  1. May 21, 2023 at 4:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Nope
    He’s wild
    Literally just showed up one day along with a female almost three years ago. Before that, a different male had showed up about 6 years ago, but he got killed by a coyote last September. Now there’s three more females that were born last summer. And another young male and female showed up a few weeks ago (it’s currently mating season).
  2. May 21, 2023 at 5:55 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ...that peacock :muscleflexing:
  3. May 21, 2023 at 6:28 PM
    PermaFrostTRD
    Northern NY
    Does a garden count as “home” improvement?
    Had some raised beds on concrete/ asphalt before. They were getting cooked and requiring too much water.
  4. May 21, 2023 at 9:53 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Thx for the photo and comments. We had a metal reel at our old home but it seems they quit making those, and have been living with hoses on the ground till we found something. I think I’ll have to try one of these…
    TaquitoBandito and RainMan_PNW like this.
  5. May 21, 2023 at 10:00 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Glad my little blurb helped. All powder coated aluminum for the mount and spool. All mounting hardware and fasteners are stainless, the water piping is copper and brass or bronze. The included hose to the exterior faucet is very nice as well, and is drinking water safe.
    Unfortunately Eley doesn’t give their hoses away looks like about $2/ft so not cheap to replace hoses, but damn the hose is nice.
    TaquitoBandito and WAtundra4x4 like this.
  6. May 21, 2023 at 10:03 PM
    Coal Dragger
    Kung Fu Dick
    Forgot to add the wall mount is one of several solutions they offer, and can be configured to spool parallel to the wall (as pictured) or perpendicular to pull directly away from the house. Your choice and you can swap it out either way depending on your needs, no additional parts needed.
  7. May 24, 2023 at 12:06 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    slatwall accessories came in so i can hang stuff. goal is to have maybe 7-10 items total actually on the garage floor. everything else is on the wall or in cabinets. got a lot of stuff on the wall already and space for a bit more. very happy with garage progress so far.
  8. May 24, 2023 at 5:42 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Vinyl siding on the garage was looking pretty bad, so I gave it a good wash and then painted it with latex house paint to match our vinyl house siding. This was the second time in about 8 years that I have painted the garage. Although the old paint had faded badly, it never once started to come off. I am amazed at how well paint holds up on vinyl.
  9. May 24, 2023 at 6:20 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    If they're anything like my kids, they won't play in the room that has all their toys in it. Instead, we drag everything out to the living room. Best of luck.
  10. May 24, 2023 at 6:25 AM
    SnrDisregardo
    Wade
    IL
    I have the flexzilla hoses for air and water and love them. They are a bit loud in the color department, but I would describe them in the same way, in terms of material.
    TaquitoBandito likes this.
  11. May 24, 2023 at 6:43 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    it's upstairs above the garage on their side of the house, so i'm hoping that will deter that. hoping...being the key word there. planning on ordering the TV soon and they can even start having their movie nights up there. that'll give us more time to ourselves to "talk";)
  12. May 24, 2023 at 7:18 AM
    SnrDisregardo
    Wade
    IL
    Seems like you've "talked" enough. LOL. Just kidding you.
  13. May 25, 2023 at 6:10 AM
    Im a little a stuck here. Our soil in CO likes to settle, which of course causes shifting. It appears it moved this spout up some, so I purchased this extender, but don’t think I may need this (exact) one. I can probably cut it down, but is there a better one that’s more “fitting” for this exact scenario?
  14. May 25, 2023 at 6:28 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Either extend the downspout with a matching piece or extend the drain pipe. Both will look better than the flex extender.
    You don't need much so you may even be able to get by with a downspout connector.
  15. May 25, 2023 at 6:45 AM
    Because I am retarded in this area, are you able to link me to one that should work?
    TaquitoBandito and NWPirate like this.
  16. May 25, 2023 at 6:54 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  17. May 25, 2023 at 8:42 AM
  18. May 25, 2023 at 9:14 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If it’s aluminum, you could buy another piece of downspout cut 6 inches and connected to the old one
    https://youtu.be/7ik9KZIuH4o
  19. May 25, 2023 at 9:29 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    I agree with everyone on the extender doing the trick but if you do not want to see the new piece and prefer a one piece look I would put a whole new downspout and cut it to size and replace your old one. That is also depending on if a whole new downspout would match and fit in that area
  20. May 25, 2023 at 9:31 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Sanded and re-stained two exterior doors on the house. Ordered a new wand for the pressure washer.
  21. May 25, 2023 at 9:32 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Quietcool StealthPro 6.0 is in. Had them do the RF remote over the hardwired. They said that they have coming next year a kit that tie into thermostats and they also mentioned something to open/close windows automatically and that it would be better to have the RF.
    uGFNAEffOLfh_fVPT23YViNdycrrd3-JOsM8vGXY_06b7813ae3d911623f1d07c70b93b335da8cfabd.jpg
    2EfFP6FKI0ZV0aycqvtXKjdrhm05ERUFQo4tOeKv_d7abe8d6f17dc5dfb2d2b63a6b32484ce13cece9.jpg
  22. May 26, 2023 at 9:24 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Finally got my front yard to look half decent just in time for Summer. I always neglect Fall maintenance, and it always kicks my ass. :annoyed:
    Happy Memorial Day Brothers. :drunk:
  23. May 26, 2023 at 9:33 PM
    Outbound
    Aaron
    Northern Alberta
    I love all the trees. One thing my area lacks is trees. The city lots in newer neighborhoods generally have no trees, or just small stunted ones.
  24. May 26, 2023 at 9:40 PM
    TILLY
    Massachusetts
    We love the trees too, we have the most of any lot on our street. The worst part is picking up the leaves every Fall. I think its worth it, but its not fun.
  25. May 27, 2023 at 5:50 AM
    Dont pick em up. Mulch em.
    TaquitoBandito and TILLY[QUOTED] like this.
  26. May 27, 2023 at 7:10 PM
    TILLY
    Massachusetts
    I attempted that a few years ago but there's way too many leaves, and it started killing the grass. I need to just bite the bullet and do a better job in the Fall so its not so overwhelming when spring rolls around.
  27. May 27, 2023 at 7:14 PM
    Outbound
    Aaron
    Northern Alberta
    I enjoy raking leaves. It relaxes me.
  28. May 27, 2023 at 7:37 PM
    TILLY
    Massachusetts
    Come on down to MA. you will definitely have a relaxing time, I have Beer. :)
  29. May 27, 2023 at 7:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I use a lawn vac it's pretty awesome and it shreds so I can add it to my compost bins.
  30. May 27, 2023 at 7:51 PM
    TILLY
    Massachusetts
    Do you have something like a Cyclone Rake? I was contemplating picking one up, but they're a little pricey.
