PM
    #8587
    snivilous
    SW UT
    Except for the 98% of the time that it's a complete pile of shit :rofl: yesterday I was trying to mirror a subassembly to another side of an assembly, and it would not for the life of it put it in the right spot. I even added the second subassembly manually and added reference axis and planes and mirrored the first one again just to make sure I wasn't crazy, and it always ended up 1/2" too high. Like wtf :confused:
    HulkSmurf14[QUOTED] and reywcms like this.
  8. May 25, 2023 at 12:02 PM
    #8588
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    If you already have the dimensions, can you also get quotes for a GM TB on Harrop? Pretty please? :D
    I bought one of these to go with the signal converter I ordered, the mount is the only missing piece...I was going to hack up some aluminum I had laying around, but would prefer something professional.
    https://www.summitracing.com/parts/ADO-19420707
    snivilous[QUOTED][OP] likes this.
  9. May 25, 2023 at 12:08 PM
    #8589
    snivilous
    SW UT
    I haven't done any Harrop stuff so would need some details. Does the Tundra throttle body bolt directly to the Harrop so I can just use the Tundra TB bolt pattern? Do you know what the Harrop inlet diameter is or what you'd want it to be (if you wanted to port it for instance)? I haven't pulled the GM TB dimensions yet, I'll need Rey to confirm the dimensions are the same as the ones I have once he gets his in. But all of those are fairly minor changes with the bulk geometry and machining operations being the same, so whatever this quote is shouldn't be far off for a Harrop to GM setup.
  10. May 25, 2023 at 12:12 PM
    #8590
    HulkSmurf14
    2014 Tundra Limited
    Yeah man...SW is a fickle b!tch
  11. May 25, 2023 at 12:14 PM
    #8591
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Shit yes!
  12. May 25, 2023 at 12:18 PM
    #8592
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The stock Tundra TB does mount directly, I'll get some measurements and get back to you.
  13. May 25, 2023 at 12:21 PM
    #8593
    snivilous
    SW UT
    If you can get dimensions of the outer perimeter of the surface that the TB bolts to on the Harrop, then I can make the adapter sit (close to) flush so it'll look like a continuation of the Harrop and not so much a spacer just bolted in the middle. Like the outside of this Whipple adapter matches the Whipple profile, if it weren't for that then it could've been slimmed up a lot more.
    Silver17 and armyoffoo[QUOTED] like this.
  14. May 25, 2023 at 12:22 PM
    #8594
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Now do one of those LS TB ported Nose pieces for the maggy! lol
  15. May 25, 2023 at 12:24 PM
    #8595
    snivilous
    SW UT
    The Mag and Harrop should be the same adapter since they're both made for the Tundra TB. As far as porting the blower snout that's a whole different animal :rofl:
  16. May 25, 2023 at 12:45 PM
    #8596
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Thanks for putting the work in gents. Would be cool to see this all come together to a working finished product.
    reywcms likes this.
  17. May 25, 2023 at 1:05 PM
    #8597
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Hi does anyone have a post/pics/instructions on how they installed their Walbro/Ti 450 (274 model) in a non flex fuel setup? I’ve been trying to find a post with the search for a while and haven’t seen anything for general install. Just ordered one from Summit plus their install kit. Mostly curious about the wiring situation. Hoping to use stock wires/fuel lines but can replace if that’s required (seen conflicting posts on this).
  18. May 25, 2023 at 1:18 PM
    #8598
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Pretty sure I just used the factory plug and wired it to the pump. Been awhile. Also added some extra holes to the basket.
  19. May 25, 2023 at 1:21 PM
    #8599
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    5% Off of any Whipple kit through the weekend here at Hotshot Offroad. No tax either as long as you're in Cali (or at least not shipping there) :spy:
    Not gonna spam in here since this is a discussion thread, but I figured I would toss it out there!
  20. May 25, 2023 at 1:22 PM
    #8600
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Sweet!! @Vizsla here you go
  21. May 25, 2023 at 1:57 PM
    #8601
    snivilous
    SW UT
    It was $125 per adapter and I ordered 3x, so figure around the same. That's out of raw 6061-T6.
    armyoffoo[QUOTED] and reywcms like this.
  22. May 25, 2023 at 2:02 PM
    #8602
    snivilous
    SW UT
    URD has a write up that I followed for my original Aeromotive, and the Walbro I did the exact same thing. And all that really involves is cutting some slits in the fuel basket so you can run a zip tie (I used a metal one so it doesn't melt from the fuel) to hold the pump to the side (very fancy :D ), and then if the plug is different then just crimp the new plug onto the existing wires. The corrugated black line is the return as I recall, and the rubber line is high pressure fuel line and swapped out whatever the factory plastic line was and is just hose clamped to the outlet nipple on the pump and basket.
    With that said, since I need to say it always now, your results may vary. Seems like half the people end up having some issue with the wiring doing what they want, but in the case of my 2008 non flex fuel it was extremely simple.
  23. May 25, 2023 at 2:08 PM
    #8603
    M3Tundra-JK
    Scott
    2005 GX470
    Attached URD Fuel Pump Upgrade instructions, and a link to upgrading the upgrade
    https://www.tacomaworld.com/threads/improving-the-urd-fuel-pump-kit.308651/
  24. May 25, 2023 at 5:58 PM
    #8604
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This is how I did my flex, then when the 450 failed I direct wired it using the oem as the relay trigger. No electrical problems, don't ask about the hoses :p
  25. May 26, 2023 at 1:54 AM
    #8605
    e30cabrio
    Japanese police have Land Cruisers!
    Ponderosa_Pine likes this.
  26. May 26, 2023 at 4:07 AM
    #8606
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    What happened to the dude, on here, with the Harrop LX570? I forget his name....
  27. May 26, 2023 at 11:44 AM
    #8607
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    We’ll see if it fits lol
  28. May 26, 2023 at 11:52 AM
    #8608
    HulkSmurf14
    2014 Tundra Limited
    FEED ME!! That's what that filter means...
    reywcms likes this.
  29. May 26, 2023 at 11:54 AM
    #8609
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    How much air? ALL OF IT
  30. May 26, 2023 at 1:01 PM
    #8610
    M3Tundra-JK
    Scott
    2005 GX470
    May just need to leave the fender off at this point...
