General Supercharger Thread
  1. May 24, 2023 at 12:10 PM
    #8551
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I think it was an old Victor post or video saying the issue is the TPS sensor signal range. Toyota vs. GM, one is rising rate, one is inverse; or something similar. As the IG guys have figured out, it's just a signal processor convertor needed. I wonder if any of the Megasquirt / DIYEFI guys have came up with a solution?
    *edit* found the video. Toyota TPS is 2 rising voltage outputs. GM has 1 rising, one falling. This is a bit outside of my wheelhouse, but not too far.
    *EDIT2* I decided to move my ramblings to the TB development thread we pulled from the dead and not clog this up so bad.
    https://www.tundras.com/threads/ini...le-body-on-a-supercharged-tundra.75732/page-2
    Winks4x4Toy and Saltyhero13 like this.
  2. May 24, 2023 at 12:17 PM
    #8552
    snivilous
    SW UT
    300k+ Supercharged 2008
    Well no shit :rofl: it'd have be a parts kit to adapt the two together
  3. May 24, 2023 at 1:38 PM
    #8553
    Saltyhero13
    Saltyhero13 Throbbing Member
    If it fits in the housing I think it would be better to swap the guts than to have a translator. Less likely to throw faults. Translator is also introducing another failure point.
    Only issue I could see is if the larger TB plate is heavier.
    I see some additional discussion has taken place.
    reywcms[QUOTED] likes this.
  4. May 24, 2023 at 1:52 PM
    #8554
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I personally wouldn’t want to be tuned on any setup with components that are not readily available, especially relatively untested non OEM parts would be my main hold back. Unless of course it’s not big deal to just switch back to the regular TB without changing the tune and just make less power.
    reywcms and Saltyhero13 like this.
  5. May 24, 2023 at 2:02 PM
    #8555
    Saltyhero13
    Especially considering not much HP may be left on the table based on the article you posted a few months ago.
    Silver17[QUOTED] likes this.
  6. May 24, 2023 at 2:11 PM
    #8556
    snivilous
    SW UT
    I have Reys RCF throttle body he sent me. I also have a Nick Williams 92mm (iirc) on my LSA setup, and some random (6.0 or 5.3) throttle body from one of my engines:
    Assuming the Tundra is the same as the RCF, the motor assembly is riveted to the housing so those would need to be drilled out, and then all the parts of the housing (can see the motor bulge and there's probably bearings and springs and shit) would need to be made as a stand alone piece is my thinking, then probably have a second piece that connects the Tundra electronics output (probably a gear or maybe a dedicated output shaft) to the GM butterfly shaft. So optimistically it'd be two parts: replicate the housing components on the Tundra TB and that part would also somehow attach to the GM, and then some intermediate connection between the drivetrain and the butterfly valve. Probably wouldn't look much different than the stock RCF shown besides the housing becoming effectively a two piece design. And then cap off all the GM shit.
    With that said I haven't torn into anything, and Rey didn't want me destroying his RCF TB in the name of science :D
  7. May 24, 2023 at 3:33 PM
    #8557
    Silver17
    Eastern PA
    It’s sad I don’t even remember which article that would be. Lol
    Unrelated, I spotted an elusive Craptor R in the wild today.
    reywcms likes this.
  8. May 24, 2023 at 4:05 PM
    #8558
    Saltyhero13
    Winks4x4Toy and Silver17[QUOTED] like this.
  9. May 24, 2023 at 5:22 PM
    #8559
    Silver17
    Eastern PA
    Ah yes I remember now. That article seems to have a lot of positives to say about radiused entries as well. Wonder if there is truly a benefit to the TRD airflow accelerator aiding flow into the airbox. It’s pretty cheap, probably worth it. But if the TB is a restriction does it even matter?
    Saltyhero13[QUOTED] likes this.
  10. May 24, 2023 at 5:33 PM
    #8560
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  11. May 24, 2023 at 6:40 PM
    #8561
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    So, my truck has been sitting since I installed the PS fuel system, for me it was just a fuel pressure regulator, lines and rails, I already had the injectors and fuel pump. It's been sitting because it would go past 3k rpm after the install. I thought I could have a clogged cat, but the guys at PS said I shouldn't drive it because it needs to be tuned. I'm four weeks into a ten week wait for my AR long tube headers, once they are installed PS will tune it. So, like I said the truck has been sitting until tonight. @snivilous sent me a tune that got my truck running normal again and I can't thank him enough. I will be installing his 2.2 pulley with the header's and putting the truck on the Dyno to see the difference.
  12. May 24, 2023 at 6:43 PM
    #8562
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Glad he got it running! Can you share a pic of how the Prospeed box looks against the fender wall? Curious since there’s no pics of that.
  13. May 24, 2023 at 6:45 PM
    #8563
    Fastlane47
    Maryland
    2018 Platinum
    I have the whole drilled for the second air inlet, worked great with the PS intake. Let me know if you need a better pic. PXL_20230419_155150347.jpg
    HulkSmurf14 and reywcms like this.
  14. May 24, 2023 at 6:59 PM
    #8564
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Awesome ya a little lower to see the fenderwell area where the inlets are would be great.
    HulkSmurf14 likes this.
  15. May 24, 2023 at 7:08 PM
    #8565
    Fastlane47
    Maryland
    2018 Platinum
  16. May 24, 2023 at 7:17 PM
    #8566
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Awesome thank you! Did you add a larger airfilter? I ordered a larger piece if it fits I’ll send you the part info.
    Fastlane47 likes this.
  17. May 24, 2023 at 7:44 PM
    #8567
    snivilous
    SW UT
    Buy mine since it's sitting on the table and I don't want it
  18. May 24, 2023 at 7:47 PM
    #8568
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I got one lol
    snivilous[QUOTED][OP] likes this.
  19. May 25, 2023 at 6:36 AM
    #8569
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I argued with Amazon about not getting a replacement in a timely fashion so loudly they said keep it & have your damn money.
    I need a good radiator to go to L.A. at 3am tomorrow so I took the damaged radiator to a shop, they pressure tested it & found it good, tested mine & it's leaking, they installed the new one, I was running at 205 before pre overflow nipple breakage, now it is 190.
    I will order the CSF when I get back from L.A.
    Also, while it was there, they dropped the tank, welded in studs & put the tank back, now I can drop the tank to my heart's content (none) and not worry about the damn straps. Shoulda been studs in the first place imho.
  20. May 25, 2023 at 6:43 AM
    #8570
    Fastlane47
    Maryland
    2018 Platinum
    I'm just running what came with the intake.
  21. May 25, 2023 at 6:43 AM
    #8571
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Studs would/will make it so much easier to get that hole on the end of the strap properly in place!
    e30cabrio[QUOTED] likes this.
  22. May 25, 2023 at 6:45 AM
    #8572
    e30cabrio
    Yup & they used G9s so it'll take a lot of work to mangle them. lol
  23. May 25, 2023 at 7:35 AM
    #8573
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    PS made 700whp at the rear wheels at the same boost with a Harrop on flex as this Lexus that made 840whp to all four. Crazy!
  24. May 25, 2023 at 7:37 AM
    #8574
    e30cabrio
    I can't imagine owning a current gen LC at all, (wife would never let me spend 100k let alone an 800hp one! Sweet dreams are made of this!
  25. May 25, 2023 at 7:49 AM
    #8575
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    700-840 is a considerable difference. I'm not sure what size pulleys they were running, but the comments said 17-18 PSI pulling through that 110mm throttle body and larger custom intake tube. Or maybe ProSpeed's tune is just really conservative.
    reywcms likes this.
  26. May 25, 2023 at 7:54 AM
    #8576
    ssmokedz
    Shelton CT
    How much are you looking to get for it? I might be interested.
    AZTundra likes this.
  27. May 25, 2023 at 7:58 AM
    #8577
    snivilous
    SW UT
    $650 listed on their website. It's literally still in the wrapping it showed up in. $500 plus shipping?
    reywcms likes this.
  28. May 25, 2023 at 8:00 AM
    #8578
    snivilous
    SW UT
    Fastlane47, e30cabrio and AZTundra like this.
  29. May 25, 2023 at 9:36 AM
    #8579
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Space wrapping is extra
  30. May 25, 2023 at 9:38 AM
    #8580
    snivilous
    SW UT
    Those wrinkles deserve a refund
